Old 02-13-2012, 02:58 AM   #1
eg33GC
Member#: 206851
56 Belair
Pro Street
Default 30+ psi on a td05 16g ej20g
And it survived.
Thought I'd share with you my not so cool story,bro, of hitting 30 something tonight with my G.
I fabricated an external wastegate setup for my G, and in haste did not correctly plumb the pressure source line. The unit was an MVS, with a new diaphragm design, compared to familiar older gates. This was completely my impatience and lack of concern.
Did a 2nd gear pull, and about 3500, I was hitting my autometer's peg at 30. The car accelerated roughly from 25-60mph before I glanced at it.
Freaked, and replumbed the gate.
Engine runs great, no adverse affects. I have not inspected the oil, but I put about 10mi on it afterwards, all in vacuum.
I suspect the car had spark blowout before anything detrimental happened. I am running roughly 10.9:1 at the last cells of the map at 18.2psi, with 29* of available timing, on pump gas. I wonder what the afr looked like past 20.
Oh, the turbo decided that it didn't want the intercooler to stay on, so it blew the ic off the tb!
Boost gauge is near new, so this is not a fluke.
eg33GC is offline   Reply With Quote
Old 02-13-2012, 09:22 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
I did that once on my EJ20G TDO5 16G.
just got a new boost controler, set it wrong, did a pull getting on the freeway. it hit 2.1 bar. (boost controler stores peek boost)
all was well. now if you did that more than once or twice, i dont think it would like it much...
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 02-13-2012, 01:39 PM   #3
Aphex28
Member#: 11506
2015 WRX
you must have bumped the turbo button by mistake!
Aphex28 is offline   Reply With Quote
Old 02-14-2012, 01:00 PM   #4
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Like dave said I would not worry on it too much if you have things fixed now and the boost spike was only momentary.
When I first go my car tuned the tuner was having a weird boost issue and the easiest way of sourcing the problem was to run the turbo with a locked WG just to see if it was the turbos lack of making boost or other issues. I hit 32psi from the reading on the Utec for maybe 1/4 of a second. I asked him if it was bad to do this and he said ....not for that one time and on a throttle blip as it was. He also said since I didn't have colder plugs at the time the spark blew out more than likely well under 30psi. I tend to believe that because of the huge back fire that shot out the back after I put my foot back on the gas. The car has run fine and strong since then "2006" with a vf39. Now its been retuned with a FP Green for the past 3 years at 20psi with zero issues.
Take all that for what you will
dangerousatom is offline   Reply With Quote
Old 02-14-2012, 02:20 PM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
I'm really not concerned, I've got faith in these older engines.
It's begging for a nice v7/8 block anyway.
Old 02-14-2012, 03:36 PM   #6
dangerousatom
Member#: 70710
Keep searching the forums and ebay......
I just picked up a V8 long block motor and big port heads only from a member in UT with under 10k for $1500 shipped! That is a redonkulous deal mind you but under $2000 is a good price fora V7-8 long block
Old 02-14-2012, 04:43 PM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
That is an impossibly awesome deal.
I wish to keep the G ecu,heads, and especially intake.
Old 02-14-2012, 05:42 PM   #8
Aphex28
Member#: 11506
2015 WRX
I may have already brough this up, but I have a version 7 ej207 that spun a bearing available for sale.
I've decided to go back to usdm sti.
FS : Apexi noir, Td05 16g, bunch of EJ20G parts, Sti fuelrails, etc. Socal_WOB_LFDY 1993 - 2001 Impreza Specific Parts 11 05-22-2011 10:59 AM
WTB: ej20g td05 16g or other turbo with 90 degree inlet slava from goshen Private 'Wanted' Classifieds 1 03-31-2008 11:00 AM
WTB: ej20g td05 16g or other turbo with 90 degree inlet slava from goshen Private 'Wanted' Classifieds 0 03-01-2008 10:53 AM
td05 16g off a ej20g, or vf28 turbo spoonfedb18a1 Pre-2002 Factory Turbo Powertrain 39 09-10-2007 04:33 AM
