Old 02-09-2012, 10:28 PM   #1
Turbo27
Member#: 270182
2003 WRX
Default 03 EJ205 Compression test results @ 165K
Just finished doing my compression test and here are the results!
Was done on a warm engine following the FSM's instructions.
Cylinder 1: 160 PSI
Cylinder 2: 161 PSI
Cylinder 3: 160 PSI
Cylinder 4: 161 PSI
FSM says 138-166 PSI is standard so needless to say I am very happy with the results! I even went back through and did the test twice to be sure.
Just posting this up here to see what others are getting as far as compression numbers, I've seen a few but please post up your year/mileage/compression results if you want!
Last edited by Turbo27; 02-10-2012 at 07:57 AM. Reason: eg33GC doesn't like ppl saying "EJ20T" :/
Turbo27 is offline   Reply With Quote
Old 02-09-2012, 10:36 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
the **** is an ej20t
eg33GC is offline   Reply With Quote
Old 02-10-2012, 07:54 AM   #3
Turbo27
Member#: 270182
2003 WRX
Quoted from Wikipedia:
Originally Posted by Wikipedia
EJ20T
This is not actually a valid code from Subaru, but is mostly used by enthusiasts and also mechanics to describe the entire line of 2.0 litre turbocharged engines that have been available over time. The practice began with the incorrect designation of the USA-spec turbo, commonly referred to as the EJ22T, and the habit of referring to any turbocharged engine as a "T" began.
I will change it to EJ205 if it will make you feel better.
Old 02-10-2012, 08:27 AM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
congrats..keep doing what you're doing
fastnoypi is offline   Reply With Quote
Old 02-10-2012, 09:43 AM   #5
Turbo27
Member#: 270182
2003 WRX
Well I wanted to check it just to give me piece of mind because I am about to be upgrading the turbo and shooting for 300 wheel. These results make me feel a lot better about going ahead with it!
Old 02-10-2012, 04:22 PM   #6
Rally Monkey
Member#: 36310
03 WRX Sedan
03 wrx, 105000 miles. 165,165,165,164 tested last week.
Rally Monkey is offline   Reply With Quote
Old 02-14-2012, 08:51 PM   #7
sorrowfulkiller
Member#: 170439
I <3 Lamp
OP you are a lucky man, as of two years ago my compression test would have shown something like 150, 155, 0, 158
I broke a rod in to pieces....
sorrowfulkiller is offline   Reply With Quote
Old 02-18-2012, 05:43 PM   #8
AZP Installs
Member#: 40160
AZP Installs is offline   Reply With Quote
Compression test results TyranosaurusWRX Newbies & FAQs 0 03-13-2004 10:32 PM
Compression Test Results subachad Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-29-2003 07:08 PM
Compression Test Results @ 55,650k PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-12-2003 02:59 PM
EJ25 Compression Test Results at 50,000 miles latinskllz Normally Aspirated Powertrain 4 11-11-2002 02:46 PM
Compression test results numbers Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-12-2001 01:08 AM
