Old 02-12-2012, 04:08 AM   #1
ncarn8
Member#: 71419
Default Misfire at WOT under 4500 rpm?
I can floor it in 1st gear and all is well. But whn i shift to second, and wide open throttle, it will misfire. At any revs, in 2nd gear.
If i ease in the throttle as revs rise i can go floor it again over 5k rpm and its fine.
Have changed plugs, coilpack.
Car is EJ205 with JDM STI computer conversion, VF28, FMIC, Silicon intakes, Walbro.
I cant for the life of me figure out why it will misfire, usually in second, if you go to wot under 4500rpm.
Any help please!!
edit - boost gauge connected to turbo outlet, shows 10-11 psi.
Doesnt really go as well as it should.
ncarn8 is offline   Reply With Quote
Old 02-12-2012, 11:54 AM   #2
pmugabi
Member#: 280926
If you're running an EJ205 with it's correct ECU, then this should have been posted under the Factory 2.0L Turbo powertrain forum.
Since you've changed plugs and coilpacks, another possibility is that the car might be running lean under 4500rpm and hence misfiring. Have you ever logged AFRs on it? The 2002+ ECUs have fairly good diagnosis capabilities, try pulling the codes and see if any error codes have been stored.
pmugabi is offline   Reply With Quote
Car is making screetching noise at WOT around 4k rpms... All4bSpinnin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 49 12-15-2014 03:58 PM
Hesitation at wot from 4000+ rpm MTL_SLVR_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 11-21-2013 09:30 AM
Boost bounce at WOT under load ZekeTheSneak Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 26 10-27-2011 04:47 PM
02 wrx hybrid bogging/hesitation at wot around 4400 rpms help!! STiGuy23 Built Motor Discussion 50 10-31-2009 11:41 AM
bogging/hesitation at wot around 4400 rpms help STiGuy23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-20-2009 08:52 PM
