Welcome to the North American Subaru Impreza Owners Club Saturday December 27, 2014
Old 02-12-2012, 09:23 PM   #1
98stimenace
Member#: 289023
Metalic silver pearl
Default Need a little help...please!!!
I just bought an 02 wrx with basically an 04 sti swap. It has a map on it with a v1(I think) AP. I can't get the ap to the main menu stage. The main screen comes on and then automatically goes to the screen that states "please choose a new map to flash to ecu" if I hit cancel, it goes back to the first screen and then the second screen and if I hit ok it goes to a list of maps. The car runs fine and I want to get to the main menu so I can check the CEL and clear it so I can get it inspected... any ideas? Please help!!!! The AP is the grey rectangle with the green screen and black letters...
98stimenace is offline   Reply With Quote
Old 02-13-2012, 12:51 PM   #2
Cobb Tuning
Member#: 4803
The V1 AccessPORT does have a green screen, so most likely that is what you have. It sounds like your V1 might have a stuck button which is causing it to automatically go to the next screen and not stay on the main menu. Unfortunately, we can not repair the V1 anymore. Also, the clear code function on the AP only clears codes temporarily, and they will reappear if the same issue on the car persists.
We do have a V1 Trade In Program though and you would get a $200 credit towards a new V2. If you know who originally tuned the car, they might be able to convert your current map to a V2 map. Otherwise, you will need a custom tune for the set up on your car.
Ian
Old 02-13-2012, 03:45 PM   #3
98stimenace
Member#: 289023
Thanks Ian, I also spoke to a car at Cobb, they said its possible that the ap may not be installed, is that possible? I spoke with the seller and he said its possible the battery was disconnected, could that "uninstall" the ap? Thanks again!!!
Old 02-13-2012, 04:13 PM   #4
Cobb Tuning
Member#: 4803
A disconnected battery will not uninstall the AccessPORT, only revert it back to the Reflash (base) map. The only way to uninstall the AccessPORT is to use the Revert to stock or Uninstall menu option.
Ian
Old 02-13-2012, 06:44 PM   #5
98stimenace
Member#: 289023
Should I try and install it again? Or try the revert to stock, or nothing ... is it possible to fix the CEL without the ap? I know autozone and stuff does that, but depending on what is causing the CEL, could it be something that I need the ap for? Like running too lean, etc....
Old 02-13-2012, 06:45 PM   #6
98stimenace
Member#: 289023
By the way, Ian, you are such a huge help!!!! I appreciate it a lot!!!! Again thanks!!!!
Old 02-13-2012, 07:10 PM   #7
Cobb Tuning
Member#: 4803
You will probably be able to read the code and clear it for a short amount of time using a code reader. But depending on what the code is actually for, it may come back quickly, or it might stay off.
Ian
Old 02-13-2012, 09:31 PM   #8
98stimenace
Member#: 289023
Yeah I kinda figured...I was mainly trying to figure out the ap. Wish I could afford a new one!! Thanks Ian
need a little help please notyet227 Texas Impreza Club Forum -- TXIC 36 07-28-2011 03:47 PM
Need a little help please Jkmaynard Newbies & FAQs 5 03-30-2009 12:32 PM
Need a little help please... Dieman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-23-2006 11:53 AM
need a little help please blue-ej20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-31-2002 05:35 AM
I need a little help, please read! Boom New England Impreza Club Forum -- NESIC 3 05-30-2000 02:26 PM
