Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 02-04-2012, 12:07 AM   #1
Willt23
Member#: 302333
2002 J&W auto/perfor
Default Jdm ej205 help needed
Just got in an 02/03 jdm ej 205 complete swap with tranny ecu and all for a great price. I plan on installing this into my usdm 2002 wrx I have done swaps before but with an usdm ej205 before I start the process is this a direct plug and play or is there any other things I need to know before installing this swap since its a jdm version ej205 any help would be appreciated
Thanks in advance
Willt23 is offline   Reply With Quote
Old 02-04-2012, 08:03 AM   #2
twinturbo_z
Member#: 211035
2002 Bugeye
Is it AVCS?
twinturbo_z is offline   Reply With Quote
Old 02-04-2012, 10:14 AM   #3
Willt23
Member#: 302333
I don't know yet she be here in a couple of days buy the seller didn't mention.
If it does have avcs all I got to do is wire it up and if it don't it's a straight plug and play?
Old 02-04-2012, 03:09 PM   #4
illmatic
Member#: 3536
2013 SWP BRZ Limited
2002/2003 AW/PSM WRX
^correct, might as well take advantage of the AVCS. I believe the 2001 GD WRX was the first year they offered AVCS in the EJ205. Where did you source your JDM EJ205?
DIY AVCS wiring:
http://forums.nasioc.com/forums/show....php?t=2118295
illmatic is offline   Reply With Quote
Old 02-05-2012, 09:10 AM   #5
Willt23
Member#: 302333
DIY AVCS wiring:
Thanks for the info.
If am using my USdm harness I don't have those avcs wires. And goingnto use the jdm ecu So do I have to buy the avcs wiring kit from ia performance
Old 06-10-2012, 07:55 PM   #6
my928s4
Member#: 158412
Where there any remains of the JDM harness on the motor? When I got mine they had the connectors and a few inch's of harness on the JDM motor.
You can re-purpose the TGV connections as the JDM motor with AVCS will not have them.
There is a nice PDF (D1 Motorsports) out there on the web with the details.
Chris
my928s4 is offline   Reply With Quote
Old 08-24-2012, 11:08 PM   #7
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Chris
JDM ej205 will have avcs and tgvs actually.
RS_to_WRX_swap is offline   Reply With Quote
Old 09-12-2012, 09:10 PM   #8
Willt23
Member#: 302333
thanks yeah it was avcs it was plug and play and i used the jdm ecu and all i did was buy the kit from ia performace and wired it up. the instructions was so straight foward and only took no more than 30 mins to install
Swapping jdm ej205 in to my USDM 2002 wrx NEED HELP! mrkevinchiu Built Motor Discussion 22 02-12-2015 12:55 PM
Retrofit Jdm Hid Bugeye Need some opinions!! forsakenforlife Electrical & Lighting 6 02-04-2012 10:56 AM
03 JDM STI: Help needed, see dyno charts csugden Engine Management & Tuning 0 09-13-2007 01:32 PM
JDM EJ205 education needed Chuck H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-12-2005 09:53 PM
black chrome jdm hid help needed wrxpooh Electrical & Lighting 1 02-20-2005 12:47 AM
