Old 02-09-2012, 04:42 PM   #1
03SUB
Member#: 184470
Default Timing belt change on 2003 6.0
I have a 2003 legacy Outback with the 6.0 It now has 105000 miles on it. I helped my son change his timing belt,idlers,water pump ect on his 2004 WRX. My question is it much different for the dual over head cam of the 6.0 than his 2.0
Also where is a good place for me to order all the parts I need to change timing belt,iders,water pump,thermostat, drive belt.
Have watched the videos of the timing belt change. Very good video just wanting to know what the difference would be or is there a video for the 6.0
Thanks for any and all help.
Paul
03SUB is offline   Reply With Quote
Old 02-09-2012, 06:37 PM   #2
Rally Monkey
Member#: 36310
03 WRX Sedan
Does the 6 cyl have a belt? I thought it had a timing chain on the 3.0 and need not be changed.
Rally Monkey is offline   Reply With Quote
Old 02-09-2012, 07:05 PM   #3
03SUB
Member#: 184470
I really don't know! That would be great if that was the case.
Any one out their know?
Old 02-09-2012, 07:23 PM   #4
03SUB
Member#: 184470
Rally Monkey you were correct. Never heard of that till you replied so I did some more searching with the question of belt or chain on 6.0 and yes it does have a chain.
Well that sounds really good so now I can use that money for something else.
PARTY!!!!!!
Thanks for the info Rally Monkey.
This site is great!
Old 02-09-2012, 08:41 PM   #5
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
I have never heard of a 6 liter Subaru. You have a 3.0L which has a timing chain.
blackfang is online now   Reply With Quote
Old 02-10-2012, 10:25 AM   #6
03SUB
Member#: 184470
Blackfang my mistake in calling it a 6.0 you are right as far as the 3.0 But the 3.0 is a 6 cylinder.
3.0L DOHC H-6 cylinder engine.
This engine has an aluminum crankcase, double-overhead camshafts (dohc) chain-driven with four valves per cylinder. The timing chain does NOT have a replacement schedule - suggested replacement of the rubber belt on the 2.5L 4 cyl is 105,000 miles.
The 6 cylinder uses Direct Ignition with an individual ignition coil for each cylinder so there is no distributor or sparkplug wires.
The H6-3.0 produces nearly 30 percent more horsepower and torque than the 165-horsepower 2.5-liter H-4 and is only 0.8 inches longer. Premium fuel, 91 octane, is recommended.
212 horsepower @ 6,000 rpm
210 lb.-ft. of peak torque @ 4,400 rpm
174 lb.-ft of torque @ 2,200 rpm
I guess we all learn some thing new now and then.
Oil Leak From Near Timing Belt Cover - Wait Until Next Timing Belt Change? Surf WRaX Service & Maintenance 12 09-02-2011 06:26 PM
changing the timing belt, change bearings or whole idler wheels/pulleys? NicEJ25 Service & Maintenance 15 12-28-2010 07:46 PM
Any deals on Timing Belt Change? cjx17 Mid West Subaru Owners Club Forum -- MWSOC 15 02-04-2009 02:35 AM
When doing a timing belt change on an EJ22... SubarNoober Normally Aspirated Powertrain 7 02-21-2008 02:44 PM
Need advice on 2.5 DOHC timing belt change FiremanBob Normally Aspirated Powertrain 3 01-11-2007 12:20 PM
