Old 02-08-2012, 09:58 PM   #1
JohnJW
Member#: 304172
Default Boost spike than surge.
So I don't normally post as I usually search or find a way to figure stuff out myself, but I need help on this one.
I've owned my car (2002 WRX Wagon 5mt) for about a 6 weeks now and have worked on it more than I drive it.
Car currently has a Cobb AP, Cobb SF intake, after maf hose, Perrin inlet, Samco charge air hoses, tgv's deleted along with cats deleted.
So my problem is that the boost spikes at first and continues to surge back and forth. Sometimes it happens and sometimes its fine. I've logged boost spikes up to 19.6psi regularly. Today though, I've had enough. Pulling a mild hill I had it in 5th gear and had it at about half throttle. I would consistantly surge from about .5bar to above 1.1 bar. I could make it do it anytime. This will happen in lower gears but happens much quicker. Sometimes it pegs 1.1 bar and stays there till boost taper near redline.
So what I've done to correct this issue is replacement of every pcv hose, vacuum line, boost control solenoid, and vacuum t. I've smoked the intake tract numerous times with no leaks showing. All new oem parts.
When it does happen, I swear I can almost hear the bypass valve venting, or something similar.
It also seams better when I reflash the ecu, but gets worse the longer I go on a fresh tune. My DAM stays around 15-16 and everything else looks good.
I would be so happy if someone can give me a reasonable direction. My next step is to tape my phone to my hood and record my wastegate actuator. lol
JohnJW is offline   Reply With Quote
Old 02-08-2012, 11:51 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I would put in a 1/8 or slightly less ID in-line connector in the vacuum line between the T from the turbo to the BC solenoid to restrict airflow out of the wastegate...
wrxdrvr is offline   Reply With Quote
Old 02-09-2012, 01:08 AM   #3
JohnJW
Member#: 304172
So another thing to add is that the car has done it since I've owned it and along with the mods I have done. From stock to the way it is now. I would like to think that there is a way to fix this with oem part replacement.
I don't agree with modding a control system to fix it. Normal WRX's don't do this, and they don't have a 1/8 inch or smaller wastegate signal line.
Old 02-09-2012, 01:38 AM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
The OEM vac lines from the T to BC solenoid do have that in-line restrictor, I'm guessing it's not there now...
Old 02-09-2012, 10:22 AM   #5
JohnJW
Member#: 304172
No, its there, I purchased a new T with the pill included from Subaru. Also the lines to the bcs have connectors in them to go to a larger hose. The ports on the bcs are larger then the ports on the wastegate actuator and turbo charge side.
Also I've tried the LWG versions of the maps with no success.
Old 02-09-2012, 11:19 AM   #6
Omega_2nr
Member#: 298119
Are you sure your WGate is working properly? Opening/closing properly.....or is there some sort of adjustment on it?
Omega_2nr is offline   Reply With Quote
Old 02-09-2012, 11:25 AM   #7
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
That's the next thing to check, I would give it a turn to slightly loosen the preload...
Old 02-09-2012, 12:31 PM   #8
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
I would start by removing any tension from your WG and see if you still get a surge.
moonrider_99 is offline   Reply With Quote
Old 02-09-2012, 08:36 PM   #9
JohnJW
Member#: 304172
Thanks for the replies so far.
So I might try adjusting the rod. Is this a normal service procedure for older WRX's? I don't understand how the rod would lengthen over time and preload the wastegate? I'm sure the car was not like this to begin with when new.
I just don't want to have a bandaid fix, when the real problem is.......?
Old 02-09-2012, 09:41 PM   #10
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
It's not you car from day 1 is it? You don't know what has been done to it. That's why I went with making sure the Vac. lines were the proper lines at first, If they are, then proper adjustment of the preload on the wastegate is next. If adjusting it doesn't fix the problem then you need to put it back to where it was...
Old 05-22-2012, 08:03 AM   #11
Stirav2
Member#: 307578
1995 STI RA
White/Black
Be careful with this man, I had/have the same problem. 1-3 gears no problem. 4th sometimes and not so bad, but 5th was pretty bad and only happened within a certain rpm range. One day some dude was tailgating me so I lost him after a curve punching it and lost my 5th gear completely during the surge did you ever get to fix this problem?
Stirav2 is offline   Reply With Quote
not normal boost spike/surge seanathanq83 Open Source Reflashes 10 08-19-2009 02:51 PM
boost spike / surging when raining sharpe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-24-2008 10:09 PM
Boost Spike/Compressor Surge 94'325is Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-24-2006 11:14 PM
Boost spiking/surging jetsiphon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-15-2005 09:06 PM
Need help with AP stg. 2. spiking and surging surfer5567 Engine Management & Tuning 9 01-24-2005 05:04 PM
