Old 05-20-2012, 03:07 PM   #1
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Default 2011 stage 2 OTS + SF
Would love for someone to look at these two runs i did today. Thanks in advance.
First Run:
https://docs.google.com/spreadsheet/...DhTbDRyYTFQaXc
Second run:
https://docs.google.com/spreadsheet/...Up3RzJ0OXY2ZVE
Mods are listed here:
http://forums.nasioc.com/forums/show....php?t=2338194
bluemax189 is offline   Reply With Quote
Old 05-20-2012, 04:18 PM   #2
ppayer38
Member#: 234407
04 Self-tooned
STi
Minor fine knock but seems to go away when you hit 100% throttle...
Boost is barely 16(not sure what it is suppose to be) if it helps try switching between the high WGDC and low WGDC maps to see if boost comes up to Target.
Keep an eye on that fine knock and log some part throttle stuff and regular cruising to see if it is happening all the time(the way I see it any knock is bad knock)
ppayer38 is offline   Reply With Quote
Old 05-20-2012, 05:27 PM   #3
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
the knock is weird and im not sure about why its there at partial barely any throttle and not present at all during a WOT pull. I think target boost is 18ish but im not wanting to switch to the HWG unless maybe someone could explain if i should be worried about this partial knock. Seems to be happen randomly in 3rd and 4th gear on low rpms(watched ap for about a 1/2hour drive). Anyone else?
Old 05-20-2012, 06:16 PM   #4
ppayer38
Member#: 234407
04 Self-tooned
STi
Could be a loose part or just something like that causing it... Fine knock can be anything from a bad tune to phantom knock(guessing that's what yours is) You say randum so in assuming it is off and on and not continuous? See if you can fine exactly when it happen like certain load, rpm, throttle, etc and if you can more than likely phantom knock or a loose bolt/bracket
Old 05-20-2012, 06:35 PM   #5
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
ill check out the engine bay to see if i can find anything loose. The only common thing is its always at lower rpms.
Old 05-20-2012, 08:22 PM   #6
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
some more logs...... Just changed to the HWG stage 2+sf and did some drives. Didnt really have space for a 3rd gear pull on this stretch of road since it wasnt level but that shouldnt matter for the partial throttle issues. Anyways, looks like for whatever reason my issues are gone!
https://docs.google.com/spreadsheet/...3psc1B2MmhmbEE
and
https://docs.google.com/spreadsheet/...GdqUkI5dllDSlE
Old 05-20-2012, 09:50 PM   #7
hutch959
Member#: 267463
need to see a 3rd or 4th gear full pull please.
hutch959 is offline   Reply With Quote
Old 05-20-2012, 09:59 PM   #8
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
I'll try to get one tomorrow for you guys on the new map
Old 05-21-2012, 08:51 AM   #9
Cobb Tuning
Member#: 4803
The fine knock learning in the first set of logs is just low load noise - which is normal. As hutch959 stated, you want to get a 4th gear WOT run (if you can do so safely) on the new HWG map.
Bill
Old 05-21-2012, 09:08 AM   #10
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
i got a 3rg gear pull but only to 5k. 4th gear pulls for me on the 5 speed just take me a little faster than i want to go.
https://docs.google.com/spreadsheet/...VQ2VEFlYzhYRGc
Old 05-21-2012, 09:47 AM   #11
Cobb Tuning
Member#: 4803
Sorry - for some reason I thought this was an STi. You definitely want to do 3rd gear WOT run for 5-spd tranny. Log looks fine, but when you can do so safely, try to get a longer run.
Bill
Old 05-21-2012, 09:52 AM   #12
ppayer38
Member#: 234407
04 Self-tooned
STi
Agreed nothing to worry about here just go enjoy the car...
Happy Boosting!
Old 05-21-2012, 11:19 AM   #13
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
It is false knock from the transmission which Cobb has stated but if u experience fine knock or feed back knock at wot then I would be concern
trev762 is offline   Reply With Quote
Old 05-21-2012, 11:38 AM   #14
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
the knock is solved now and i see im now hitting boost targets. I saw the boost error was 2+ on the standard. This HWG map has been alot better.
Old 05-24-2012, 09:37 PM   #15
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Old 05-24-2012, 10:04 PM   #16
hutch959
Member#: 267463
looks good to me.
Old 05-25-2012, 10:06 AM   #17
Cobb Tuning
Member#: 4803
Lookin' good. Have fun!
Bill
Old 05-25-2012, 07:08 PM   #18
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
Thanks everyone!
2011 wrx stage 2 cobb sf arod15 Open Source Reflashes 7 04-07-2012 02:04 AM
Cobb Stage 2 OTS map vs. Perrin Stage 2 OTS map liljon350 AccessPort 4 08-09-2009 09:01 AM
Target boost on Stage 2 OTS Flash? Superorb Commercial ECU Reflashes 11 06-20-2007 11:12 AM
12.6 @ 107.98 04 STI Cobb Stage 2 OTS Deranged Proven Power Bragging 30 05-16-2007 04:20 PM
safe running cobb stage 2 OTS map with catless tbe + megan headers? spooln407 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-19-2006 06:41 PM
