Old 02-06-2012, 05:51 PM   #1
KentuckyFriedSTI
Member#: 287038
2006 Impreza WRX STI
World Rally Blue
Default Cobb AP will not power in car.
Two weeks ago I put my car back into stock mode. Since then I have not been able to power on my cobb ap to put my 93 hwg tune back on. I purchased a new dongle, 3 new cables and nothing worked. I can connect it to the PC just fine and access all my maps, firmware etc. Has anyone experienced anything similar to this? The only thing that changed on my car was a new battery. The AP was not connected at the time of change. Battery is a red top optima, old one was yellow top. I have this horrible gut feeling something is up with my ecu or the usb port on the ap is dead.
KentuckyFriedSTI is offline   Reply With Quote
Old 02-06-2012, 05:54 PM   #2
KentuckyFriedSTI
Member#: 287038
World Rally Blue
Oh and yes my car starts and run, I didn't ever experience any flash freezes or power cutting off in the middle of a base flash.
Old 02-06-2012, 06:48 PM   #3
subeb
Member#: 246550
2003 impreza wrx
black
Talk to Cobb. There the only ones that will really know what's up
subeb is offline   Reply With Quote
Old 02-07-2012, 07:23 AM   #4
SpongeBobSquarePants
Member#: 296048
2011 STI
Blurple
Check your fuses. OBD diagnostic plug should have a fuse
SpongeBobSquarePants is offline   Reply With Quote
Old 02-07-2012, 08:02 AM   #5
KentuckyFriedSTI
Member#: 287038
World Rally Blue
I will look at that first thing after work.
Old 02-07-2012, 10:30 AM   #6
Cobb Tuning
Member#: 4803
It's possible you might have a dead AP screen. Give us a call (866-922-3059) or an email ([email protected]) with your full name and phone number, and we can set up a repair ticket for you!
Ian
Cobb Tuning is online now   Reply With Quote
Old 02-08-2012, 08:09 AM   #7
KentuckyFriedSTI
Member#: 287038
World Rally Blue
The screen powers on fine when connecting it to the PC. I checked all the fuses under the drivers side and under the hood. Everything looks fine. I am going up to autozone later today and try to see if they can pull code off the OBD port. Will post the results.
Old 02-08-2012, 05:00 PM   #8
Cobb Tuning
Member#: 4803
If the USB port to the car is broken, the screen will not power up in the car. Luckily, this is something we can repair so you don't have to buy a whole new AP. If the OBDII code reader works and you narrow down the issue, please give us a call or email and we can set up a repair ticket for you.
Ian
Old 02-08-2012, 05:33 PM   #9
KentuckyFriedSTI
Member#: 287038
World Rally Blue
Actually it isnt the AP at all. I went over to a friend house and his OBD2 reader would not power on my OBD2 port. I also drove to autozone just to double check and have them also check. Nothing. I have pulled every fuse I could find under the driver side and under the hood. I dont know what is wrong if I have some sort of physical connection issue or what. My OBD2 port was fine two weeks ago when I put a base flash on my car.
Cobb AP V2 not Synching with AP Manager SUBYDOODIE AccessPort 8 09-10-2011 03:37 AM
Car will not move in any gear WRteXan Transmission (AT/MT) & Driveline 2 01-07-2010 08:46 AM
Help: Cobb AP will not work with my car silvsteve AccessPort 3 02-04-2007 05:23 PM
AccessPort will not power up v0od0o AccessPort 3 04-28-2006 12:55 AM
UTEC will not connect in car spazegun2213 Engine Management & Tuning 6 11-21-2005 12:23 AM
