Old 05-26-2012, 09:31 PM   #51
79tranny
Member#: 209661
JDM RHDswappedWRX
2012 Dodge Ram-daily
79tranny is offline   Reply With Quote
Old 05-27-2012, 01:18 PM   #52
oatbran84
Member#: 182893
06 06 cgm sti
cgm
oatbran84 is offline   Reply With Quote
Old 05-27-2012, 02:56 PM   #53
25rsti
Member#: 166324
Old 07-10-2012, 01:17 PM   #54
79tranny
Member#: 209661
JDM RHDswappedWRX
Cams have come in! Just waiting on:
Pistons
Rods
Bearings
And two sets of hella tones
Once it all arrives at the shop I will pick it up and add pictures
Now I need:
Fuel rails/injectors (outfront motorsports)
Invidia one piece header
Clutch (haven't decided which one yet)
Two 38mm TIAL EWG
gasket set
Timing belt kit
Oil pump
Oil pick up.
The clutch and header will probably be the most expensive buys but not as bad as the cams pistons and rods lol
Then the wiring harness will get merged, custom brake lines for abs delete yada yada yada...
Don't want to get too into detail and bore everyone!
Pics will be added by next week when the rest come in!
Old 07-29-2012, 08:31 PM   #55
79tranny
Member#: 209661
JDM RHDswappedWRX
Decided to switch to turbo tuff I beam rods by Manley! Will be in by Tuesday
Old 07-29-2012, 09:19 PM   #56
Tubbs540
Member#: 197216
2006 STI
06 Range Rover Sport SC
Where did you find that front end clip?
Tubbs540 is offline   Reply With Quote
Old 07-30-2012, 09:41 PM   #57
79tranny
Member#: 209661
JDM RHDswappedWRX
I purchased it from a member on here
Old 08-20-2012, 09:56 AM   #58
79tranny
Member#: 209661
JDM RHDswappedWRX
Haven't updated in some time now and I've been slacking with the pics! I'm working on getting a much better job right now so my saved up $$ is on hold right now.
Next purchase will be both tial ewg's, one piece Invidia headers and msi solid motor mounts (will lower my engine 15cm for some good clearance for my long runner/big plenum intake manifold!
Hopefully I'll get a chance to upload my pics soon
Old 08-20-2012, 11:19 AM   #59
richy_21
Member#: 58670
2005 got muuuuu?
Damn nice build man. Look forward to seeing my progress, how's the rhd swap coming along?
richy_21 is offline   Reply With Quote
Old 08-23-2012, 09:31 AM   #60
79tranny
Member#: 209661
JDM RHDswappedWRX
Thanks! It's coming along very good, all I need is my fuel system a clutch and make the rotated kit.
The rhd swap itself is done besides needing merge the front harness to the rear which will get done after the motor is in.
I have just about enough saved up to finish it, but I'm starting school in a month and supposed to be getting a job as a correctional officer so I'm hanging onto that in case any extra expenses come my way.
After its running the interior will be tackled, then paint, wheels and brakes! I'm expecting it to be done by the spring.. Hopefully sooner than that
Old 09-06-2012, 03:09 PM   #61
79tranny
Member#: 209661
JDM RHDswappedWRX
*sigh* still slacking on pictures I know. I finally got an interview for my new job and I also started full time criminal justice school so things are busy.
On a good note the following parts have come in:
Two (2) tial ewg's
Msi solid motor mounts (lower engine 10mm)
And two pairs of hellatones.
THEN I also just got a 6 piston wilwood front brake kit and working for rear brembos now
I promise pics this week!
Old 09-06-2012, 04:50 PM   #62
JohnnyWas
Member#: 91010
2002 Subaru WRX
OG Blueberry
absolutely LOVE what you're doing with this car - kudos to you, man
JohnnyWas is offline   Reply With Quote
Old 09-06-2012, 10:41 PM   #63
79tranny
Member#: 209661
JDM RHDswappedWRX
Thank you the compliments help my motivation haha
Old 09-07-2012, 05:17 AM   #64
mister hashimoto
Member#: 131909
03 RHDbugeye wagon
LowerClassMen
Originally Posted by 79tranny View Post
Parted out the rhd clip? Do you still have any parts left? My wiper switch broke when it was shipped and a lhd isn't the same. And my master window switch doesn't work but when I plug in the LHD master switch all the windows work
Originally Posted by blkwagon View Post
The jdm door harnesses awe different. Do your door locks work?
I don't think they're entirely different. I swapped door harnesses (left one with right one) so all the pins I then connecters math up and they all work correctly. It's only when I plug in the jdm master switch it doesnt work.
It isn't a huge concern of mine right now but it will be soon
i know im a couple months late on this, but i had the same issues with my window switch harness they worked with the LHD control but when i plug in the RHD all my windows worked except my driver side, we switched some of the pins around so that my driver side can roll down but my back window wouldnt. also tried pulling all the pins and trying to make them work but i gave up. lol
mister hashimoto is offline   Reply With Quote
Old 09-07-2012, 02:36 PM   #65
79tranny
Member#: 209661
JDM RHDswappedWRX
Well I'm gonna have a shop check out the switches when they merge the harness for me. Worst comes to worse I will take the lhd switch out of its case and put it in the rhd switches case. Only thing is the left one will still be the auto down window.. No big deal.
Old 09-08-2012, 04:18 AM   #66
StealthWRX
Member#: 50175
2 Bugeyes
'11LGT '16FXT
this was a big pain for us as well during the swap
, i feel your pain
StealthWRX is offline   Reply With Quote
Old 09-08-2012, 09:33 AM   #67
79tranny
Member#: 209661
JDM RHDswappedWRX
Well it's not too bad I've got all my windows working already. The harness worked great. Only thing I need to do is merge the rear harness because brake light and fuel pump pin outs aren't correct
Old 09-12-2012, 02:28 PM   #68
79tranny
Member#: 209661
JDM RHDswappedWRX
Posts Numbers 4 and 5 have new picture updates!
Old 09-28-2012, 02:48 PM   #69
79tranny
Member#: 209661
JDM RHDswappedWRX
Ordering a brake booster delete, adjustable proportioning valve, and a battery relocation box.
When those come in I will get the trunk and engine bay finished up and ready to go. Also I'll install the rear diff and 6 speed since I've been slacking on that.
Waiting to get my intake manifold back from a shop getting to ports welded over. My goal currently is to hear this car start before 2013!!
Old 05-19-2013, 11:51 AM   #70
79tranny
Member#: 209661
JDM RHDswappedWRX
Wow it's been a long time since I've been on here! Just graduated my academy last month and got my new job!
Some slight changes happened, such as now I have a Cosworth intake manifold, and have gotten lots of parts in!
Ill add pics and check where I left off last, my goal is to be running by August/September (this get so expensive!!)
Old 05-19-2013, 07:28 PM   #71
25rsti
Member#: 166324
Glad you're back! IT has been along time.
Old 05-21-2013, 12:34 AM   #72
79tranny
Member#: 209661
JDM RHDswappedWRX
Yea man I forgot how long it's been! Got lots of progress made but still not there yet.. I'll add some pics up in the next day or two
Old 05-21-2013, 07:29 AM   #73
25rsti
Member#: 166324
That's how it is. Never ending, lmao.
Old 05-21-2013, 10:05 AM   #74
oatbran84
Member#: 182893
06 06 cgm sti
cgm
cant wait for this car to be done. been anticipating it since you announced the plan. . both you and chris should be coming out pretty hard this year if he can make up his mind lol
Old 05-29-2013, 11:31 PM   #75
79tranny
Member#: 209661
JDM RHDswappedWRX
Thanks brandon! I can't wait either. Wheels are on the way and just dropped some parts off to get powdercoated.
So I'll wait until that's done to add some more nice pictures
New Pics Of My rhd Bugeye!!! blkwagon Member's Car Gallery 66 06-17-2015 06:37 PM
EJ20h Twin Turbo and RHD conversion build Giraffe Attack Member's Car Gallery 12 05-15-2013 10:18 PM
bugeye build.. Pike Alaskan Impreza Club Forum -- AKIC 55 04-03-2009 07:07 PM
RHD Bugeye with dubs for sale on ebay...lol Blackaxela Off-Topic 40 10-23-2007 04:08 PM
RHD BUGEYE shots jdmSpecC760 Member's Car Gallery 25 07-05-2007 08:50 PM
