Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 02-02-2012, 12:56 PM   #1
AJW Performance
Vendor Sales Rating: (38)
Member#: 219896
Default Gauge Combos Galore! SMY,Defi, STRI, ATI, AEM + more
We distribute SMY Gauge Cluster products for the 08-14 WRX/STi, 09-13 Forester and 02-07 WRX/STi! These cluster are high quality and designed to be an OEM replacement for your factory bezel!
08-14 WRX and 09-13 Forester
02-07 WRX/STi
Don't forget to check out the manufacturer!
SMY Performance
ATI Gauge Pods Avilable as well!
02-07 WRX/STi
08-14 WRX/STi
Defi Advance CR series 52mm or 60mm Gauges
Defi-Link Advance CR 52mm gauges utilize Defi's next generation, Defi-Link Advance control unit for ultra precise monitoring and interaction. A built in warning light will illuminate if any short, sensor failure, or connection failure is detected. Defi also built in a user-determined "peak" and "warning" setting that will illuminate a light to indicate that one of these value has been reached. The Advance CR system is able to record and play back any gauge display for up to three minutes. Note that Defi-Link Advance gauges and control unit are not compatible with the standard Defi-Link system.
Features:
- Driving data can be stored and can be replayed up to 3 minutes.
- Warning by buzzer sound (defeatable) when the warning LED is on.
- Records peak values and warning values during driving.
- The illumination at night can be switched between 2 different colors. (White dial: amber red / blue; Black dial: white / amber red)
- Self-diagnosis system turns the warning LED on to indicate any wire disconnection, short circuit or serial communication error.
- Available in White dial/Amber Red/Blue or Black dial/White/Amber Red
(Defi-Link Advance control unit is required for the following gauges)
- 2.0 Bar boost gauge
- Intake Manifold Pressure Gauge
- Oil Pressure Gauge
- Fuel Pressure
- EGT Gauge
- Water Temp
Defi Racer series
Defi's Racer series gauges will reward you with their great response and reliable readings. The gauge faces are a stealthy tinted black when the power is off. Fire up your car and enjoy Defi's signature sweeping ceremony as the gauges light up bright. Defi Racer gauges are standalone gauges as they do not require a Defi-Link Control Unit for use. The temperature gauge can be used for water or oil and the pressure gauge for fuel or oil. The Racer series are smaller, less expensive, and don't require a control unit but still have the aggressive styling and accuracy that Defi is known for. These gauges are 52mm or 60mm and display in US measurement units.
Features:
- The outer bezel contains a red triangle and can be rotated to be used as a visual indicator.
- Enjoy Defi's signature flashing and sweeping ceremony on power on / off.
Self-diagnostics function monitors both sensor disconnection and short-circuiting during start-up.
- Available in Red, Blue, or White!
Available for:
- Boost (PSI)
- Pressure (PSI)
- EGT (Fahrenheit)
- Temperature (Fahrenheit)
- Voltage
AEM Digital display gauges
AEM's digital display gauges feature a standard 52mm gauge housing that fits in most gauge pods and can be remotely mounted virtually anywhere. Each gauge includes interchangeable silver and black bezels & black and white faceplates to personalize the look of your gauge; it's like having four designs in one! Each gauge includes 24 color-coded LED lights that change from green to yellow to red for immediate reference to the measured parameter as well as an integrated three-digit display that reveals real-time operating conditions.
- Boost
- Oil Pressure
- Transmission, Water or Oil Temperature gauge
- Volt
- Wideband UEGO
Need a wide-band? AJW Performance Recommends:
AEM Wide-band UEGO
AEM's Wide-band UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! The controller also features an LED readout and sweeping LED "needle" that changes colors as AFR fluctuates from rich to lean. The 52mm (2-1/16") gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Key Features:
- Bosch sensor included
- 24 Color-coded LED display lights
- Integrated three-digit display reveals AFR or Lambda in real time
- 0-5v analog output included for use with data loggers and ANY engine management system
- Black or silver bezel with black or white face
STRI Gauges also available!
X Line Series
- 52mm or 60mm
- Boost
- Vacuum
- Water Temp
- Oil Temp
- Oil Pressure:
- Exhaust Temp
- Tachometer
- Voltmeter
- Fuel Pressure
Digital Stepper Drive (DSD) Series:
- 52mm or 60mm
- Boost
- Vacuum
- Water Temp
- Oil Temp
- Oil Pressure:
- Exhaust Temp
- Tachometer
- Voltmeter
- Fuel Pressure
Want a Combo? No problem! Let us know what you want for the best price! Please PM us for all questions!!!
__________________
Best Pricing and Customer Service in the Business!
Shop Line: 603-715-9076
Hours:
Monday- Friday Closed weekends
9:00 AM to 5:00 PM at shop
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
facebook us: "AJW Performance"
Follow some of our work-
AJW Performance is offline
Old 02-03-2012, 02:09 PM   #2
AJW Performance
Member#: 219896
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-06-2012, 10:25 AM   #3
AJW Performance
Member#: 219896
SMY Cluster deals ready to ship!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-06-2012, 01:16 PM   #4
TGUN11
Member Sales Rating: (3)
Member#: 287255
2011 WRX Limited LRP
Tuned by MotionLab
TGUN11 is offline
Old 02-06-2012, 05:00 PM   #5
AJW Performance
Member#: 219896
Thanks
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-07-2012, 12:01 PM   #6
AJW Performance
Member#: 219896
Here for the day with lots of gauges in stock! SMY Clusters available with great combos
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-08-2012, 10:05 AM   #7
AJW Performance
Member#: 219896
Gauges combos in stock!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-09-2012, 10:21 AM   #8
AJW Performance
Member#: 219896
SMY Clusters FTW! ATI pods in stock as well. The new Defi 60mm gauges are in
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-10-2012, 11:50 AM   #9
AJW Performance
Member#: 219896
Lets get some packages out of here today! Free shipping on your purchase of an SMY Cluster with gauges!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-13-2012, 11:18 AM   #10
AJW Performance
Member#: 219896
Here for the day to help our customers get the gauges they need! Let us know what youre looking for.
Fresh batches of Defi Racer series in 60mm all here!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-14-2012, 09:31 AM   #11
AJW Performance
Member#: 219896
Thanks for the orders!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-14-2012, 05:01 PM   #12
AJW Performance
Member#: 219896
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-15-2012, 12:25 PM   #13
AJW Performance
Member#: 219896
Here all day to get people their gauges and pods!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-15-2012, 03:43 PM   #14
scoobysti2005
Member Sales Rating: (1)
Member#: 300789
2005 Wrx Sti
how much for defi 60 mm red and black oil pressure and egt shipped to 18360
scoobysti2005 is offline
Old 02-16-2012, 10:20 AM   #15
AJW Performance
Member#: 219896
Sending PM
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-17-2012, 01:22 PM   #16
AJW Performance
Member#: 219896
WBR Products in stock!
PM for more details!
In stock, Headers, Intakes and a couple FMIC kits. These headers are good for 380-400 WHP. Twin Scroll setups available for 500 or better whp. Fits 2 bolt, 3 bolt and 4 bolt uppipes (WBR). Intakes are available in 2.75 and 3" options with a huge Green filter, reusable, two layers of woven cotton with a steel mesh over the top.
If you want to go fast with American made quality products, you have come to the right place! WBR Performance products available only at AJW
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-20-2012, 06:42 PM   #17
cavSuba
Member Sales Rating: (2)
Member#: 287746
2012 WRX Limited
Price for smy cluster with with defi red racer boost and oil pressure gauge? Combo price/discount? Hehehe shipped to 43081
cavSuba is offline
Old 02-21-2012, 11:16 AM   #18
AJW Performance
Member#: 219896
You got it. Sending you a PM now
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-22-2012, 09:08 AM   #19
AJW Performance
Member#: 219896
Who else has questions for me?
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-22-2012, 09:23 AM   #20
jay25RS
Member Sales Rating: (30)
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
How much for a Defi Advance CR 52mm Black boost gauge (I think: DF07802) and Defi ADVANCE controller (I think: DF07703) shipped to 06712?
jay25RS is offline
Old 02-22-2012, 11:38 AM   #21
AJW Performance
Member#: 219896
Look at you! Part numbers and everything. Sending PM
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-23-2012, 09:01 AM   #22
AJW Performance
Member#: 219896
Here for the day! Thanks for the sales.
Dont forget we have over 50 SMY Clusters in stock!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-24-2012, 11:47 AM   #23
AJW Performance
Member#: 219896
Gauge combos available here! Let us know if you have any questions and Ill be happy to help!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-27-2012, 11:33 AM   #24
AJW Performance
Member#: 219896
Got some ripping combo deals on gauges! Let me know how to help
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Old 02-28-2012, 11:06 AM   #25
AJW Performance
Member#: 219896
Plenty of gauge combos here at AJW Performance. Let me know how I can help!
__________________
Hours:
21 Meadowbrook Ln
Unit 10
Gilford, NH 03249
Closed Thread
SMY Clustermaker Gauge pods AND stri, prosport, defi, innovate, aem combos! IMPORTIMAGE Import Image Racing 466 09-19-2014 08:54 AM
AEM/DEFI/STRI/Greddy/Blitz and many more! BigValleyPerformance Gauges & Electronics 63 04-24-2011 07:34 AM
Great pricing on Zenesis Alarms/Starters, Defi, STRI, and more!!! subaruwrxparts.com Interior/Dressup/Audio & Security 6 10-29-2009 12:50 PM
All IN STOCK Electronics! Defi STRI HKS Apexi GReddy Cobb AEM MORE! Z1 Performance Interior/Dressup/Audio & Security 87 09-12-2008 05:16 PM
Zenesis alarms, Defi, STRI, Aem, Navman, Autometer, and so much more! IMPORTIMAGE Interior/Dressup/Audio & Security 96 08-06-2008 06:01 PM
