Old 02-03-2012, 01:52 AM   #1
FabCruz
Member#: 299797
2012 STi Sedan
Default Stage1 +sf underboosting?
Just got the Cobb sf intake w box and on the stage1 +sf acn 91 map.
I currently am using the accessport to monitor my boost cause my defi hasn't come in yet.
on the map notes it says peak boost is 16psi. The accessport is reading 13.8-14psi going to 6500rpm 1st-3rd gear.
Just to make sure.. I do go on boost and not boost target on the ap to monitor right?
Only mods are sf intake and nameless axleback exhaust.
FabCruz is offline   Reply With Quote
Old 02-03-2012, 08:27 AM   #2
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Do some 3rd gear pulls and log the default parameters. Boost target is what the car ideally wants to hit and that is your compensated boost target, it is adjusted by intake temp, altitude. Boost is what you are actually hitting. TD boost error is the amount of lbs you are off from your target boost. I would log boost target, boost, and TD error to see what the car is doing.
snoopy_sti is offline   Reply With Quote
Low boost with Stage1+SF 93 map JordanM9 AccessPort 11 02-20-2012 07:18 AM
FS : IL: Cobb SF Intake SOLD aschmuck Engine/Power/Exhaust 1 02-01-2012 11:38 AM
2011 STI Stage 1+AEM vs Stage1+Cobb SF glamcem Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 47 12-04-2011 12:41 AM
Stage1+SF 93 not reaching ~17psi invaderzim AccessPort 34 11-11-2011 01:23 AM
COBB Tuning Stage1 and Stage2 AEM and SF Intake Maps for 2008+ WRX and STI Available! Cobb Tuning AccessPort 15 04-05-2011 11:54 PM
