Old 02-06-2012, 10:50 PM   #1
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Default It's Alive!!
The block was built by [email protected] it's a copy of junior2jz block but with stock crank.
This is the original block/crank to my 05 STi for the record.
Darton Sleeves, pinned.
Manley I beam turbo tuff rods
Custom Manley 8.5:1 pistons coated skirts, Factory 99.5mm Bore
acl race bearings, pinned mains.
11mm oil pump
id2000
pt6266
awaiting walbro e85 fuel pump release.
aem ems, the good stuff!
GSC S2/Beehive GSC valve springs retainers.
I'll get more pics of the port work soon. they are 98% done.
spoolinsti05 is offline   Reply With Quote
Old 02-06-2012, 10:59 PM   #2
gotsugg
Member#: 204014
02 02 WRB Bugeye
GTX3582 front mount turbo
What turbo set-up are you planning on running?
gotsugg is offline   Reply With Quote
Old 02-06-2012, 11:09 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
Are those custom manley or standard manley 8.5?
Nuke209 is offline   Reply With Quote
Old 02-06-2012, 11:47 PM   #4
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Think Jr said they are custom.
Turbo is going to be a PTE6266
Old 02-07-2012, 04:02 PM   #5
ArSoN9
Member#: 285777
2004 STi-
awesome looking engine...I wish I had the money to put sleeves in my new block..but Im also going Manley pistons and rods,
Why stick with the standard bore size on the pistons if you are going with pinned sleeves? I would think overboring them to 100mm atleast might not be a bad idea since that setup so tough it wouldnt miss the .5 mm. Or does the extra size throw off the bore/stroke? I guess this gives you future cutting room if you have something go wrong and cylinder walls are damaged.
What fuel are you planning to run on the 6266PTE? How much boost are you planning to run? What A/R is the exhaust housing?
What crank are you using in this build, and how was it balanced?
What type of bearings did you use?
Did you also pin the mains, like Jrs bottom-end?
Thanks in advance for ur response!! again awesome setup!
ArSoN9 is offline   Reply With Quote
Old 02-07-2012, 06:37 PM   #6
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Thanks Man. The bore is stock for future rebuilds.
the crank is factory original to the car. [email protected] Trix balanced it so idk.
Turbo 6266 cea thanks to Junior2jz for the hook up on that. A/r 1.06 I think at this point I dont care lol I just wanna drive the car.
It's Been three years to long between saving what money I could and spending it on parts.
Yes The mains are also pinned I'm more excited then when I bought the car in 05. Lol
Old 03-03-2012, 03:52 PM   #7
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Soon will be moving over to the proven power section. Just waiting on Jr for the pt6266 and id2000 then i can situate everything else.
Old 03-03-2012, 04:00 PM   #8
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Another update.
Old 03-12-2012, 02:21 PM   #9
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
updated
Old 05-07-2012, 06:57 PM   #10
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Old 05-07-2012, 07:59 PM   #11
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Congrats! 10 AFR?
binjoau is offline   Reply With Quote
Old 05-07-2012, 10:52 PM   #12
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Originally Posted by binjoau View Post
Congrats! 10 AFR?
Thanks man it's been a long journey, Lot's of help from Jr, Turbotrix friends family for support with my habit. LOL
Sorry car wasn't fully warmed up plus I think I had some old race gas left in the fuel line it smelt really good
Old 05-08-2012, 11:42 AM   #13
BlaxTrax
Member#: 139989
C6 05 Vette 11 WRX
00 Impreza, 03 WRX
Congrats bro... Wish you woulda called me so I could come by for the initial start. Was gonna bring my HD camera.
BlaxTrax is offline   Reply With Quote
Old 05-08-2012, 11:57 AM   #14
izergfx
Member#: 308012
C# & Java Devs***
PM me***
Very nice build, congrats!
Are the deck pins steel or Al?
izergfx is offline   Reply With Quote
Old 05-08-2012, 01:38 PM   #15
CatfaceType-R
Member#: 81102
ewang achieved!
nice build
CatfaceType-R is offline   Reply With Quote
Old 05-08-2012, 03:10 PM   #16
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
I was stuck in the moment man sorry. LOL
Thanks, I think they are aluminum. Jr said they are the newer style IIRC.
Thank's
Originally Posted by soon2bblackongold View Post
ewang achieved!
nice build
Old 05-08-2012, 04:00 PM   #17
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
you better have Jr. lean that out a bit or you are going to wash done the cylinders and the rings will not seat properly and then you will have excessive blowby.
john 1badSTI is offline   Reply With Quote
Old 05-09-2012, 12:53 AM   #18
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Yea it's been taken care of that was just the initial start up. engine wasn't warmed up yet got a oil leak small on the avcs line. Once I fix that I'll check the afr again.
Old 05-09-2012, 03:51 PM   #19
john 1badSTI
Member#: 77470
ccol be careful those avcs lines are kinda fragile.Get it broke in and go have some fun,and I figured you would remedy that richness.
Old 05-10-2012, 04:43 AM   #20
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Yea second time I bent it by accident. it happened when i was porting the heads oh well. I'll be getting a line from p&l i think.
Yea it ran with that richness for 15 seconds i'm itching to get it going again an piss off my neighbor.
Old 05-10-2012, 07:51 AM   #21
bbong
Member#: 141258
2006 Evo 9 GSR
GG
Finally Billy, the car is running, now lets see it drive. Congrats.
bbong is offline   Reply With Quote
Old 05-10-2012, 03:02 PM   #22
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Thanks Tom, Soon waiting for the fittings for the avcs line. Hey text me sent you a PM.
Old 07-07-2012, 09:55 PM   #23
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Just wanted to comment the car's tuned and Jr thanks for the awesome tune. I'll have a video soon of some driving.
And start up witch Jr did an amazing job doing. With the cobb speed density and pump gas id2000 stock fuel pressure it starts up first crank. And idle's at a nice 13.6-14 afr.
Soon I will be re tuning the car.
Old 07-08-2012, 02:44 AM   #24
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
what kind of boost are you running?
Any kind of date in minf for final tune?
Congrats!! She is def a beast!!!
Old 07-08-2012, 01:18 PM   #25
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
14lbs it's only seen it about 5 times so far 60 miles on the build rev limit is 5200 haven't seen that yet.
Not 100% sure yet gotta sell my outback wagon. $$
Thanks man I can't wait to see the power band on this car I have a feeling it's gonna be from 4k rpm's to 8k once done. but will see.
FS/FT : CA: Darton sleeved built ej257 blkwagon Engine/Power/Exhaust 12 06-11-2011 06:26 PM
ej257 pinned sleeves GoofyLGT Built Motor Discussion 51 03-19-2011 04:40 PM
EJ257 Darton dry sleeve engine break-in procedure mtcs Built Motor Discussion 3 08-07-2010 09:59 AM
FS: Built EJ257 shortblock! 99.5 CP Pistons, Eagle Rods, ACL Main and Rod Bearings 06TRDude Engine/Power/Exhaust 12 12-22-2009 09:24 PM
04 sti ej257, darton sleeves, 03 ej20 suby1man03 Engine/Power/Exhaust 26 11-26-2009 06:07 PM
