Old 02-05-2012, 01:28 AM   #1
mattesonb
Member#: 139607
2011 WRX
DGM Wrapped Satin Black
Default 2011 wrx stage 1 acn91 data log assist - overboosting?
Hello,
I recently purchased an AP for my 2011 wrx hatch in los angeles california.
it is stock except for the Cobb quad tip exhaust, and is currently running the Stage1 ACN91 Octane map
I have attached a Data-log for a 3rd gear pull and as i have a limited experience i would love your professional opinion as to weather i need to adjust anything as it looks like i am hitting 15.36psi around 4500rpm.
I am wondering if i should move to the LWG map to keep boost lower or if i am within normal levels.
thank you.
mattesonb is offline   Reply With Quote
Old 02-05-2012, 12:51 PM   #2
kevosti
Member#: 269463
2012 WRX STi Sedan
I'm an amateur at reading these things myself, but I believe you're alright. You're not overboosting. Your TD Boost error is 10.5 papering to 0. This is due just to you going WOT at 2.5krpm and your car building the necessary boost.
Target Boost - Boost = TD Boost Error.
Someone please correct me if I'm wrong.
kevosti is offline   Reply With Quote
Old 02-06-2012, 01:35 PM   #3
mattesonb
Member#: 139607
2011 WRX
Bump!!
Old 02-06-2012, 08:31 PM   #4
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
are you getting a cel? an over boost issue will cause a po244 wastegate code to come up. if not i think you are overly paranoid. im pushing 22 psi through my vf52 at stage 3. ive only oveboosted 2 times. my tuner adjusted the wastegate duty cycles. it has not happened again.
424wrx is offline   Reply With Quote
Old 02-07-2012, 10:08 AM   #5
snoopy_sti
Member#: 164942
2015 Porsche Cayman
TD boost error = Target Boost +14.7psi minus barometric pressure subtracted from actual boost.
So if you were to log the boost target and barometric pressure and do this math that would equate to your TD Error that is in your log.
Your TD error looks fine, your not seeing any knock so your good.
snoopy_sti is offline   Reply With Quote
Old 02-07-2012, 10:36 AM   #6
Cobb Tuning
Member#: 4803
The boost target for the Stage 1 ACN map is 14.5 psi +/- about 1 psi. You are within this range and everything else in the log looks really good! You could try the LWG is you want to take the boost down a bit, but i don't see any need on your car to do that.
Ian
Old 02-09-2012, 02:25 PM   #7
mattesonb
Member#: 139607
2011 WRX
two more maps for reference
Old 02-10-2012, 07:51 AM   #8
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Your fine, enjoy! If you run the lower wastgage map your gonna fall short on boost.
Old 02-10-2012, 01:43 PM   #9
mattesonb
Member#: 139607
2011 WRX
Thanks for the info!
i'm amazing how much the map has smoothed out the powerband through all gears!
Old 02-10-2012, 07:36 PM   #10
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Get a pro tune, then you will see smooth! Big difference.
Datalog - 2011 WRX Stage 1 + SF Intake matt2WRX AccessPort 21 01-30-2012 11:06 AM
2011 WRX stage 1 mod path? matt325 Newbies & FAQs 31 11-18-2011 05:16 PM
2010 WRX Stage 1 knock issue? logs inside. JonnyD91 AccessPort 4 08-07-2011 08:16 PM
2011 WRX Stage 1 Boost Readings Rymantas AccessPort 3 08-02-2011 12:13 AM
Dyno Tune: Stock 2011 WRX Stage 1 KWIL Proven Power Bragging 68 07-25-2011 11:36 PM
