Old 02-07-2012, 04:13 PM   #1
wrx19687
Member#: 274306
03 wrx
Default jdm v8 transmission in a 03 wrx
Hey Guys,I need help with this swap. I have everything to do the swap.I was looking at the wiring and I'm not sure how to wire it up. The 6 pin harness doesn't plug into anything. Its located right beside the slave cylinder. My 03 harness has 2 harnesses. 1 is the 02 sensor with plugs in the jdm harness. Then I have a 3 wired harness that I'm not sure where it goes either.
wrx19687 is offline   Reply With Quote
Old 02-08-2012, 10:43 PM   #2
wrx19687
Member#: 274306
03 wrx
I figured out the 6 pin harness. 2 wires go to the neutral switch,2 wires go to the reverse switch and the other two are for the dccd. Which I'm not hooking up right now. Transmission is in. Just need 4 front brembo caliper bolts and put the exhaust back on.
Old 02-09-2012, 02:29 AM   #3
jhenry1983
Member#: 269361
2006 wrx
03wrx Rallycar
sweet man . Just a heads up when you end up firing it up and get a flashing check engine light its from your IAT sensor under your throttle body on the drivers side. IT needs to be unplugged. The 03 wrx harness uses the IAT sensor in next to the MAF sensor ( like they do on all 02-07 usdm subarus ) But in japan they use the IAT sensor in the throttle body for things like automatic TMIC sprayer. and it only happens if you use a 02-03 wiring harness in your swap.
So if you get that check engine light you know what it is. also there will be no code with the flashing cel
jhenry1983 is offline   Reply With Quote
Old 02-09-2012, 08:54 AM   #4
wrx19687
Member#: 274306
03 wrx
sweet thanks
95 JDM WRX / STI Transmission in my 03 US WRX? kungfoochris Transmission (AT/MT) & Driveline 29 05-02-2011 07:20 PM
Metal bits in transmission fluid of 03 WRX WRX in STX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-26-2010 07:38 AM
V8 shortblock with V6 Heads in an 03 wrx DraconisWRX Subaru Conversions 7 02-03-2009 02:15 AM
04/05 WRX transmission in an 03. What's needed? EJ1 Transmission (AT/MT) & Driveline 6 12-17-2007 09:47 PM
JDM V8 manifold on a 03 WRX? Cautionjump Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-09-2007 09:32 PM
