Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC > RMIC Vendor Classifieds
Old 02-07-2012, 03:38 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default Just Released DEFi 60mm Racer Gauges! Boost, Pressure, Temp, EGT, and Volt!
The Defi Racer Series Gauges are quick-responsive and high-accurate analog gauges. Boost, pressure, temperature, exhaust temperature, and volt gauges are available. They are 60mm in size and the lighting is available in blue, red or white.
A Stepping motor provides smooth operation. The Racer gauges are illuminated using high-brightness LEDs. Self-diagnostics function monitors both sensor disconnection and short-circuiting during the startup sequence.
The Face features a full 270 degrees sweep dial provides ultimate visibility. The Defi Racer Gauge does not require the Defi-Link Control Unit II for use, and cannot be used in conjunction with it. The red triangle of the regular position bezel can be used as a warning indicator and others. A mounting bracket and instrument case is provided with the gauge.
Imperial or Metric
Red, White, or Blue
Boost, E.G.T. (Exhaust Gas Temp), Pressure, Temperature, Voltage
214.20
Boost/Turbo In Metric or Imperial
__________________
RallySport Direct is offline   Reply With Quote
Old 02-07-2012, 03:39 PM   #2
RallySport Direct
Member#: 33174
We are Open Late!
__________________
Old 02-07-2012, 03:39 PM   #3
RallySport Direct
Member#: 33174
We are Open Late!
__________________
Old 02-07-2012, 03:40 PM   #4
RallySport Direct
Member#: 33174
We are Open Late!
__________________
Old 02-07-2012, 03:41 PM   #5
RallySport Direct
Member#: 33174
We are Open Late!
Voltage
135.90
RICK APPROVED AND IN STOCK!
Also don’t Forget all orders over 200 get free shipping in the lower 48 states!
__________________
FS : DEFI red racer gauges boost and pressure lunch7 Interior/Dressup/Audio & Security 17 01-01-2012 04:53 PM
FS : Defi 60mm BF gauges with pod (boost, EGT, oil pressure) meat_WRX Interior/Dressup/Audio & Security 4 11-17-2011 01:27 PM
FS : Defi 60mm BF gauges with pod (boost, EGT, oil pressure) thbalance NESIC Private Classifieds 9 10-12-2011 03:38 PM
FS: MD Defi BF wht imp boost,oil temp,egt w/link &pod -AND STi UTEC w/3bar map sensor SinistiR MAIC Private Classifieds 12 02-20-2007 05:01 PM
