Old 02-03-2012, 01:06 AM   #1
Oneh1tko
Member#: 237001
2004 Impreza WRX
Default 04 WRX Accessport and Manual BC?
My accessport will be arriving tomorrow and I just thought about the situation I'm in.
My car had a Perrin Manual Boost Controller installed before I bought it and it is currently at 17psi.
My question is will I have a problem with any of the maps I load onto it? If so i would prefer to just revert back to stock. Could anyone provide me with any steps on converting back to stock? I can't seem to find anything online.
Oneh1tko is offline   Reply With Quote
Old 02-03-2012, 04:43 PM   #2
Oneh1tko
Member#: 237001
2004 Impreza WRX
Anyone?
Old 02-03-2012, 08:10 PM   #3
Oneh1tko
Member#: 237001
2004 Impreza WRX
My accessport came in now I'm scared to put a map on my car lol could someone please point mme in the right direction.
Old 02-03-2012, 08:39 PM   #4
southstar01118
Member#: 294514
02 WRX
you should go on youtube it show you how to flash the cobb ap
southstar01118 is offline   Reply With Quote
Old 02-03-2012, 09:15 PM   #5
Oneh1tko
Member#: 237001
2004 Impreza WRX
I'm aware of how to flash it just not sure how safe it would be to use it with a manual boost controller. I read that I might have to adjust the wastegate duty cycle but that's about all the information I've been able to find...
Old 02-03-2012, 09:47 PM   #6
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Normally you shouldn't run a MBC with OTS AP maps, you should have everything the same as the map notes say as that is what the are best at running... Now... can you get away with a MBC set up to the proper Psi?... Maybe, depending on your fuel, your IAT, your knowledge, Your self control...
wrxdrvr is offline   Reply With Quote
Old 02-03-2012, 10:45 PM   #7
Oneh1tko
Member#: 237001
2004 Impreza WRX
My fuel 91 octane poopy California gas lol knowledge, trying to learn, self control enough to not want to damage my expensive engine.
If anyone has installed an aftermarket boost controller what exaclty was removed? I've seen a couple of diagrams but the boost solenoid showed in pictures doesn't match the bcs I've seen.
Old 02-04-2012, 10:36 AM   #8
Cobb Tuning
Member#: 4803
Hello. An aftermarket manual/electronic boost controller or boost controller solenoid should not be used with our off-the-shelf maps. You can certainly get a custom tune from a shop that uses our AccessTUNER software. But, if you are sticking with the off-the-shelf maps, we would suggest that you put it back to stock:
http://www.cobbtuning.com/info/?ID=3482
Bill
Cobb Tuning is online now   Reply With Quote
Old 02-04-2012, 12:41 PM   #9
Oneh1tko
Member#: 237001
2004 Impreza WRX
Thanks Cobb, I was hoping you guys would chime in!
04 WRX outrigger and rear subframe bushings Qs salvi Brakes, Steering & Suspension 3 02-06-2012 08:33 PM
FS: 04 WRX AccessPort and TurboXS RFL BOV Bankie Engine/Power/Exhaust 6 10-15-2007 02:28 PM
02-04 WRX UTEC, turboXS Manual BC ludboy87 NWIC Private Classifieds 1 03-06-2007 03:07 AM
AL: Gruppe-S V2 Header W/ JetHot and/or 04 WRX Accessport - Local pick-up preffered Deep_Inner Private 'For Sale' Classifieds 15 07-01-2006 05:55 PM
FS: Up-Pipe and Downpipe - 04 WRX Accessport skkang North West Impreza Club Forum -- NWIC 6 02-26-2005 02:19 AM
