Old 02-07-2012, 11:02 PM   #1
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Default Datalog Review please
2006 wrx tr 74000 miles. Spt cat back and stage1 93 mtv 300 map. No other mods. Car runs ok but has lost alot of power. Seems to be knock from what I can tell. Any help is appreciated. Flashed it last week.
https://docs.google.com/spreadsheet/...kd3hwc0E#gid=0
Chris-pee is offline   Reply With Quote
Old 02-07-2012, 11:35 PM   #2
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
You have to set the permissions to "public" in order for us to see your log.
2Fast4U1DAY is offline   Reply With Quote
Old 02-07-2012, 11:43 PM   #3
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Done! Sorry about that.
Old 02-08-2012, 12:29 AM   #4
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Knock all over the place in that log. And even during wot runs. Try flashing the 91 octane map and see if the knock can be reproduced on a less aggressive tune with 93 octane fuel...
Old 02-08-2012, 01:54 AM   #5
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Log your knock sum and see if it is actually occurring when you see it in the fine knock learn. Take your oil cap off with the car at idle hot and see if smoke is coming out of it. Also check to make sure your knock sensor is not loose.
snoopy_sti is offline   Reply With Quote
Old 02-08-2012, 06:47 AM   #6
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Well last night I reset the ECU and reflashed the same stage1 93 octane map. This time no knock, does it take the ECM time to adjust after a reflash to look for certain issiues? Here is a partial third gear pull after reflash.
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
Old 02-08-2012, 06:49 AM   #7
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Log it under normal driving? I Will remove the cap and check this morning when I get to work.
Old 02-08-2012, 06:50 AM   #8
Chris-pee
Member#: 279168
2006 WRX TR stage 2
I Will try this as well. I did dump a few gallons of gas in it after work from a station I have never used. Could bad gas cause this?
Old 02-08-2012, 09:09 AM   #9
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
DO NOT LOG KNOCK SUM. Extremely poor indicator of an issue. The knock sensor being loose is another extremely long shot...
Old 02-08-2012, 09:10 AM   #10
Chris-pee
Member#: 279168
2006 WRX TR stage 2
The motor has never been touched, Don't think the sensor is loose.
Old 02-08-2012, 09:14 AM   #11
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Here is a lengthy log from this morning after reflash last night. Seems to be quite a few events here as well. Also I seem to be noticing some overboosting but it was about 45 degrees out this morning.
Line 343 shows 16.78 psi!
Old 02-08-2012, 09:15 AM   #12
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Redo your WOT run from around 2500 to near redline if you can do so safely. Also try to start the log before you mash the throttle for the run.
Once the DAM reaches one, the only thing left for the ECU to make adjustments are fuel trims, and pulling timing if it sees knock.
Old 02-08-2012, 09:17 AM   #13
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Yes bad gas can cause issues. Thus why I told you to try out the 91 map with 93 octane fuel...
Old 02-08-2012, 09:18 AM   #14
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Didnt get much before 2200 rpm but this is pretty close to redline. From this morning.
Old 02-08-2012, 09:20 AM   #15
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
There is just too much junk in that log. It makes is a PITA to try to decipher what's going on during the run because you keep lifting out of the pull.
Old 02-08-2012, 09:21 AM   #16
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Can't see this one set the permissions to public please
Old 02-08-2012, 09:24 AM   #17
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Fixed! Thanks for the help btw.
Old 02-08-2012, 09:36 AM   #18
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
That log looked MUCH better. No knock. Try another run later today and post it up. Also I forgot to ask what car is this on, so I can go look at the map notes on COBB's website
Old 02-08-2012, 09:43 AM   #19
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Its on a 2006 wrx tr . Map is stage 1 93 mtv300. Ill log another on my lunch break, thanks.
Old 02-08-2012, 11:21 AM   #20
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Well I went to look at the map notes, and my phones stupid, and won't let me see them. But anyway, what I can recall from memory is the target boost level is 15.2 psi +/-.7 and boost cut is 17.xx psi at sea level.
The boost control system looks good. That spike is nothing to worry about, I have the same theing in some of my logs. I will have to take another look at the A/F tables and see if I see any extreme corrections, that might indicate a problem. Can you do me a favor and log the A/f tables on the next log you take, I only see the one?
Old 02-08-2012, 11:30 AM   #21
Chris-pee
Member#: 279168
2006 WRX TR stage 2
This is taken from the notes on the Cobb site.
Boost Targets: ~13.5psi +/- 0.7psi peak boost pressure tapering down
to ~9psi, depending on vehicle and conditions. If your vehicle is
not achieving or exceeding the boost targets, you may need to
mechanically adjust your boost control system, please refer to this
document “How Subaru’s Factory Boost Control System Works v1.X” for
instructions.
I am not sure if I should be worried about that spike or not on line 9 on the last log or not, 16psi seemed pretty high. It was fairly cold out this morning and I did do a reflash last night. I heard it takes a little time for everything to get settled.
Old 02-08-2012, 12:03 PM   #22
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Well at least that's one less thing I can worry about lol. Which tables, the learning or the Correction? Thanks!
Old 02-08-2012, 02:13 PM   #23
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Both lol.
Old 02-08-2012, 02:29 PM   #24
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
instructions.
are you sure you are looking at the right map notes? I have an 06 WRX limited and those notes look like stage 1... Target boost for stage 2 for 06-07's should be 15.2 +/- .7 psi. I wouldn't worry about the spike... I have the same spike in my logs and Bill from COBB confirmed there shouldn't he any issues with that small spike. Its when it never stops building boost, and goes over the boost cut limit or over boosts and stays up there when you should he concerned.
Old 02-08-2012, 02:32 PM   #25
Chris-pee
Member#: 279168
2006 WRX TR stage 2
Pretty sure, I am working with stage 1 , not 2.
Review Please - x2 Datalogs 2011 STI CTSSM2011STI Engine Management & Tuning 5 02-09-2012 03:31 PM
Datalog reviews How-to tmcgraw Engine Management & Tuning 4 08-15-2011 09:41 AM
Datalog Review olazy AccessPort 7 06-09-2011 12:41 PM
06 wrx 6speed vf39 gs bcs datalog review please help?? wrxcbr6rr Open Source Reflashes 9 11-03-2009 03:46 PM
AP Stg2 HWG 04 WRX Datalog. Help please? scoooby04 AccessPort 8 07-03-2006 10:47 PM
