Alaskan Impreza Club
Old 02-12-2012, 02:18 AM   #1
fightnhawaiian
Member#: 299648
05 Sti
Cgm
Default Fuse box location
Can anybody tell me where the fuse for the o2 sensor is. There is a hidden box under the glove box somewhere but I cant find it
fightnhawaiian is offline   Reply With Quote
Old 02-12-2012, 02:26 AM   #2
Ethan_Drift
Member#: 264930
2011 GT, Evo 8
I don't think the O2 sensor has a specific fuse. What makes you think that it's blown, if it does? Also, what type of car?
Ethan_Drift is offline   Reply With Quote
Old 02-12-2012, 02:56 AM   #3
fightnhawaiian
Member#: 299648
05 Sti
Cgm
I've checked the sensor and wires, but I've read to also check the fuse...I keep throwing a code and I wanted to try that before buying a new sensor...car is a 05 sti
Old 02-12-2012, 03:06 AM   #4
Ethan_Drift
Member#: 264930
2011 GT, Evo 8
I don't think there is a fuse seeing how both O2 sensors are controlled by the ECM.
Old 02-12-2012, 03:33 AM   #5
fightnhawaiian
Member#: 299648
05 Sti
Cgm
http://www.iwsti.com/forums/2-5-lite...g-fuses-3.html
Here is a link from what I was reading
Old 02-12-2012, 03:36 AM   #6
coldfiremx
Member#: 285848
I don't know for sure if the HO2 has its own fuse on your car but the only reason would be for the heater. Some cars have a seperate fuse for the heater, some use the ECM fuse. More than likely if your complaint is an HO2 heater code, the sensor will need to be replaced.
coldfiremx is offline   Reply With Quote
Old 02-12-2012, 03:45 AM   #7
fightnhawaiian
Member#: 299648
05 Sti
Cgm
I figured I would try and check everything before buying a new one
Old 02-14-2012, 02:57 PM   #8
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
It has a fuse for the heater. If the heater fuse blew then it is probably shorted.
Check bus fuse #5 "under the hood fuse box"
P3Auto is offline   Reply With Quote
building a fuse box, what fuses for what?? traction issuez Electrical & Lighting 3 05-27-2009 11:42 PM
98 impreza fuse panel location XLR8_HFX Electrical & Lighting 3 01-11-2007 06:23 PM
Fuse Box Pocket mhanch Newbies & FAQs 4 12-17-2001 11:31 PM
Fuse Box Wiring - MY01 Impreza Safir General Forum Archive 0 04-02-2001 07:34 PM
