Old 02-09-2012, 11:56 AM   #1
teamorange
Member#: 193306
2008 STI - Stage 2
Default 2008 STI - Pulling P2440 Code - How to disable through Cobb AP?
I have a 2008 STI, running cobb stage 1 map. I just start pulling the P2440 code (air injection, bank 1). I have done some research on it, and after talking to a local tuner shop they said if the car is running fine then the valve is most likely stuck closed. So instead of spending the money right now to have the air injection piece deleted (instead of replacing) I want to just disable that code instead of having to clear the code every time it comes up.
Is there a way to do this through the AP? And how?
Thanks in advance...
teamorange is offline   Reply With Quote
Old 02-09-2012, 03:57 PM   #2
teamorange
Member#: 193306
2008 STI - Stage 2
Did some more searching since I didn't hear back from anyone. I called Cobb and they said this is possible by using their Cobb AccessTuner software. You open up the map you are currently using tin the accesstuner software, make the change (disable the codes), save the file/map, then upload the new map to your car...
http://accessecu.com/register/cobb.php
Old 06-25-2012, 09:13 PM   #3
gathermewool
Member#: 143624
14 FXT Touring
VRP
I just popped this code, which reads, "Secondary Air Injection System Valve Stuck Open (Bank 1)"
P2441 is stuck closed
I just popped this DTC, so I haven't done all of my research yet, but I'm assuming that doing something to ensure it shuts would be better than letting it remain stuck open. I would guess there's also a check valve in the system, but I don't know.
gathermewool is offline   Reply With Quote
how to disable seat belt chime on 06 sti? wrb2006sti Interior & Exterior Modification 14 04-25-2013 09:35 PM
can anyone tell me how to disabled 07 sti DRL? tsfire Electrical & Lighting 0 09-04-2007 04:18 AM
How to disable the day light running lights on 07 STI? Chris85xlt Interior & Exterior Modification 3 04-21-2007 01:07 PM
Anyone know how to disable or disconnect Factory STi alarm? mikecoscia Electrical & Lighting 1 11-26-2006 10:25 PM
How to disable automatic locking - aftermarket alarm dragstrips Car Audio, Video & Security 7 09-04-2006 01:07 PM
