Old 02-10-2012, 11:24 AM   #1
zosozoso
Member#: 283924
2007 Impreza 2.5I
cgm
Default 245/45/17 on stock 07 wrx rims
as the title says will 245/45/17 fit on 2007 stock wrx rims? Or is 235/45/17 the biggest tire i can fit on it. I want a wider tire than the rim, i dont like how the 215/45 sits flush and maybe a little behind the rim. Let me know what you guys think. Also i was going to get falken 912, sumitomo, or kumho ecsta le what set up would you guys suggest? Thanks everyone!
zosozoso is offline   Reply With Quote
Old 02-10-2012, 11:44 AM   #2
Splinter888
Member#: 215962
2006 Wrx
SGM
Personally a 225/45/17 is the biggest I would go on stock 07 wrx wheels. A lot of people run 235's but to me 245's are just way to wide for them.
If you care about turn in/steering feel i would go with 225 down. Although your tire choice isn't aimed at performance, you can still get a good feel out of them if you size properly.
As for the tires listed, I have driven on a set of half worn 912's and they weren't bad. Leagues above the Re-92's I was used to (obviously) and they had pretty decent turn in and overall grip. Also in the rain they seemed to above average but thats just me.
Splinter888 is offline   Reply With Quote
Old 02-10-2012, 11:54 AM   #3
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
For starters, a 245/45/17 tire is way to tall. You'd want a 245/40/17 tire.
That said, it's too wide. Your tires would bulge out and you wouldn't get the full benefit of the wider tires. Most 245/40/17 tires require a 8" to 9.5" wide wheel. You can see the requirements on a tires specs (Tire Rack the best site for seeing specs).
I'd suggest a 225/45/17 tire, or go all out and pick up some 17X8 wheels and slap on the wide tires.
dbrier is offline   Reply With Quote
Old 02-10-2012, 12:22 PM   #4
zosozoso
Member#: 283924
2007 Impreza 2.5I
cgm
Thanks guys I'm guna go 225/45 in the fallen 912 95 dolla each I don't think is a bad deal huh and ten doll each shell to put on so 420 to have a new tires...
Old 02-10-2012, 02:52 PM   #5
zosozoso
Member#: 283924
2007 Impreza 2.5I
cgm
On a 225 how low can i go on the side wall, could i do 40, or ever 35?
Old 02-10-2012, 03:15 PM   #6
jprice130
Member#: 288225
2013 FR-S
I found this link in another thread in the Tire/Wheel forum and found it very helpful when I was trying to determine what alternate tire sizes to use for my 06 WRX:
http://www.rimsntires.com/specs.jsp
Pay attention to how different widths and sidewall heights affect the overall diameter of your tire. As you probably know, larger/smaller tire diameter affects the final drive ratio of your car and could throw your speedometer off by a couple MPH depending on which way you go.
This tool will also give you an idea of how fitment in your wheel well might change based on the width/sidewall of your tires and offset of your wheels. Good luck!
jprice130 is offline   Reply With Quote
Old 02-10-2012, 03:29 PM   #7
zosozoso
Member#: 283924
2007 Impreza 2.5I
cgm
Well i have a 2.5i 07 but with wrx rims, that the only reason im thinking 225/40s instead of 45s
245/45/17 on stock sti rim Alpha_32 Tire & Wheel 27 06-25-2010 02:07 PM
Suspension Effects of 245/40/17 on stock '06 WRX Wagon? zenphoenix Tire & Wheel 2 11-22-2009 01:11 AM
245/45/17 on a 09 WRX wagon wildsti Tire & Wheel 15 05-12-2009 11:40 AM
Anyone in the TXIC, running 245/45/17 on stock suspension? _sti_05 Texas Impreza Club Forum -- TXIC 10 02-06-2007 11:56 AM
245/45/17 on stock 2004 sti ? rapidus Tire & Wheel 16 03-30-2006 12:10 PM
