Old 02-02-2012, 04:59 PM   #1
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
Default question about v5/6 boost levels
Unmolested V5 STi type RA 1999 - 2000 ej207
what is the stock psi for boost?
About how far can I turn it up on stock internals and stay reliable with following mods?
parallel fuel rails
Upgraded fuel pump
AC delete
Rotated manifold
FMIC
Turbo timer
Upgraded radiator
Strengthened oil pickup tube
Launch control
Open DP
Lite tune
Would like to get close to 400 to the wheels, is that feasable with these mods?
ruckus racing is offline   Reply With Quote
Old 02-02-2012, 05:17 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
there is nothing special with the 5 and 6 207. most people abroad pop them at the near 350whp point.
eg33GC is offline   Reply With Quote
Old 02-02-2012, 06:08 PM   #3
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Just to clarify
You want to know the stock boost is on an EJ207? Because your goal is 400hp and you want to know how significantly far from stock you are when you get your 400hp and blow the engine?
Isnt "unmolested" code for no upgraded internals?
parallel fuel rails
Upgraded fuel pump
AC delete
Rotated manifold
FMIC
Turbo timer
Upgraded radiator
Launch control
Open DP
Lite tune
TommyAtomic is offline   Reply With Quote
Old 02-03-2012, 10:27 AM   #4
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
If you consider factory forged pistons, crazy flowing heads and hot cams nothing special. Rods good for 350-400whp. Pistons are good for more if you dont det. IIRC stock boost is around 15-17psi. My car made 290whp stock and I ran low 12s with the vf28 at about 19psi. Car ran 11s with the vf22 but like all abused subys it finally spun a rod bearing.
If you want to turn up the boost on these engines you need better then 93 octane, The ign maps are too aggressive. Remember detonation will kill any engine in short time.
Scoobie Steve is offline   Reply With Quote
Old 02-04-2012, 01:49 AM   #5
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
peak stock boost should be 17psi, for all v3-6 STi
if you are expecting more than 350whp you will want to upgrade the rods. and as for any JDM import engine, its not a bad to tear it down and refresh the bearings with ACL race bearings, and ARP head studs if you'd like
elislider is offline   Reply With Quote
Old 02-05-2012, 03:04 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
can it be done? probblay
but its not the best place to start
rods/bearings/injectors(e85 or race gas)/engine management (standalone)/big turbo
starting with a 01+ ej205 would be easier and cheaper due to re-programmable ecu
Old 02-05-2012, 07:25 PM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
the rods and pistons are nothing special. not many v6 had big port heads.
Questions about STi 6 speed and rear diff. EarlQHan Service & Maintenance 3 06-22-2007 12:45 PM
Question about Version 6 heads. LiquidForce Built Motor Discussion 0 03-06-2007 09:26 PM
Question about willwood 6 pots Tex-WReX Texas Impreza Club Forum -- TXIC 7 12-03-2004 10:10 PM
question about version 6 into 2.5rs warehouse_motors Subaru Conversions 6 08-01-2004 04:02 PM
Question for all increasing boost levels Fin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-13-2002 03:56 AM
