Old 02-04-2012, 10:11 PM   #1
Vdubtype1
Member#: 297549
Default Build list
I am building a volkswagen type1 with a ej25 dohc this is a list of the parts I have for the car and a couple questions I hope to get to or near 400 whp. Keep in my I should have little less horsepower drop with not losing power threw driveshaft and other awd components. Not to concerned if I don't get it as long as it has solid long powerband
Haltech Ecu with avcs tuning
Oversized top mount
750cc injectors
Aftermarket oil cooler
Dual radiators from porsche boxsters
OKADA plasma direct ignition coils
Vf39 turbo
Custom fabricated aluminum intake manifold (to much unneeded stuff on factory manifold with amount of vacuum lines and clearance issues) it will has 2 1/4 inch runners with velocity stacks inside plenum. With fairly small plenum and long runners, since its not high revving and for quicker response it is still drive by wire
I was wondering what you guys would recommend for waste gate and turbo manifold pipe sizing exhaust will be three inch
Transmission is wrx 5mt with stage 2 clutch. It has a reversed drive. Ring and pinion and is shortened. I am looking into cosco 1.5 way LSD. I don't believe the transmission will be like glass since it will not have the shock force of a awd set up. and a 6 speed is way to big, also the weight is just over 2100 ibs 5 gears is enough
Would like to hear feedback I should be able to post pictures soon
Vdubtype1 is offline   Reply With Quote
Old 02-05-2012, 02:49 PM   #2
08STI_GT35R
Member#: 309001
08 STI 525WHP
You definitely need to keep this thread going with updates. I wanna see the progress.
08STI_GT35R is offline   Reply With Quote
Old 02-05-2012, 03:11 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
400 hp isn't going to happen with a vf-39
ej25 is it the ej255/257/25e/25d
your not starting with a N/A engine are you?
Old 02-05-2012, 10:53 PM   #4
Vdubtype1
Member#: 297549
It is a turbo engine, from sti. Which turbo do you recommend for a autocross application
Old 02-05-2012, 11:33 PM   #5
Vdubtype1
Member#: 297549
It is a 06 sti engine from a salvage wreck. I was just plaining on using the stock turbo but with the work that I am doing and have planned would a 18g be better off? since I do have big injectors and a good Ecu already purchased
Maybe I should looking into a few boost maps
I might look into running Meth. But would my injectors be to small?
Build List. Missing Anything? Suggestions? BimM3r Newbies & FAQs 15 02-25-2010 12:22 AM
Jeep build list and pics RallyeXpress Member's Car Gallery 6 09-16-2008 01:01 AM
My new Build list for my Legacy Turbo smh0101 Built Motor Discussion 16 06-12-2008 12:25 PM
98 RS head w/ 04 RS SB build list austenf740 Subaru Conversions 0 02-21-2007 02:37 PM
