Old 01-28-2012, 02:03 PM   #1
Bluedunn
Member#: 304430
2005 Impreza RS
Dark Blue
Default Idle Noise After Timing Belt Replacement
Hi-
First, I'm new to the forum and have done some searching on this subject, but the posts I found seem, through the thread, get turned into a conversation that digresses away from the OP. Anyway, I have a 2005 Standard 2.5 RS wagon - nice little car.
So with that in mind, I had a local garage (trusted...dealership in this area is notoriously crooked) replace my timing belt, tensioner, idler pulleys, thermostat, and water-pump last week. I've had the car back for about 3 days and I just noticed today, that while the car is idling, I'm hearing a knocking noise coming from the engine somewhere - I don't recall this sound before bringing it in for the work. When I rev up the engine a bit, it goes away, but when the car sits for a few minutes, it comes back.
I've already had it back in since the change for a defective tensioner, which the garage replaced free of charge. Now I plan on calling them first thing Monday morning to bring it in so they can have a look, but in the meantime, any idea what this likely to be?
Thanks for any help!
-S
Bluedunn is offline   Reply With Quote
Old 01-31-2012, 10:26 PM   #2
onetruth1130
Member#: 308689
1998 forester s
black
could be a couple of different things. subaru motors for the most part have a different sound than regular 4 cyls do. you might be just extra sensitive to any noise post the repair. but it could be from maybe an exhaust leak to valve damage. if the car runs fine and isnt idling strange then you might be ok, but id def say have the machanic check it out. better be safe than sorry. great car and best of luck! let us know how it goes
onetruth1130 is offline   Reply With Quote
Old 02-01-2012, 10:02 AM   #3
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
They could have messed up the timing.
Also did your belt break or did you just replace it?
ManualOverAuto is offline   Reply With Quote
Old 02-07-2012, 03:15 PM   #4
JayDavies15
Member#: 298486
2006 Impreza WRX
Did you figure out what it was? I'm having the same problem in my 2006 Impreza WRX. The noise goes away at about 2000 rpms. I work at a garage and during lunch tomorrow I'm going to check it out. Im hoping its just a loose belt so I dont have to replace the tensioner.
JayDavies15 is offline   Reply With Quote
Oil Leak - After Timing Belt Replacement ReD-DaWg-OnE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-16-2011 07:47 PM
Ticking Noise after Timing Belt Change: VID mrbigshot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-23-2009 12:05 PM
Cooling issue after timing belt replacement. wasp642 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-16-2009 06:48 PM
Check engine light 150 miles after having water pump/timing belt replaced Dural Service & Maintenance 1 06-29-2008 05:21 PM
Timing Belt Replacement = Steering Noise? Anderson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-25-2004 11:50 AM
