Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 03-03-2012, 07:25 PM   #26
Overland04
Member#: 293311
2011 Impreza WRX
Laguna Seca Blue
Originally Posted by BigRob74
another great write up jason, what happened to the process west TMIC? are you planing an e85 tune?
Thanks Rob!!
The Top Mount is doing awesome, I'm working on an install write up for it so it's been on and off the car lately. I'll be done soon...
The e85 tune is coming on April 7th, I can't wait!!!
Overland04 is offline   Reply With Quote
Old 03-03-2012, 09:03 PM   #27
BigRob74
Member#: 305107
2012 wrx
360/386 E85
Originally Posted by Overland04 View Post
Thanks Rob!!
im confused, the process mount was uninstalled and the factory tmic was for the inj install?
BigRob74 is offline   Reply With Quote
Old 03-03-2012, 09:18 PM   #28
Overland04
Member#: 293311
2011 Impreza WRX
Laguna Seca Blue
Oh, haha...
I purchased the PW top mount and installed it right after I did the injectors. The problem was that after I did the injector install I was so anxious and impatient about finishing that I put the top mount on without taking pictures.
I wanted to do a full write up on the top mount so I had to uninstall it, put the factory one back on, take pictures and reinstall the PW... Kind of a silly move but I really like making complete write ups.
So the PW is back on but I haven't had time to finish editing the pictures and post them.
Old 03-04-2012, 08:36 AM   #29
BigRob74
Member#: 305107
2012 wrx
360/386 E85
lol, gotcha! get those PW pics and thread up! i am looking to get the IC as well. where did you get it from?
Old 03-04-2012, 09:55 AM   #30
Overland04
Member#: 293311
2011 Impreza WRX
Laguna Seca Blue
Hey Rob, I got it form Rally Sport Direct... I get 10% off coupons all the time so it's always cheaper to go there.
Old 03-04-2012, 05:51 PM   #31
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
once i had the injectors reinstalled i go to start the car up and nothing.
then i realize the car is drive by wire and needs a special sequence of key play to intiate the Dbw system.
it fired up yesterday no sweat.
today i go out to take her around the block and try to start the car up and i get nothing. car is cranking but no spark.
so i perform the same sequence as yesterday and i get nothing.
the one thing i notice is that the fuel pump is not turning on right before i try to crank the motor. any thoughts?
topguneagle1 is offline   Reply With Quote
Old 03-04-2012, 09:17 PM   #32
BigRob74
Member#: 305107
2012 wrx
360/386 E85
so whats needed for the e85 tune? just the injectors and fuel pump right? curious to see what it does on the dyno!
Old 03-04-2012, 09:21 PM   #33
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
ok so after taking all day of trying to figure out what's going on, i've narrowed it down to an issue with the fuel pump.
after i reset the dbw system, i am turning the key to the on condition but not cranking the car over.
i do not hear the DW300 fuel pump kicking on .
so i disconnect everything and try again. no fuel pump. i can definitly hear the throttle body turn on and the check engine light is on.
but the fuel pump is not priming the system.
i even disconnected the battery, opened the fuel cap, and disconnected one of the fuel hoses from the fuel pump assembly, to my surprise no fuel came out, indicating that the system is not pressurized.
what's weird is that i was having this same issue yesterday and after resettting the dbw system the car fired right up and it even idles for about 2-3 minutes before i shut it off.
i can confirm that the fuel pump relay is clicking on. so i'm pretty much sure that its something with the fuel pump.
it is a dw300, i have a 2000RS with a 2007 full swap, wiring and all.
Old 03-04-2012, 10:16 PM   #34
Overland04
Member#: 293311
2011 Impreza WRX
Laguna Seca Blue
Hey Rob,
Yupp, bigger fuel pump, injectors and a new tune. The 850's will be maxed out with the stock VF-52 on e85. You need around a third more fuel to run flex fuel then standard 93 octane.
If and when I go to a bigger turbo, the 850's will have to come out and 1000 - 1300's are going to be needed.
Old 03-05-2012, 10:44 AM   #35
DeatschWerks
Member#: 87358
PM'd you, topgun.
DeatschWerks is offline   Reply With Quote
Old 03-19-2012, 05:26 PM   #36
BigRob74
Member#: 305107
2012 wrx
360/386 E85
bumping this back up for some questions. once the car is dyno tuned on 93 and e85, what happens if you come to a point that you can only get 93 octane? there will be 2 or 3 gallons of e85 in the tank, and mixing it with 93, what could happen?
Old 03-19-2012, 05:35 PM   #37
JordenP
Member#: 305041
2013 STOCK WRXSDN
Well, you have both an e85 and 93 oct map loaded on the AP. If he has a few gallons of e85 in the tank, but only has access to 93 oct, you switch maps. Running the 93oct map with a little bit of e85 diluted in there wont hurt anything, just a slight increase in octane. However running an e85 map on 93 would be a lot more harmful to the motor. With higher octane you're running more boost, timing, fuel. If you run a higher octane map with lesser fuel, high likely hood detonated will occur cause engine to go boom.
JordenP is offline   Reply With Quote
Old 03-19-2012, 05:45 PM   #38
Overland04
Member#: 293311
2011 Impreza WRX
Laguna Seca Blue
Yeah, and I also plan to stay out of boost while running on mixed fuels as a last resort...
I'll barely use e85, but when I do I plan on draining the tank and vise versa with 93 oct.
I'm double checking with EFI now to get their opinion too.
Old 03-19-2012, 05:51 PM   #39
BigRob74
Member#: 305107
2012 wrx
360/386 E85
curious what they say jason, they gave me a price for fuel pump, inject install and 2 separate maps for 1800 bux
Old 06-03-2012, 09:02 PM   #40
VitorBelfort041
Member#: 177568
2000 2.5 RS
BRP
Wanted to add that for the 3rd bolt on the driver side shield bracket (the one on the back of the block, closest to the driver) I managed to do it all by feel. I couldn't even see the bolt, but I found it with my fingers and didn't have to remove the TGV connector or motor.
VitorBelfort041 is offline   Reply With Quote
Old 06-03-2012, 11:10 PM   #41
bugeye sti
Member#: 186691
2011 sti
I did the same thing but on my 11 sti I did have to remove the passenger front tgv to remove the bracket.
bugeye sti is offline   Reply With Quote
Old 07-18-2012, 03:43 AM   #42
daszooo
Member#: 263942
Jason,
thank you for the detail oriented write-up. I was just looking for spark plug R&R, but I stumbled onto a win-win thread. My future plans on my 11 STI is E85. By reading this entire thread I came away with foresight. Just getting ready to do a compression test @ 20k to determine my next step in the tune process, why not read/change plugs at the same time.
Regards,
Jason
daszooo is offline   Reply With Quote
Old 07-18-2012, 07:44 AM   #43
Overland04
Member#: 293311
2011 Impreza WRX
Laguna Seca Blue
Originally Posted by daszooo View Post
Jason,
Regards,
Jason
Glad you found the thread Jason, it was a lot of work for just changing simple injectors but at the end it was worth having the extra head room in the fuel system for e85 or a bigger turbo.
Cheers!
Old 07-19-2012, 12:28 AM   #44
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
By far the best tech write up I have seen. Well done sir.
smeerone is offline   Reply With Quote
Old 11-07-2012, 02:47 PM   #45
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
Great writeup! I did a few things differently though on the passenger side. First off, I purchased Deauschwerks injectors which are taller than stock injectors. By loosening the bolt holding the fuel lines, I was able to get the stock injectors out, but unable to get the new, taller injectors in. So I had to figure out how to get the bolt completely out. I removed the TGV (pretty easy compared to the driver's side) and then loosed that oil line by removing that 17mm bolt (in bottom right of the picture below). There were 2 little copper washers that you need to make sure you don't lose. After loosening that up, I was able to get that bolt out. I put the aftermarket injectors in at that point. Since the injectors were taller, I had to space the fuel rail, which then wouldn't allow me to insert that fuel line back in. I don't see much of a point of that fuel line bolt as long as the fuel rail is bolted down securely.
Buzzed Trucks is offline   Reply With Quote
Old 11-07-2012, 03:19 PM   #46
Tripintaz
Member#: 245218
2013 STI Limited
Which DW Injectors did you use? I thought the DW injectors used stock cores which would mean the height of the injectors are the same.
Tripintaz is offline   Reply With Quote
Old 11-07-2012, 03:35 PM   #47
DeatschWerks
Member#: 87358
The 850cc, 1000cc, and 1300cc top-feed injectors are a little taller than stock.
If the injectors are installed with the o-rings and seals we package with the injectors, no spacers are necessary for the fuel rail.
Old 11-07-2012, 07:21 PM   #48
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
I bought them off a guy in the classified section. They were brand new. Maybe he didn't include the o-rings from when he initially purchased them, but the o-rings on the injectors are the ones that they came with. As you can see in the picture, the DW's are much taller than the stocks. I'm not sure if this was right, or if he sent me injectors meant for another car. There was no way I wasn't going to run these injectors without fuel rail spacers. I ran a 7mm spacer which was perfect. No leaks but the injectors can still spin.
EDIT: Tripintaz, the ones I received had Denso cores
Picture is kind of blurry, sorry.
Old 11-12-2012, 11:18 AM   #49
DeatschWerks
Member#: 87358
Hey Buzzed,
Those are the correct cores for the 850, 1000, 1300cc sizes.
Old 11-12-2012, 06:02 PM   #50
Buzzed Trucks
Member#: 316128
2012 WRX Hatch
Hey Buzzed,
Well the injectors work great, I am very happy with them. But like I said, there was no way I wasn't going to run spacers. A 7mm spacer worked perfect for me.
FS: DW 850cc Injectors, HyperFlow TMIC TurboWRX32 MAIC Private Classifieds 11 08-05-2009 05:03 PM
NJ:FS -Takata harness , STi TMIC , DW 850cc injectors ,Mines lip ,Defi gauges + MORE! DanTheMan23 Tri-State Area Private Classifieds 191 06-02-2009 02:23 PM
WTB:(MO) Spearco TMIC for 06 sti, DW 850cc injectors stidriver31 Private 'Wanted' Classifieds 1 04-18-2009 08:49 PM
VF43 turbo, STI TMIC, DW 850cc injectors Drac9 Engine/Power/Exhaust 26 04-12-2009 01:54 PM
TX: BRAND NEW ATP GT3076R, Perrin 3" inlet DW 850cc injectors ownnij Engine/Power/Exhaust 6 12-29-2008 01:55 AM
