Old 02-10-2012, 09:42 AM   #1
hotshot2109
Member#: 94785
04 WRX STi
Default 02 WRX needs a tune with just bolt ons?
I have an 02 wrx and a friend told me I should get a tune even with only having an equal length header, stock catted up pipe, 3" catted down pipe, 3" catback, sti top mount with hks ssqv and spt cold air intake. I have a turboXS utec uninstalled...
hotshot2109 is offline   Reply With Quote
Old 02-10-2012, 09:53 AM   #2
brutnus
Member#: 257195
2004 WRX
2.1L 12k miles strong
Its just a safety thing for your car. You want to make sure its tuned to run on your mods. if in doubt get it tuned.
brutnus is offline   Reply With Quote
Old 02-10-2012, 10:02 AM   #3
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
exhaust and bov......doesn't seem ricey to me at all.
No you do not "need" a tune, but you will get much more performance and reliability if you do tune.
jayman4312 is offline   Reply With Quote
Old 02-10-2012, 04:41 PM   #4
WMCCook29
Member#: 152685
2005 VF34 WRX Wagon
You really need to get a catless UP in there, your turbo will thank you!
WMCCook29 is offline   Reply With Quote
Old 02-10-2012, 09:21 PM   #5
pocketdrummer
Member#: 197301
2005 WRX STI
W R Blue (02C)
sell the hks ssqv and spt cold air intake. Buy a grimmspeed uppipe (or equivelent), get a tune.
The BOV will only jack with your AFR during shifts and won't really give you anything other than looks with raised brows.
The stock airbox is good until 350-400 AWHP (if I'm not mistaken, double check the exact number). You won't be making that much unless you get a larger turbo. Not to mention you're drastically increasing the chance of hydrolock. Also, you're AFR will be off from this until you tune for it as well.
The Up-pipe, on the other hand, will help the turbo spool up faster and generally give you more power. This part technically doesn't require a tune, but all new parts perform better after a tune.
pocketdrummer is offline   Reply With Quote
Old 02-11-2012, 01:14 AM   #6
03Rextacy
Member#: 239497
2003 Impreza WRX
Not to mention, could save your a$$ should the cat decide to break free. First mod IMO should be a catless Uppipe.
03Rextacy is offline   Reply With Quote
Old 02-19-2012, 09:03 PM   #7
hotshot2109
Member#: 94785
04 WRX STi
This is just my winter car.. I have an 04 STi also. Some semi local subaru guys said I should get a tune mostly for ignition purposes. I could care less how it performs I just want to keep it reliable and sound good.
Old 02-19-2012, 09:22 PM   #8
WhiteBgeye02
Member#: 224785
2005 wrx-jdm207
i went black...
well if u want reliable then get a tune and keep it conservative.
WhiteBgeye02 is offline   Reply With Quote
Old 02-20-2012, 02:18 AM   #9
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
SPT intake needs to be tuned for and you're not benefiting with that TMIC without tuning either.
Byzantium is offline   Reply With Quote
Old 02-20-2012, 08:37 AM   #10
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Originally Posted by Byzantium
SPT intake needs to be tuned for .
No it doesn't... Ran it on my bugeye for 2yrs, never had a cel or any other probs.
wrxlaunch is offline   Reply With Quote
Old 02-20-2012, 08:41 AM   #11
Byzantium
Member#: 207826
85k 2002 WRX
Great. The MAF housing is smaller than stock. It needs to be tuned for. Even Subaru accounted for this with a reflash.
Old 02-20-2012, 10:29 AM   #12
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Good to know... Thnx for update
Old 02-20-2012, 03:32 PM   #13
FraudulentNeon
Member#: 29108
2002 Impreza WRX
For the later model owners, just wanted to reiterate that the 02-03 cars only can safely be modded without a tune.
Regardless, wake that thing up with a tune! Night and day.
FraudulentNeon is offline   Reply With Quote
Old 02-20-2012, 03:49 PM   #14
Byzantium
Member#: 207826
85k 2002 WRX
^ Depends totally on the mods in question.
Old 02-25-2012, 08:39 AM   #15
hotshot2109
Member#: 94785
04 WRX STi
It turns out I can stand the way the car feels with that tiny turbo spooling unusable heat the whole time, and the tiny top mount isn't doing much. So I have a holset hx35, all the flanges and pipe to rotate, fmic kit with enough pipe to mod it for the holset, STi 535cc injectors from my car, and a utec. I'm going to add a few other pieces and boost 10psi, maybe some holset lag will help with the 20mpg and step up the power output to more then what this gutless wonder has now..
02 MBP WRX W/JDM STI VII with all bolt ons redhat778 Private Vehicle 'For Sale' Classifieds 9 01-17-2005 02:46 AM
F.S. 2004 wrb/gold sti with tastefull bolt ons. potsiewebber Private Vehicle 'For Sale' Classifieds 3 11-10-2004 07:11 PM
HP potential for 2.5RS with common bolt ons? Davenow Normally Aspirated Powertrain 32 05-06-2003 09:54 AM
What's a good turbo upgrade for people with basic bolt ons S-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-21-2002 04:05 PM
how much HP with just bolt ons for now slammedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-11-2002 04:30 PM
