Old 02-12-2012, 06:48 PM   #1
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Default Issue With Injectors and Robb tune(possible) Help a GC8 out
I bought a Robb Tuned ECU, Grimspeed controller, and the yellow side feed injecotrs for the robb 550 tune.
Upon installing them and turning the car over, the car cranked normally for a half second, then made a sound like the starter locked up and nothing happened. i pulled the spark plugs and fuel PISSED out of only one of the cylinders.
So thinking it was just one injector i went and purchased another set(flow tested etc.) (notice the rubber piece on the top of the injector was slightly different, but still a yellow side feed).
I installed these and dropped the oil(to find plenty of fuel mixed in) put it back together just to have the issue repeat itself and now one PISSED out fuel again, and one slightly leaked more fuel then the others.
Help Me out guys, this was supposed to be a simple exchange
93GC8Dub is offline   Reply With Quote
Old 02-12-2012, 08:59 PM   #2
Mister Anderson
Member#: 296056
1993 Turbo legacy
Metalic silver
Mister Anderson is offline   Reply With Quote
Old 02-12-2012, 10:25 PM   #3
suberdave
Member#: 101865
88 GL-10 STi
you have a 93 WRX, unless you are running the adapters 550 yellow injectors will not work. they do not just drop in. you have to run a fuel injector adapter. such as these ones. http://www.carldavey.co.uk/product.php?id=2
what happeded is you turned over your engine and hydrolocked it. just pull all the plugs and slowly crank it over by hand and you will get the fuel out. then disable your fuel pump and crank it over a few times. this will get the rest of the fuel out.
-=Suberdave=-
suberdave is online now   Reply With Quote
Old 02-12-2012, 11:25 PM   #4
blessthekellen
Member#: 273859
MY98
WRX
hahaha suberdave nailed it.
you can't just drop in 550's you need the carldavey adapters to make them work on the EJ20G.
blessthekellen is offline   Reply With Quote
Old 02-13-2012, 02:53 AM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
or ej18,ej22e, or ej25d rails. direct bolt in.
eg33GC is offline   Reply With Quote
Old 02-13-2012, 01:06 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yep you need EJ25D rails, they are cheaper than the adapters.
If you have the rails or adapters already, you might have a torn o ring.
Old 02-27-2012, 05:32 PM   #7
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Wow, thanks guys, i immidiately bought the adapters of carl davey as soon as i seen the link, i pulled the plugs and cranked it by hand, fuel came out of the left side(RHD) cylinder close to firewall, i put new oil in and am waiting on the adapters or if i can find rails from the above listed engines. when i turn it over with fuel pump disabled, plugs in right?
Old 02-27-2012, 09:24 PM   #8
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Where can i purchase these fuel rails and from what im reading, the ej22e is 96-99 legacys and 98 outbacks?
Old 02-28-2012, 03:38 PM   #9
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
what subarus do the EJ25D come in?
Old 02-28-2012, 08:28 PM   #10
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
rob is offline   Reply With Quote
Old 03-09-2012, 05:32 PM   #11
93GC8Dub
Member#: 217150
1993 Wrx rhd gc8
Ya, Sorry about the delay, i purchased the adapter kit but got impatient so i found an old 98 legacy got its fuel rails (and injectors-anyone needs Red top side feed)and the car started and is running well with the Robb tune (who id like to apologize for doubting the tune, its very fun and i tried the launch controll...two thumbs up!...pretty epic!..haha Great Tune Robb!!
Help with injector and coil pack wiring Shadoxity Subaru Conversions 1 12-02-2010 07:46 AM
I need help with injectors and vf39 install! street_racen_va Mid Atlantic Impreza Club -- MAIC 6 10-07-2009 02:19 PM
HR /Can anyone help this Sunday with injector and Unichip install? japslapr Mid Atlantic Impreza Club -- MAIC 32 02-27-2006 11:07 PM
modding my injectors and a little metal doohicky pops out???????? jared nelson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-13-2005 11:18 AM
