Old 02-07-2012, 08:38 AM   #1
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Default To billet crank or to not billet crank, that is the question
Time has come to start building the spare race engine for the car a friend and I are doing. (The one I made the 400lph Walbro post about) The engine in the car currently has a BC 83mm stroker kit in it unsleeved. We assume at 650whp its only a matter of time before she explodes which is OK. He wants to push it, and we have at least doubles if not triples of every part.
The spare motor is getting sent out to get sleeved as soon as the pistons get here
I ordered the JE Billet FSR pistons with coated skirts and domes (balllllin) and a set of Carrillo Pro H rods to compliment. Nicest lightweight rotating assembly, that can handle the abuse that this car will see. Really broke the bank on that one though, lets see if it pays off. This combo is 508 grams, or 1.12lbs lighter than the standard Manley/CP piston + Turbo Tuff rod combo. That is a lot less weight to be swinging around in an engine.
The only thing we are on the fence about now is crank selection. I am torn between using a nitride coated 2011, which I know is a good unit, but unsure of its HP limits, or a K1 or Manley 79mm crank. The money for a $3500 Cosworth isn't in the budget.
If this motor was going to make 500, 550, or 600 I wouldn't think twice and go for the OEM. I want this thing to be able to do a real 750 on a good day. I have no problem admitting that HP level is virgin territory for me with a Subaru.
Planning to rev it on the drag strip to 7500-8000 with a shimmed 11mm pump or the high flow Cosworth (which is probably overkill).
So I am looking for some real world racing advice here.
Japan made? OEM crank vs China made billet crank?
No Limit Motorsport is offline   Reply With Quote
Old 02-07-2012, 11:01 AM   #2
MartinSTi05
Member#: 145145
2006 wrx STi
I spun a 83mm cross drilled BC 2.7 stroker to 8500 routinely with their heavy rods, and non lightened CP pistons. I used a shimmed/ ported 10mm pump. When the motor was torn down the bearings looked great.
MartinSTi05 is offline   Reply With Quote
Old 02-07-2012, 11:32 AM   #3
CatfaceType-R
Member#: 81102
Wait, didn't that crank break though, martin????
Carmi
CatfaceType-R is offline   Reply With Quote
Old 02-07-2012, 11:35 AM   #4
reid-o
Member#: 103631
2004 STI
I'd think that the forged crank would be stronger. I'd move to the billet cranks for the improved oiling and weight.
reid-o is offline   Reply With Quote
Old 02-07-2012, 01:06 PM   #5
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Are the newer 08+ STI "black nitrided cranks" forged or cast?
I'm glad to have the old 07 STI crank.
berdugo is offline   Reply With Quote
Old 02-07-2012, 06:36 PM   #6
MartinSTi05
Member#: 145145
2006 wrx STi
Carmi
Yes it did. However it failed due to heat treat and tiny fillet radii. Those problems have been adressed by that manufacturer and are not present in others' cranks such as Manley. I am just saying that with proper prep of the oiling system I was able to hit 8500 at the dragstrip and the bearings looked good upon teardown.
Old 02-07-2012, 07:18 PM   #7
jamal
Member#: 71875
98 Legacy GT
my wheels fit
this is JC's time attack car on a BC 83mm crank, BC I-beams, and JE FSR pistons:
Broke an H-beam going to 8500, kept this under 8200.
Worked great until a sleeve cracked (stock with a deck plate) and hydrolocked the motor.
jamal is offline   Reply With Quote
Old 02-07-2012, 08:08 PM   #8
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
You need to consider the upgraded oil passages on the billet cranks, not just strength
mick_the_ginge is offline   Reply With Quote
Old 02-07-2012, 08:38 PM   #9
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
I realize that as a positive, in addition to the strength. This is why I wanted to do it. My deliberation comes from the parts possibly having manufacturing issues.
My fears are of the journals being improperly shaped, sized different, the crank not being "true", and having to do work to get the bearing clearances right
Either way I guess we will find out. I bit the bullet this afternoon and ordered a Manley 79mm.
I guess we will find out soon enough. Ill post up with the results.
Old 02-07-2012, 09:09 PM   #10
MartinSTi05
Member#: 145145
2006 wrx STi
Mick speaks the truth. Straight shot oiling passages alone can be worth the price of admission when it comes to stick stroke billet cranks.
Old 02-07-2012, 09:26 PM   #11
ASF Machine
Member#: 236349
1993 Impreza
OD Green
Although I've never been happy with how the Manley cranks balance....
The last couple I've mic'ed were toleranced fairly well at max variation of .0001" and the journals were round.
The Manley option saves us from having to deal with the ******** at Pankl.
Centrifugal force isn't your oiling system's friend at bigger RPM, so straight shot oiling is going to help.
ASF Machine is offline   Reply With Quote
Old 12-15-2015, 10:25 PM   #12
KinkSti
Member#: 414850
2004 WRX STI
Which H beam you break?
KinkSti is offline   Reply With Quote
Old 12-16-2015, 07:43 AM   #13
rtv900
Member#: 428511
2016 STI
My only input is that a China made billet crank will be junk.
It won't be the material they say it is, it may look nice though.
rtv900 is offline   Reply With Quote
Old 12-16-2015, 01:28 PM   #14
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Like polishing a turd kinda?
Does crower make a crank?
I think CJ runs a Manley.
spoolinsti05 is offline   Reply With Quote
Old 12-16-2015, 06:22 PM   #15
DisoDisp
Member#: 187648
2007 WRX
The manley cranks are chinese forgings... I run one regardless...
But the Arrow unit is of a different calibre.
DisoDisp is offline   Reply With Quote
Old 12-16-2015, 10:52 PM   #16
user1029
Member#: 57064
2008 STi IAG built
HTA86, Meth, 272s, Cos IM
Stock nitride or heat treated STi crank good for 750-800whp ($350). Manley billet crank beyond that ($1300)
user1029 is online now   Reply With Quote
Old 12-23-2015, 09:30 AM   #17
Placide Doubai
Member#: 383646
2000 Impreza GF8 WRX
(2 cars)
Indeed... 3 micron mm of discrepancy between each journal...
Placide Doubai is offline   Reply With Quote
Old 12-23-2015, 09:32 AM   #18
Placide Doubai
Member#: 383646
(2 cars)
Fantastic piece from Arrow that 79mm crankshaft. For sure.
Old 12-23-2015, 12:50 PM   #19
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
To bad Callie's doesn't make one for us.
Old 12-23-2015, 01:56 PM   #20
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
I wonder if they make the cosworth unit, mine looks identical
Hyper is offline   Reply With Quote
Old 12-23-2015, 06:31 PM   #21
Placide Doubai
Member#: 383646
(2 cars)
Yes, they do...
Old 12-23-2015, 07:27 PM   #22
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
How well are they balanced?
Old 12-24-2015, 09:03 AM   #23
Placide Doubai
Member#: 383646
(2 cars)
Like that:
Old 12-24-2015, 06:11 PM   #24
Paul
Member#: 56203
00 RSTI Coupe
Sorry for my ignorance but is that saying its 19grams out of balance?
Old 12-24-2015, 07:44 PM   #25
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
They do. A guy up in Charlotte was posting pictures a week ago of his new Callie's crank.
subydude is offline   Reply With Quote
Too fatty or not too fatty: That is the question The Motel Fella Off-Topic 17 09-06-2011 02:53 PM
Teh WING or NOT teh WING: that is the question SuBK North West Impreza Club Forum -- NWIC 60 11-30-2007 03:18 AM
dual port, or not dual port, that is the question. rufracer Normally Aspirated Powertrain 3 07-23-2007 08:01 PM
to access port or to not access port. that is the question DarkShadow Texas Impreza Club Forum -- TXIC 10 07-15-2004 02:47 AM
MY00-01 2.5RS or MY02 2.5RS, to buy or not to buy, that is the question Fujiwara General Community 7 04-24-2002 08:54 PM
