Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 02-01-2012, 06:25 PM   #1
beater
Member#: 221429
Default Gas smell... 1997
I have a 97 legacy (outback) that has random issues of gas smell. I can smell it inside the car and out, but not all the time. When it does the fuming, the gas cap has no pressure. When there is not fumes the cap has pressure.
I am putting the cap on all the way. Sometimes it does not happen until days after I fill up.
Anyone got any suggestions for me to look into?
beater is offline   Reply With Quote
Old 02-01-2012, 07:59 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
If the tank doesn't have pressure then the vapors are going to come from elsewhere in the fueling system. Can't say I'm as familiar with it as I should be, but it's possibly the purge valve for the evaporative canister.
I'm not sure how much this has changed from the older cars, but it's probably very close:
DLC is offline   Reply With Quote
Old 02-03-2012, 02:51 PM   #3
Navi271
Member#: 203099
1995 Legacy Wagon
Winter Green Metallic
Do you know if you're losing any gas? The fuel filler neck likes to rust out on our older legacys. Check it even if you're not losing gas.
Navi271 is offline   Reply With Quote
Old 02-04-2012, 07:04 PM   #4
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
Does this happen in cold weather only or even when it is warm out? When I worked as a Subaru Service advisor we would see this a lot in the colder months and the clamps on the fuel hoses in the engine area were always the culprit.
blackfang is offline   Reply With Quote
Old 02-05-2012, 09:19 AM   #5
^jynx^
Member#: 1787
That has happened to me twice. Deffinatly check that
^jynx^ is offline   Reply With Quote
Old 02-15-2012, 10:27 AM   #6
chrish8r
Member#: 275511
1999 legacy outback
winestone
I had to replace my gas tank because there was rust or whatnot on the lines feeding into the tank. Has the gas smell sometimes. You may want to check into this as well
chrish8r is offline   Reply With Quote
Anyone looking for a gas saver? 1997 Toyota Camry v8eaterWRX SWIC Private Classifieds 8 11-30-2008 10:28 AM
Horrible Gas Mileage/Raw gas smell in cabin ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-18-2007 07:14 PM
2 newbie questions, Occasional gas smell and gas pipe wattpuppy Newbies & FAQs 0 10-31-2006 01:01 PM
gas smell TSB- repaired and still smelling it! SVX WRX Warranty Issues & SOA Problems 5 04-13-2004 07:33 PM
gas smell? tonic Newbies & FAQs 4 04-11-2001 10:53 AM
