Welcome to the North American Subaru Impreza Owners Club Thursday July 30, 2015
Old 02-09-2012, 12:37 PM   #1
MyNewSubaru
Member#: 292817
Default Help converting V1 maps to V2
So I finally got my V1 Maps off of my V1 AP over to my PC. Well, I have 3 Base Maps and several Real Time Maps. The previous owner told me anytime the battery is disconnected to reflash the first Real Time Map > "STS GW R 12."
Well, there's another RT Map that says "LWG STS GW R12." I am trying to convert these maps to V2 format since I recently purchased a V2 AP. I need help on deciding which maps need to be converted, which map I should be running, and the difference in the two "custom" RT Maps.
The 3 Base Maps on the AP are "SS TS GW B 3," "Married Stock Mod," and "VF39 93 MTv101." At one point the car had a VF39 on it but is now running a VF34. So I assume the "SS TS GW B 3" Base Map needs to be on the V2 but which of the two Real Time Maps?
Uploaded with ImageShack.us
I contacted Cobb about this and was pretty much advised it'd be best to go back to Top Speed in Atlanta and have them retune the car with the V2 but I know that's not my only option, right? This is all new to me so I'm still learning I did search over on Cobb and here before posting, no dice. Thank you guys for all of your input.
Edit: is there a way I can open each map and see what it means or would it appear Greek to me? I think the LWG in the 2nd RT Map means Long Waste Gate.. which means higher boost? The previous owner did mention there was an "aggressive" on the car at one point so would that map be the aggressive tune?
MyNewSubaru is offline   Reply With Quote
Old 02-11-2012, 02:39 PM   #2
MyNewSubaru
Member#: 292817
Anyone?
AP V1 ECU lock? V1 override old V1 map AFTER V2 install and uninstall. sonic03rex AccessPort 2 08-28-2009 12:33 AM
Converting my v2 to v1 map SacksLax AccessPort 5 02-16-2009 11:40 PM
ap v1 map to v2 blackrod punishment AccessPort 5 12-05-2008 02:42 AM
Need help for 18g map to get to tuner. rexspeedmaster AccessPort 1 07-14-2008 10:43 AM
LVM gurus... need help converting IDE config to SCSI config... AcquaCow Off-Topic 6 05-14-2007 07:05 PM
