Old 02-04-2012, 05:28 PM   #1
srapchak
Member#: 270719
Default 06 STI engine n trans swap into 03 impreza outback?
im thinking about buying a 06 sti motor and tranny, it comes with the motor, trans, the ecu, dccd controller for tranny, trans mount, rear diff, drive shaft, all axels, Clutch and flywheel and shift link.
what else would i need to do to get this swp easy peasy. i kno it would probably need a rack n pin for the rear. and possibly a new suspension for it, but im not sure, all i want to know is what id be getting myself into by trying to swap all of this into a impreza outback sport!
i need everyones help
STI HELP NOW haha
srapchak is offline   Reply With Quote
Old 02-05-2012, 12:30 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
You will need the entire wiring harness from the STI and '05 or newer STI knuckles.
speedyHAM is offline   Reply With Quote
Old 02-05-2012, 01:46 PM   #3
srapchak
Member#: 270719
he has the wiring harness that i need. what about suspension wise could i get away with regular suspension on it. due to i just replaced it all before the engine and tranny started to go?
Old 03-17-2012, 10:23 AM   #4
mikeydrives1
Member#: 262117
2001 Forester
STi II type M
More or less.....
You can do an STi swap without swapping the knuckles. Go with a 2004 trans, and you can re-use your front axles, use a WRX 3.90 rear diff and driveshaft and you can retain use of your rear axles / hubs no problem.
With the 05 and up swaps, ive read many accounts of people doing Hybrid axle swaps. There is literally a dozen ways to do an STi drivetrain swap successfully and safely.
mikeydrives1 is offline   Reply With Quote
Old 03-17-2012, 02:15 PM   #5
Wannabe WRX
Member#: 130623
1998 Legacy L
Green
05-07, you would need the front axle seals and stubs and a 3.70 R160 rear diff. IIRC, the rear diff is from an 06-07 WRX.
Wannabe WRX is offline   Reply With Quote
ej20g from v4 sti swap into 96 impreza outback scooby kidd Pre-2002 Factory Turbo Powertrain 16 10-03-2010 03:45 AM
Will a 2003 Forester 2.5 be a direct swap into 2002 Impreza Outback Sport red civic standard Normally Aspirated Powertrain 0 03-23-2010 08:48 PM
how hard would a svx engine be to swap into an impreza? josh...just josh Subaru Conversions 17 09-06-2005 03:50 AM
sti swap into 97 impreza outback kaneda3 Subaru Conversions 6 02-06-2005 02:45 PM
jdm swap into an impreza outback sport pauljds Subaru Conversions 0 10-24-2004 12:23 AM
