Old 10-18-2012, 11:04 PM   #51
SP2Flip
Member#: 63932
2006 Tribeca B9
Glad you got it running, it's always the easy things that get you! The ring has to be really close to the front of the key cylinder, too far back and it won't pick up. In the past I have had to use a small zip tie to take some of the slack out of the ring so that it fits snugly around the cylinder. You should also be able to hear the 555uw module click when you initiate the remote start sequence. Also the placement of the key inside the module makes a difference. Good luck...almost there!
SP2Flip is offline   Reply With Quote
Old 10-19-2012, 11:43 AM   #52
zpeedd3mon
Member#: 332170
whoop whoop!! So excited, its starting up perfectly! Couple of things I changed/fixed:
Clutch bypass - I didn't realize there were two different switches hooked up to the clutch and I had mistakenly hooked up the wrong pair. They were showing voltage and would switch when the clutch is engaged but it was the wrong plug (lower plug, smaller gauge wire). Got that hooked up correctly to the relay and that worked perfectly!
Question: I know everyone likes to solder for good connections but do you normally solder relays? I've done it both ways (solder vs connectors) but wondered what the pros out there do.
Immobilizer bypass: relay wasn't getting the message from the blue wire off the remote start for some reason. Manual says its a 200ma (-) output but the 556uw doesn't say anything about how many MA to send so I decided to snag the orange 500ma (-) of the viper and it worked perfectly!
Got everything taped and tied up nice and pretty and now am on to finishing up my stereo. Already have my pioneer in dash in but gotta hook up all the ebrake *cough* wire. Then in goes the 6 channel amp and sub. Stoked to be getting the car all dialed in!
The only thing that seems a bit odd to me is that when I remote start the car it unlocks prior to starting but doesn't re-lock after the start sequence has occurred. Is this normal? Not a big deal since I can just hit the lock again after but am curious if there is a way to eliminate an extra button push.
Thanks again guys and for all your help and patience here. It was greatly appreciated and I hope that others who go down this road can get problems solved by reading from my mistakes!
zpeedd3mon is offline   Reply With Quote
Old 10-19-2012, 12:55 PM   #53
SP2Flip
Member#: 63932
2006 Tribeca B9
Glad you got it sorted brotha. If you tied the disarm wire
(black/green) to the unlock/disarm to the flcan, cut it. Then test, should be good to go.
Old 10-19-2012, 01:49 PM   #54
zpeedd3mon
Member#: 332170
I went the D2D direction and so none of those inputs/outputs are wired to the flcan.
Old 10-19-2012, 02:02 PM   #55
SP2Flip
Member#: 63932
2006 Tribeca B9
Ahh gotcha, thought you switched over to the hardwire.
Old 10-19-2012, 02:19 PM   #56
zpeedd3mon
Member#: 332170
No, I was going to as a last resort because the FLCAN wasn't seeing the ground while starting but that was resolved before it went that far. Hmm...
Old 10-19-2012, 03:07 PM   #57
zpeedd3mon
Member#: 332170
ok, so there is the option in the programming:
OEM ALARM DISARM OUTPUT -
1. with lock
2. with unlock
3. with remote start only.
Would this be a solution?
Old 10-19-2012, 04:24 PM   #58
zpeedd3mon
Member#: 332170
not sure what the deal was before but it seems to be operating fine now. Probably user error. Thanks all!
Old 10-20-2012, 10:45 PM   #59
kevosti
Member#: 269463
2012 WRX STi Sedan
Anyone have a suggestion for how to hook up a back up battery to a compustar CM6000? Does it have its own charging unit? If so, can I just hook something like this (http://www.ebay.com/itm/12V-1-3AH-SL...item5ae85a1529) up to the +12VDC battery terminal and (-) ground battery terminal?
kevosti is offline   Reply With Quote
Old 10-20-2012, 10:51 PM   #60
SP2Flip
Member#: 63932
2006 Tribeca B9
This is what you need kev http://www.ebay.com/itm/DEI-520t-Bac...item20cbeadbfc. It just charges of your alternator and when main power is disconnected the alarm would then revert to the back up battery.
Old 10-20-2012, 11:48 PM   #61
kevosti
Member#: 269463
2012 WRX STi Sedan
I was considering using the 520T, but my local installer just told me to buy a lead acid battery and connect it to connector two of the schematic below:
http://www.google.com/url?sa=t&rct=j...SMlJhg&cad=rja
The unfortunate thing is I don't have much confidence in my local installer, that is why I am tackling the install myself. I looked into the 520T, but I heard that the factory battery is not all that great. If I wanted to use the charging circuit from 520T with a different battery, how would I go about hooking it up on the compustar side?
http://www.mobiletraxx.com/id131.html
Can I wire as below?
520T side to CM6000
(+) Constant Power 12V Input -> Connector 2 Pin 1
(-) Instant Trigger Input -> Connector 2 Pin 2
Old 10-21-2012, 08:58 AM   #62
claythrow
Member#: 283663
2004 STI
Root Beer
I didn't read through your entire post but this is almost certainly a stick shift right?
520T side to CM6000
claythrow is offline   Reply With Quote
Old 10-21-2012, 09:46 AM   #63
kevosti
Member#: 269463
2012 WRX STi Sedan
Yes it is a stick shift
Old 10-22-2012, 03:30 PM   #64
zpeedd3mon
Member#: 332170
loving the remote start. Warming up this morning and it tells me how nice it is in the car! fun stuff.
Old 10-22-2012, 04:09 PM   #65
SP2Flip
Member#: 63932
2006 Tribeca B9
1. with lock
2. with unlock
Hmmm, try changing the settings to see what happens. But I am unsure if that would work as the remote start and the flcan communicate with Data. It is strange that the flcan is causing your car to unlock upon remote start.
Old 10-22-2012, 04:14 PM   #66
zpeedd3mon
Member#: 332170
Not quite sure what was going on with it. I'm guessing I was a little tired and didn't realize what exactly was going on therefore I spoke too soon. Its all working properly and up to speed now. Thanks for all your input and expertise!
Old 10-22-2012, 04:16 PM   #67
SP2Flip
Member#: 63932
2006 Tribeca B9
520T side to CM6000
Hi Kev, sorry about the late response. By the diagram you attached it looks like the Compustar has a charging circuit built into the brain. I would have to look at the instructions to see if there are any stipulations on what type of battery that you can use. If your installer suggested that battery then you should be ok with it. Just have to make sure that the built in charging circuit can support the back up battery that you will be using. Good luck...
Old 10-22-2012, 04:17 PM   #68
SP2Flip
Member#: 63932
2006 Tribeca B9
Anytime Buddy, glad you got that thing going!
Old 10-22-2012, 10:47 PM   #69
kevosti
Member#: 269463
2012 WRX STi Sedan
Flip, thanks for the tip. I looked at the manual and it says that the 2nd connector has a charging circuit built in. I bought a battery and a 506T glass break sensor to finish off my list of to buy items.
I have a pretty nice excel spreadsheet of a 901SS/CM6000 Compustar to 2008-2012 STi interconnecting wiring list that I made. I'm going to start wiring up this week/weekend and will post it up when I get everything working.
I started some of the install today with installing the siren, hood pin, and antenna. Stage 2 will be connecting the BLADE-AL and Compustar and getting the door lock interface to work.
For the main 12V feed into the alarm, there are two 16AWG wires with two 30A wires. I was considering connecting these two wires together, then connecting it to the 12V constant white wire on the ignition connector on the car. Is this a bad idea or would this be acceptable? I'm concerned that the fuse upstream is rated less than 60A total, but I'm not sure if the constant 12V white wire on the ignition connector is high current or not. My only thought to fix this problem is to directly tap off the battery, relocate the fuses, and then extend the wiring. Anyone know what the 12V constant white wire on the ignition connector is rated for on the (08-12) STi?
Old 10-22-2012, 11:50 PM   #70
SP2Flip
Member#: 63932
2006 Tribeca B9
Hi Kev, I believe the main 12v wire in the ignition harness is rated at 50A. There should be two 12v wires, both white. Just utilize both of these wires and you will be good.Take it easy!
Old 10-23-2012, 09:18 PM   #71
KenBeanNet
Member#: 335407
Hey Guys. Hate to be the noob of the thread, but I am here. I just bought a 2013 STI. Got everything but my remote starter in. I bought a Viper 4704V and found it doesn't have security, so I just bought a Viper 5904. I would like to not do a bypass, and only allow remote start when the system is setup for remote start. (Brake > EBrake > Break release > Leave Car > etc).
Do I need additional hardware for me to get this functional? What limitations will I have when going to attack this project with just the Viper unit and nothing else? My father is very good with cars and will help with the installation but I want to ensure I have all the required parts before hand! Thanks!
KenBeanNet is offline   Reply With Quote
Old 10-24-2012, 01:13 AM   #72
jegomes
Member#: 303039
2006 WRX
You will need a bypass... no way around it. You're best off getting 2 flcans or 1 and a 556u however with the latter you will need a spare key to stash in the dash..
jegomes is offline   Reply With Quote
Old 10-24-2012, 01:13 AM   #73
jegomes
Member#: 303039
2006 WRX
Also you will need a relay if the vehicle is a manual.. for your clutch bypass
Old 10-24-2012, 09:48 AM   #74
KenBeanNet
Member#: 335407
With the clutch bypass (It is a manual), I still don't want it to start unless I do the required setup EBrake and such. That won't override that.
Any suggestions of good companies/pricing found online that I can buy from for the required parts? I have a 2013 STI Limited.
Old 10-24-2012, 10:06 AM   #75
jegomes
Member#: 303039
2006 WRX
I can't help you on where to get the parts as I work at a shop where they are only an arms reach away.. but we charge retail, I know you can get them elsewhere cheaper.. but there is no way around the parts, you need them for the unit to function.. as far as how you set the car up for remote start, that's up to you.
***liteSPEC 08+ WRX STI HB Titanium Exhaust System GROUP BUY Starting at $750*** liteSPEC Vendor 'Group Buy' Classifieds 177 02-20-2013 07:51 PM
FS : MN: Perrin Cold Air Intake 08+ WRX/STI and spare foam filter. hotrodrex MWSOC Private Classifieds 2 02-04-2012 10:07 AM
Invidia Q300 Catback for 08 STI, AEM CAI for 08 WRX/STI, and Element Tuning for 02+! WorldOne NWIC Vendor Classifieds 9 03-25-2011 11:11 AM
2004 STi Remote Start, Keyless entry inop,alarm activates Murphdog Car Audio, Video & Security 5 12-30-2009 10:48 AM
vf48, 08 STi TMIC, LGT/08+ WRX/STI downpipe, 08 injectors vhalin Engine/Power/Exhaust 23 12-09-2008 10:07 PM
