Old 02-08-2012, 11:14 AM   #1
yman
Member#: 199051
06 Subaru
Default 02 Forester EJ205 Swap questions,clockspring compatibility and also hood scoop advice
[left]Will a clock spring (roll connector) from an 02-03 wrx work in my SF forester?
Also, has anybody installed a hoodscoop on a car that has never had a scoop? Any advice?
My Forester is up and running with the exception of a broken and botched ribbon repair on the clockspring, a slight leak making it run lean, and in need of a hood scoop installation.
yman is offline   Reply With Quote
Old 02-08-2012, 11:19 AM   #2
eg33GC
Member#: 206851
99 V4
EJ20K RS
220ps ej20g
sell it. you cant use usdm wrx wiring with it
eg33GC is offline   Reply With Quote
Old 02-08-2012, 11:59 AM   #3
yman
Member#: 199051
06 Subaru
Next question.
Can I put USDM Forester XT heads on an EJ205 2.0 block, put the USDM intake manifold/tgv's on and it will work?
Old 02-09-2012, 06:47 AM   #4
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
No you can't use the EJ255/257 heads on a EJ205.
Marnix is offline   Reply With Quote
Old 02-09-2012, 06:48 AM   #5
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Oh and the manifold in the pictures has been 'worked on' as the EJ20G idle control valve flange has been removed and welded up.
Old 02-09-2012, 07:20 PM   #6
Freeze Plug
Member#: 234613
looks like an ej20g of some sort. i recently used that block (jdm closed deck) with usdm ej205 heads and ej20g jdm headgaskets. runs like a champ!
Freeze Plug is offline   Reply With Quote
Old 02-09-2012, 08:17 PM   #7
suberdave
Member#: 101865
88 GL-10 STi
however this is an open deck EJ20G from an automatic car.
-=Suberdave=-
suberdave.com
suberdave is offline   Reply With Quote
Old 02-10-2012, 09:00 AM   #8
GEE-OTTO
Member#: 201277
2008 Legacy
Not that the EJ20g is terrible or anything but that EJ20 is a phase 1 engine. It would make your life loads easier if you went with a phase 2 engine i.e. EJ205, EJ255 stay away from those EJ20(letter) blocks. That engine probably came out of a BC/BJ Legacy.
GEE-OTTO is offline   Reply With Quote
Old 02-10-2012, 09:56 AM   #9
driftingrotary
Member#: 234715
2003 wrx
charcoal
I'm surprise they had coil packs in this phase 1 motor. Sure it ain't jdm?
driftingrotary is offline   Reply With Quote
Old 02-10-2012, 11:27 PM   #10
yman
Member#: 199051
06 Subaru
I'm pretty sure its JDM pulled from a 93-96 wrx wagon automatic. it looks like it is in great shape though, I wish you could see it. The timing belt still feels new, everything is super clean, I just need to get it sold asap.
Old 04-18-2012, 12:58 AM   #11
yman
Member#: 199051
06 Subaru
So I ended up doing the swap, I've still got some plugs that are unaccounted for (and also the CEL is on, and the airbag light is on. Also fighting my clutch problems, I think the slave cylinder either needs to be replaced or bled.
Old 04-18-2012, 01:01 AM   #12
yman
Member#: 199051
06 Subaru
Under the dash, driver side.
Under the dash driver side
Near the center console, driver side.
Engine bay:
Turn signals dont turn on either.
Old 05-14-2012, 08:35 PM   #13
yman
Member#: 199051
06 Subaru
So it runs and drive's a lot better, clutch issues got figured out mostly and now it's down to just a few more little things.
What is this and what does it do (2007 WRX) kcpaz Subaru Conversions 4 09-09-2010 01:56 AM
What is this, and what does it do? Karas Newbies & FAQs 10 08-25-2009 08:45 PM
while installing my up pipe i did something bad. what is it and what should i do Yakshii Factory 2.0L Turbo Powertrain 4 06-15-2008 01:13 AM
what is this and what does it do? Russ77 Factory 2.0L Turbo Powertrain 5 09-22-2005 01:00 AM
('93-'01) what is this and what does it do? shimstock Impreza Forum 4 04-10-2001 09:53 AM
Message Board Statistics All times are GMT -4. The time now is 09:34 AM.
