Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Old 02-10-2012, 06:58 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default Just Released DEFi 60mm Racer Gauges! Boost, Pressure, Temp, EGT, and Volt! IN STOCK!
The Defi Racer Series Gauges are quick-responsive and high-accurate analog gauges. Boost, pressure, temperature, exhaust temperature, and volt gauges are available. They are 60mm in size and the lighting is available in blue, red or white.
A Stepping motor provides smooth operation. The Racer gauges are illuminated using high-brightness LEDs. Self-diagnostics function monitors both sensor disconnection and short-circuiting during the startup sequence.
The Face features a full 270 degrees sweep dial provides ultimate visibility. The Defi Racer Gauge does not require the Defi-Link Control Unit II for use, and cannot be used in conjunction with it. The red triangle of the regular position bezel can be used as a warning indicator and others. A mounting bracket and instrument case is provided with the gauge.
Imperial or Metric
Red, White, or Blue
Boost, E.G.T. (Exhaust Gas Temp), Pressure, Temperature, Voltage
214.20
Boost/Turbo In Metric or Imperial
__________________
RallySport Direct is offline   Reply With Quote
Old 02-10-2012, 06:59 PM   #2
RallySport Direct
Member#: 33174
We are Open Late!
__________________
Old 02-10-2012, 06:59 PM   #3
RallySport Direct
Member#: 33174
We are Open Late!
__________________
Old 02-10-2012, 06:59 PM   #4
RallySport Direct
Member#: 33174
We are Open Late!
__________________
Old 02-10-2012, 06:59 PM   #5
RallySport Direct
Member#: 33174
We are Open Late!
Voltage
135.90
RICK APPROVED AND IN STOCK!
Also don’t Forget all orders over 200 get free shipping in the lower 48 states!
__________________
Old 02-23-2012, 05:49 PM   #6
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 02-23-2012, 05:51 PM   #7
Psychoreo
Member Sales Rating: (11)
Member#: 79643
2015 WRX STI
Terminal black pearl
Have anything in the green backlit, yellow needle flavor?
Psychoreo is offline   Reply With Quote
Old 02-23-2012, 05:53 PM   #8
RallySport Direct
Member#: 33174
We are Open Late!
No
As most cars now days come with either white or amber coloring Defi has stopped production of green back light gauges.
__________________
Old 02-23-2012, 05:56 PM   #9
Psychoreo
Member#: 79643
2015 WRX STI
Originally Posted by RallySport Direct
No
Not even in the back of some random filing cabinet in the far corner of the warehouse under an old newspaper that was discarded long ago? :-(
Old 02-23-2012, 06:02 PM   #10
RallySport Direct
Member#: 33174
We are Open Late!
Not even that
You would need to go back to the older Defi Link gauges from about 5 years ago as the last ones that where still offered in green.
Trust me I have personally been looking for a full set for one of my cars with no luck
Kirill
RallySportDirect.com
__________________
Old 02-27-2012, 07:14 PM   #11
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 03-10-2012, 11:40 PM   #12
RallySport Direct
Member#: 33174
We are Open Late!
To the top
__________________
Old 03-15-2012, 07:36 PM   #13
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 03-16-2012, 08:39 AM   #14
DVS04
Member#: 313719
2003 STi
Best price on defi 60mm boost in psi, 60mm oil pressure and oil temp. All in amber please.. Defi racer series..
Delivered to australia
DVS04 is offline   Reply With Quote
Old 03-23-2012, 04:37 PM   #15
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 04-06-2012, 05:42 PM   #16
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 04-23-2012, 05:46 PM   #17
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 04-23-2012, 07:08 PM   #18
Pearly_Whites
Member Sales Rating: (5)
Member#: 164714
2007 WRX TR
Satin White Pearl
Bump!
...you have PM
Pearly_Whites is offline   Reply With Quote
Old 06-12-2012, 03:42 PM   #19
RallySport Direct
Member#: 33174
We are Open Late!
Bump it up for some great products!
__________________
Old 06-18-2012, 02:07 PM   #20
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Old 06-24-2012, 04:58 PM   #21
RallySport Direct
Member#: 33174
We are Open Late!
To the top!
__________________
Old 07-27-2012, 05:39 PM   #22
RallySport Direct
Member#: 33174
We are Open Late!
BUmP!
__________________
Old 08-12-2012, 02:44 PM   #23
RallySport Direct
Member#: 33174
We are Open Late!
To the top!
__________________
Just Released DEFi 60mm Racer Gauges! Boost, Pressure, Temp, EGT, and Volt! In stock RallySport Direct Interior/Dressup/Audio & Security 31 06-24-2012 04:57 PM
Just Released DEFi 60mm Racer Gauges! Boost, Pressure, Temp, EGT, and Volt! RallySport Direct RMIC Vendor Classifieds 4 02-07-2012 03:41 PM
FS : DEFI red racer gauges boost and pressure lunch7 Interior/Dressup/Audio & Security 17 01-01-2012 04:53 PM
FS : Defi 60mm BF gauges with pod (boost, EGT, oil pressure) thbalance NESIC Private Classifieds 9 10-12-2011 03:38 PM
