Welcome to the North American Subaru Impreza Owners Club Wednesday April 16, 2014
Old 02-03-2012, 07:01 PM   #1
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Default accessport new install stage 1.... 22.9 psi
just installed stage 1 91 map. has been installed for about 12 hours. was data logging and went to the target boost screen. did a couple wot 1-2 pull and half of a 2-3 pull. was getting 16.8 max psi then got a 22.9 psi max spike in the target boost screen. in the datalog these boost numbers did not show up, but where on the ap screen. is this normal or should I be seeking help?
2011 wrx 5 door stock
spt catback
HeroCrank is offline   Reply With Quote
Old 02-03-2012, 07:08 PM   #2
juventus1983
Member#: 183534
06 wrx
wrb
doesnt sound normal. check the map notes...
take some data logs and or contact cobb
juventus1983 is offline   Reply With Quote
Old 02-04-2012, 01:41 AM   #3
snoopy8818
Member#: 164942
2013 WRX STI Limited
2007 WRX STI Limited
Log your target boost and your actual boost.
snoopy8818 is offline   Reply With Quote
Old 02-04-2012, 10:53 AM   #4
Cobb Tuning
Member#: 4803
spt catback
Target boost is what the engine control unit is targeting, not what you are actually hitting (which is determined by the "Boost" monitor on AccessPORT). Some of the maps have a bump in target boost (due to a specific compensation) in 1st gear below a certain speed to attempt to improve spool in first. You will never hit that boost target in 1st - just that it is a means for more aggressive response in 1st.
Bill
Cobb Tuning is online now   Reply With Quote
Old 02-04-2012, 11:17 AM   #5
HeroCrank
Member#: 301089
2011 WRX 5 door
TP stage 2
Bill
thanks for the response Bill, I feel much better now and will do some more datalogging. I was very nervous for a bit.
2.5 accessport users questions.. stage 1 and stage 2... labukas19 AccessPort 6 12-26-2008 09:22 AM
Just installed Stage 1 Accessport on '04 WRX mbakercad AccessPort 16 08-30-2006 07:29 PM
[autoX] slush5 @ new venue, Sun 1/22 everbruin Vancouver Impreza Club Forum -- VIC 0 01-19-2006 01:14 PM
accessport installed, stage 1 complete 03mbpREX Factory 2.5L Turbo Powertrain 8 01-18-2006 09:13 PM
cobb stage 1 15.4 psi kevin2.5rs Engine Management & Tuning 2 07-06-2005 06:57 AM
