Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-09-2012, 08:24 PM   #1
overlord
Member#: 52186
2005 LGT LTD
Regal Blue
Default 05 xt consuming oil
I have had the car for one year now and at each oil change it was low on oil but I checked it at the 3000K mark and ended up 2.5 quarts low. I have no smoke coming out the tail pipe and no other issues with the car. The td04 was factory replaced just before I purchased the vehicle. Any ideas?
cliff notes
consumes oil
86K miles
no mods
no smoke
no leaks
no CEL
2.5 quarts low
WTF
overlord is offline   Reply With Quote
Old 02-09-2012, 08:30 PM   #2
soundsofsnow
Member#: 230039
94 Miata
come at me bruh
if it's mobile 1, i burned that quite a bit.
i switched to rotella and have seen better results.
soundsofsnow is offline   Reply With Quote
Old 02-09-2012, 09:05 PM   #3
SkiWrex
Member#: 142559
02 PSM Wagon VF39d
05 PSM Fozz 2.5xs
+1 on the rotella. Turbo subarus tend to eat a little oil, especially if it's Mobil one.
Another thing to check would be the valve cover gaskets, if you can smell burnt oil in your engine bay after driving, they need to be replaced.
SkiWrex is offline   Reply With Quote
Old 02-09-2012, 11:05 PM   #4
Momosaurus WRX
Member#: 214737
I also recommend rotella. My 99 legacy burns so much of any other oil besides Rotella. I've tried several different brands.
Momosaurus WRX is offline   Reply With Quote
Old 02-09-2012, 11:18 PM   #5
docNUCCA
Member#: 242377
2006 Legacy GT Wagon
For Sale
pull the TMIC and see if there is a large pool of oil in it. If so, your turbo seals may have gone. You may find your 2.5qts in there.
docNUCCA is offline   Reply With Quote
Old 02-09-2012, 11:37 PM   #6
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
Rotella T6 Full Synthetic FTW! Should have my oil sample results back from the lab soon with how good the stuff does breakdown wise. From the initial reading it looked very good!
907Bum is offline   Reply With Quote
Old 02-10-2012, 12:12 AM   #7
overlord
Member#: 52186
2005 LGT LTD
Regal Blue
I'll be switching to rotella ASAP and I'll check the ic tomorrow. Thanks for the comments.
Old 02-10-2012, 10:57 PM   #8
euroauto
Member#: 249
05 FXT psm
12 R350
Or try to find Mobil 1 15w50 No high consumption issues
euroauto is offline   Reply With Quote
Old 02-10-2012, 11:56 PM   #9
soob noob
Member#: 220158
02 bugeye
medamullet tuned
Rotella-T FTW
soob noob is offline   Reply With Quote
Old 02-11-2012, 12:42 AM   #10
docNUCCA
Member#: 242377
For Sale
keep in mind every time you switch oils you'll have a bit of usage as seals always respond differently to changes.
Once you find an oil you're happy with, stick with it. In my opinion, it will really respond differently with your 2nd round of Rotella (if you go that direction), meaning, you'll see less oil disappear after your 2nd oil change interval. If mechanically you don't have other issues.
Hope your TMIC isn't full of 2.5qts of missing oil
Old 02-11-2012, 09:38 PM   #11
overlord
Member#: 52186
2005 LGT LTD
Regal Blue
I pulled the ic tonight and there is not enough oil in there to be a bad turbo. I'm still digging into it. Pulling the dp tomorrow.
Old 02-12-2012, 03:11 AM   #12
excipient
Member#: 90956
2004 Forester vf39'd
Blacked Out(sold)
Normal dude, my 04 was a quart and a half to two quarts low every oil change. If you are in boost on those you get lots of blow by, main thing is to add oil between changes and not worry about it. Keep the oil level up and then worry about it if and when something blows but you should be good. I was worried about the same thing as you from 5k on but never had an issue and sold the car with 70k which was stage 2 then vf39 ots for most of it's life. Mine seemed to be happier with Pentosynth 5w-40 which I bought from these guys, good luck.
Motor Sport Inc‎
2128 South Richard Street
Salt Lake City, UT 84115
(801) 487-6733.
excipient is offline   Reply With Quote
Old 02-12-2012, 11:25 AM   #13
docNUCCA
Member#: 242377
For Sale
Glad the ic did not have a large pool inside.
One option that many like to address blow by is to pick up the Grimmspeed Air/Oil separator. Works great as long as you aren't using any alternative crazy fuels like E-85 or race fuel.
All assuming that you have no mechanical issues. In addition, my wife's 2.5i legacy is recommended to go 5K in between oil changes, but she's always a quart down at 3K and has done this since we picked it up at 18K. So I always change the oil at 3K, just like my legacy GT. (And it ate the Quaker state the car lot had put in it when we bought it, muchh better on Castrol GTX).
My GT eats zero oil at 23psi now that I have an air/oil separator in place. (this is my second motor )
Hope your mechanicals are fine.
Old 02-13-2012, 12:40 AM   #14
overlord
Member#: 52186
2005 LGT LTD
Regal Blue
I guess that's why I worry. My lgt never consumes anything and my wrx before it didn't either. Maybe .5 quarts at 3k. I pulled the dp and nothing there either. I'll take it as is it still performs fine and gets expected mpgs. As always thanks for the input.
Old 02-13-2012, 01:39 AM   #15
907Bum
Member#: 183634
02 wrx/ 92 ss
Booze fueled :)
My old leggy burned a ton of oil (read 3-4 quarts added a change), an AOS stopped this all together..
Old 02-13-2012, 07:21 PM   #16
soundsofsnow
Member#: 230039
94 Miata
come at me bruh
I think i'll be picking up an AOS after reading this thread and getting sick of topping off mine too.
Old 02-13-2012, 11:27 PM   #17
zackl801
Member#: 171753
2012 WRX
where is a good place to pick up that rotella t?
zackl801 is offline   Reply With Quote
Old 02-14-2012, 01:24 AM   #18
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Anywhere that sells it.
bhhamblin is offline   Reply With Quote
Old 02-14-2012, 03:56 AM   #19
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
Walmart carries it, autozone as well.
addictionsoLA is offline   Reply With Quote
2007 Impreza 2.5i consuming oil kaotik78 Normally Aspirated Powertrain 32 07-07-2008 02:04 PM
does leaking turbo consume oil?? Suberman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-29-2006 07:04 AM
Mobil 1 5w30 users- whose car consumes oil? ursmother Service & Maintenance 39 10-02-2005 03:06 AM
Anyone come to a consensus of why STis are consuming oil? eightballrj Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 29 09-19-2004 09:04 PM
STi consuming oil? jasonchanx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-19-2003 06:44 PM
