Old 02-11-2012, 11:34 AM   #1
steveomiami
Member#: 309883
Default 1992 Jdm Wrx Questions
I just got a 1992 JDM WRX and I have a few questions. First what should the stock boost be? How much boost is safe? I'm not trying to raise it but i want to see what it is running now to know if the prior owner was over boosting or anything. All I know is that there is an apex intake thing with a k&n filter on it, I was told it has 300hp but I don't know from what. it also has an hks nov on it. I have 2 vacuum lines coming off the front left when standing at the front, they are both plugged with screws. My guess is they went to the stock air box or something but i have no idea. Thanks in advance.
steveomiami is offline   Reply With Quote
Old 02-11-2012, 01:24 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
1. get a rob tune
2. get a turbo back
3. get a mbc
4. get good plugs
5. be happy
eg33GC is offline   Reply With Quote
Old 02-11-2012, 06:36 PM   #3
blessthekellen
Member#: 273859
MY98
WRX
^truth.
blessthekellen is offline   Reply With Quote
Old 02-12-2012, 04:10 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
1992 runs 0.7-0.8 bar boost stock (9-12 psi) max safe boost is 1 bar or 14 psi. Other than that do as eg33GC says
Marnix is offline   Reply With Quote
Old 02-12-2012, 11:55 AM   #5
steveomiami
Member#: 309883
Sounds like a plan, It already has a turbo back so i got that one covered and I was already reading a little about robs tune. My engine code is EJ20GDW1HE so this car has a 9-1 compression ratio right? What gas should I run and what gas should I run with Robs tune? Also what plugs are good to run in this car? Lastly does anyone have any idea about the boost lines in my first post?
Old 02-13-2012, 12:19 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
No. It has a 8.5 compression ratio. The 9.0 compression ratio for EJ20G wagons and automatics came in 1996 for the MY97-98 cars. Plugs (NGK PFR-6B) are the best for stock cars once you turn up the boost run NGK PFR-7B. If you don't mind changing plugs more often you can also run the non-platinum verions but stick to NGK and the heat range.
Old 02-18-2012, 07:46 AM   #7
steveomiami
Member#: 309883
[/s][/s]http://i88.photobucket.com/albums/k1...P/IMG_5533.jpg
This is not my car but what are those 2 vacuum lines running out on the lower left of the picture? On my car these 2 are plugged.
Old 02-18-2012, 08:11 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The bigger of the two runs from the fuel tank evap line to the charcoal canister near the radiator on the right side of the vehicle. The smaller one runs from the charcoal canister to the purge solenoid valve.
Old 02-18-2012, 08:18 AM   #9
steveomiami
Member#: 309883
oh ok so those are not necessary and i should make sure that they have an airtight seal since they currently have screws in them?
Old 02-18-2012, 02:48 PM   #10
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
If you have the Charcoal evap canister it doesnt hurt to hook it up. I've been told in some states it is required for emissions. Off of the top of my head I do not remember if there is a CEL code in the 92 WRX ecu for the evap system. But on USDM WRX models there is. If you do a search on deleting the charcoal canister you may find it educational.
TommyAtomic is offline   Reply With Quote
Old 02-18-2012, 05:32 PM   #11
steveomiami
Member#: 309883
Are these the right injectors for the robs tune?
http://www.ebay.com/itm/Subaru-1993-...item256cd52152
Old 02-20-2012, 10:27 AM   #12
steveomiami
Member#: 309883
Ok I found the right injectors, how do I get in touch with rob?
Old 02-20-2012, 11:40 AM   #13
eg33GC
Member#: 206851
56 Belair
Pro Street
pm him on here, or I can refer him to you
FS : 1992 Jdm Wrx - $5900 Obo jstbstn VIC Private Classifieds 2 09-27-2011 05:29 PM
FS: 1992 jdm WRX sedan $9700 (<-nasioc price!) 92-GC8 VIC Private Classifieds 10 06-14-2008 01:57 PM
Just bought a 1992 JDM WRX, noob questions! Flat6 Newbies & FAQs 3 05-20-2008 12:56 PM
1991 legacy fwd manual -> 1992 jdm wrx Sojuuk Subaru Conversions 10 10-30-2005 01:11 PM
Quick late model JDM WRX Question ben awd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-28-2005 03:46 AM
