Old 02-01-2012, 02:41 PM   #1
edwinv04wrx
Member#: 306067
2004 wrx
wrb
Default Rp Synchromesh Anyone?
sup guys i've been noticing & feeling that gears 3-4 are grinding. i want to change my transmission fluid & add Royal Purples Synchromesh. do i add a whole bottle + Subaru Extra-S 75w-90 gear oil? does that sound right? sorry for the noob question but help me out thanks
edwinv04wrx is offline   Reply With Quote
Old 02-01-2012, 05:38 PM   #2
bluesubie
Member#: 767
04 FXT
I've never heard of any positive experiences with RP gear oil.
-Dennis
Old 02-01-2012, 07:29 PM   #3
edwinv04wrx
Member#: 306067
2004 wrx
wrb
really? what do you recommend?
Old 02-01-2012, 09:09 PM   #4
bluesubie
Member#: 767
04 FXT
Extra-S if you do not see temps below freezing, and Mobil Delvac if you do.
-Dennis
Old 02-02-2012, 02:54 AM   #5
edwinv04wrx
Member#: 306067
2004 wrx
wrb
what about motul?
Old 02-02-2012, 06:37 AM   #6
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Stop shotgunning oil guesses at the masses and choose one that WORKS. http://forums.nasioc.com/forums/showthread.php?t=995498 has the good one. Want to use something else? Knock yourself out, but its at your own risk.
Old 02-02-2012, 11:48 PM   #7
edwinv04wrx
Member#: 306067
2004 wrx
wrb
i am going with motul 300
Old 02-03-2012, 08:52 AM   #8
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
Good choice.
Humor me.
Are you the original owner and if so, how often was the gear-box oil changed? If not, then how many miles have you put on the car as 2nd (or 3rd) owner and how often have you changed it?
I ask because, and respectfully, it seems that everytime I read about someone's transmission woes, that person has not changed their oil or has changed it per Subaru's recommended service schedule, which however is still inadequate because the car is driven 'hard'.
Just curious.
Old 02-03-2012, 01:21 PM   #9
edwinv04wrx
Member#: 306067
2004 wrx
wrb
i am the 2nd owner i believe i would have to double check but the car has 85k miles. when am i suppose to do a transmission fluid change according to subaru's service schedule?
Old 02-03-2012, 05:33 PM   #10
Big-E
Member#: 123843
2006 SGM WRX S2
Front and rear gear oils: every 30 months or 30,000 miles you are to: "inspect, correct, or replace if necessary."
"When the vehicle is frequently operated under severe driving conditions, replacement should be performed every 24,000 km (15,000 miles)."
http://www.subaru.com/content/downlo...04SchedFed.pdf
As an example, I put about 10,000 miles on my car every year, but I drive it spiritedly and I auto-cross it as well. So, I change it every year, which is well before the 15,000 mile limit.
I would say that most WRX and WRX STI's are driven under "severe driving conditions", but that most do not do the minimum required maintenance.
Also, if you modify your car, you modify your service schedule intervals.
Old 02-03-2012, 07:05 PM   #11
edwinv04wrx
Member#: 306067
2004 wrx
wrb
thanks for the info bro!
anyone in NJ with Tactrix 2.0 that I can borrow/meet up? wordsarize Tri-State Area Forum 3 02-02-2012 09:32 PM
anyone try this bulb? svynx Electrical & Lighting 2 02-01-2012 02:36 PM
What catback will fit with TurboXS DP & RP? sneeky Factory 2.5L Turbo Powertrain 1 04-02-2005 07:49 PM
Now this is RP Christoff Off-Topic 8 02-13-2004 03:47 PM
New Spring set in Development at RP - feedback? Rally Performance Brakes, Steering & Suspension 6 01-04-2004 02:45 PM
Message Board Statistics All times are GMT -4. The time now is 12:01 AM.
