Old 02-07-2012, 01:51 PM   #1
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Default Steam coming out of radiator cap. Please help
I am having a weird issue with my Mitshimoto aluminum radiator. I have maybe only 2000 miles on this radiator. I just installed my rotated turbo kit on my 2002 WRX. My radiator cap is steaming around the neck. Its a 1.3 bar (19 lbs) cap. My overflow tank is working fine and fills up if need be. I don't understand how this cap can already be bad unless I am having a pressure problem. I replaced the thermostat with an OEM one and also replaced the cap with a new one. Still steams. I took the cap off and the steam was coming out the top of the radiator pretty bad. The only thing left to do is get the radiator flushed. I do not overheat at all. My fan also comes on at 204 degree F like it always has. Im stumped now Any help is appreciated. Thank you
emsmap is offline   Reply With Quote
Old 02-07-2012, 04:05 PM   #2
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
I know you said that you replaced the radiator cap, but I recall reading that the Mishimoto ones are crap. If you can get an oem one, that may solve your issue. On a side note, is your upper turbo coolant tank full? Is your entire system full of coolant? If you aren't overheating, it either sounds like a pressure buildup (perhaps not enought coolant) or the radiator cap is weak. Good luck.
WRXSD is offline   Reply With Quote
Old 02-07-2012, 05:21 PM   #3
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
I actually deleted the upper coolant tank since i went with a oil only cooled turbo. The whole system is full. Even in the coolant over flow tank its steaming up a bit. Ill have to get myself a stock cap to see if that helps.
Old 02-07-2012, 08:50 PM   #4
whtscoobplk
Member#: 195400
2004 WRX STi
Just had a problem with this happening, i had a cap that was on my car for less than 8 months go bad and actually lost a bit of coolant while driving. Got a new one from NAPA and all is good. Even new parts break sometimes, get a new one and drive on.
whtscoobplk is offline   Reply With Quote
Old 02-08-2012, 05:38 PM   #5
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Just replaced with new cap from advance auto parts and still steaming. Next is a compression test i suppose. This sucks
Old 02-08-2012, 05:41 PM   #6
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Just replaced the cap with a new one from advance auto parts and its still steaming. I suppose the next thing to do is a compression test. This sucks
Old 02-08-2012, 09:20 PM   #7
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
Is there a crack in the top of the radiator neck? Get a loaner cooling system pressure tester from pep boys ($130'ish deposit) and pump it up, see what's up.
*Attach to turbo (upper)reservoir.
z is offline   Reply With Quote
Old 02-09-2012, 10:26 AM   #8
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Im going to put my reservoir back on today to see if air is getting trapped in the system. Hoping this will make a difference
Old 03-05-2012, 10:48 PM   #9
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
No motor No Trans :-(
Did you ever figure out the problem w/ the rad cap? Having the same issue and trouble shooting now.
Thanx
Mario
marios03wrx is offline   Reply With Quote
Old 03-06-2012, 12:27 PM   #10
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Yep! Air was in the system. I installed my upper coolant tank back on and burped the system. All is well
Old 03-06-2012, 06:09 PM   #11
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
Cool, thanx for the reply. Back to work i go...
Mario
Steam spitting out of exhaust! Help! wrx54 Newbies & FAQs 3 04-01-2011 02:21 PM
HELP. purging air out of radiator DCrally43 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-22-2010 01:29 AM
hmmm...smoke/steam coming out of radiator...help? 98subyrezaRS Normally Aspirated Powertrain 11 02-28-2006 03:05 PM
help smoke coming out of hood scoop ? phat pat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-04-2004 03:43 PM
Smoke/Steam coming out of vents?? HonduhEater Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-24-2001 06:03 PM
