Old 02-11-2012, 02:09 PM   #1
Filibuster_Del
Member#: 285637
2005 Wrx
Rojo
Default Check Engine Light Help
ON my way home today from the barber shop i decide to go get gas, then as im reversing the car stalls due to a bafoon driving behind me while im backing up.
Then the check engine light comes on? as i crank the car, its starts up pretty slow which scared the living hell out of me. what could it be? do i Need
New Spark plugs, Timing Belt , My fluids changed ( Rear Diff, power steering, trans)?
Filibuster_Del is offline   Reply With Quote
Old 02-11-2012, 05:10 PM   #2
hardball75006
Member#: 214319
2009 Legacy 2.5 NA
Diamond Grey Metallic
Check your gas cap. If the CEL happened after right you filled up, you might not have got it tight enough.
hardball75006 is offline   Reply With Quote
Old 02-12-2012, 11:14 PM   #3
leecea
Member#: 37359
2003 WRX
If you still have the CEL, get it read at an auto store then search for the code on here.
leecea is offline   Reply With Quote
Old 02-12-2012, 11:41 PM   #4
Rally Monkey
Member#: 36310
03 WRX Sedan
could be something could be nothing. I have had CEL's twice that where nothing. The first time was just a couple of years after getting my WRX in 03. The code was for a tumble generator valve stuck open. I cleared the code and it never came back. Same thing happend on my wifes 06 Legacy. We were driving and threw a cell. I did not have a code reader for that car and it was under warranty so we drove it to the dealership. They did the same thing(pulled the code, determined there was no action needed, and it never came back. But there could be something going on with your car. You could clear the CEL and see if it comes back right away. Or just have it looked at would probably be better.
Rally Monkey is offline   Reply With Quote
Old 02-13-2012, 12:15 AM   #5
cummlns
Member#: 261222
WRX Wagon
Impossible to know what's wrong with the car without getting the code read. Autozone reads codes for free.
cummlns is offline   Reply With Quote
Check engine light help WRobX Service & Maintenance 6 12-30-2005 11:46 AM
Check Engine Light Help Topshelf Normally Aspirated Powertrain 6 12-13-2004 12:45 PM
check engine light HELP!!!! subarublu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-26-2004 02:27 PM
Check Engine Light Help HpiRally Normally Aspirated Powertrain 1 03-01-2002 12:15 AM
check engine light !!! help! jhoffmann Technical Forum Archive 2 08-13-2000 12:17 AM
