Old 02-03-2012, 02:21 PM   #1
quoiasdaddy
Member#: 147711
2002 WRX/Stg 2
Default Stg 2 on a recovered ECU
I just got my ECU and new V2 AP back from Cobb. I had to send in my ECU to be recovered because when I tried to flash Stg 2 with my old V1 a bad battery caused it to get stuck and thus throwing all kinds of CELs and basically rendering the ECU useless. Anyway it is now fixed and ready to go back in my car. Once I put the ECU back in should I run the car stock for awhile before I flash to Stg 2? My only mods are a turboback that I recently had installed. MY car is an 02 WRX and I just don't want to cause any more problems. So my question is can I flash it right away or should I run it stock for a couple days before I flash it? I just don't want to mess anything up again so I want to be safe, any input would be greatly appreciated. Thanks,
quoiasdaddy is offline   Reply With Quote
Old 02-04-2012, 01:37 AM   #2
snoopy_sti
Member#: 164942
2015 Porsche Cayman
If you have a turbo back I would not wait and flash it stage 2 right away.
snoopy_sti is offline   Reply With Quote
Old 02-04-2012, 10:40 AM   #3
Cobb Tuning
Member#: 4803
Waiting to flash isn't going to make the process more or less reliable. You should reflash to the stage 2 mapping right away as you should not be running the stock mapping when you are at stage 2 as far as mods. That is assuming you fixed the original issue (bad car battery). If you have not fixed that issue, then I would not reflash until you have (drive very conservatively until then).
Bill
Old 02-06-2012, 09:57 AM   #4
quoiasdaddy
Member#: 147711
2002 WRX/Stg 2
I got a new battery and hooked up a trickle charger as backup and flashed it on Sat. I was so nervous but everything went fine so now Im happily at Stg 2. This new AP is so much better than my old one and it was much faster downloading the map to my ECU, can't wait to use the other features!
Question about Cobb stg 2 on 06 wrx... Dutchman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 10-31-2008 07:48 PM
Tackling Stg 2 on Saturday, any last warnings? richde Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-02-2005 04:08 PM
WTT: COBB STG 2 91 Reflashed ECU for Stock ECU FostersAFB Private 'For Sale' Classifieds 3 08-24-2004 05:52 PM
Cobb stg 2 ECU boost? waitandbleed92 Engine Management & Tuning 3 05-28-2003 12:26 AM
Does the Cobb stg 2 ecu come close to maxing out stock fuel limits? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-24-2003 11:43 PM
