Old 02-13-2012, 04:28 PM   #1
noside
Member#: 241254
2015 Scat Pack
Default Noside's GR STI Built by IAG, Powered by BP Dom5, Battle Ready
Hello NASIOC!
Just to start I'd like to introduce myself very briefly. My name is Mike, I'm 23 and I'm from NJ. I purchased my 2010 DGM STI hatch in Feb of 2010 out of Bay Ridge Subaru in Bklyn NY.
Since then the car has been a blast to drive. I had it modded with your basic intake, tbe, el headers, ebcs meth injection and tuned by me. Well that lasted about 42k miles and now here I start with a bad cylinder #2, a plan, a shop, and a bunch of parts!
I've always done all of my own installs, tuning etc over the past 5 years with two cars. This time I think its just to much to handle on my own in Feb without a garage to even work in.
Keeping that in mind I've talked to IAG performance to have them take care of the build and tuning. This is my build plan though FWIW.
I'm open to comments, complaints what you think I should do differently etc. The plan is though to come as close to 500awhp as we can with everything in the stock location!
02/01/12
The start of my RE~build
here's the plan
Engine/Power adders
Vigilant Motor Sports Track Series Short Block, built by Sean @ Vigilant - Ordered ETA 3 weeks
2.5 Liter STi semi-closed deck case
Modified forged EJ257 crankshaft
High Performance ACL Main & Rod Bearings
Pauter 4340 Chrome-Moly Forged Rods
CP Forged Pistons w/ Moly Coated Skirts
High Performance Piston Rings
Fully Balanced & Blueprinted
8,500 Rev Limit Recommended
Manley Sport Compact Valve Springs and Retainers
[email protected] / [email protected] / [email protected] ( these were the lightest upgraded springs I could find, I didn't want to overload the stock valves with a double spring )
KillerB Motor Sport Oil Pan, Pickup, and Baffle
Injector Dynamics 1000CC Injectors
Perrin Black Fuel Rail kit
DW 65C pump
Snow Performance Stg3 WMI -4AN custom dual port
KS Tech MegaMAF Type 3 CAI
Agency Power 3" Solid Turbo Inlet
Process West TMIC
Forge BPV
CNT catless bell mouth DP
ERZ quad CBE
Tomei EL headers
IAG 38mm EWG 3 bolt uppipe
Tial 38mm EWG
GrimmSpeed EBCS
Engaged Performance PNP Throttle Body / Intake Manifold / TGV Deletes
OEM Engine Gasket Set
FluiDampr
Gates Racing timing belt kit with water pump
Gates Racing power steering and alternator belt
OEM 12mm Oil Pump
OEM Oil Cooler
Tomei Timing belt guide
NGK 1 step colder plugs
Torque Solution air pump delete plates
Perrin alternator and radiator covers
Torque Solution 12mm exhaust hangers
Blouch Dominator 5.0XTR the biggest, baddest mammer-jammer bolt-on turbo for the Subaru WRX/STi offered by Blouch
Drivetrain / Suspension / Mounts / Bushings
Clutch Masters Fx300 segmented kevlar disk
OEM Flywheel
TigWerks Motor Mounts
Torque Solution Pitch Stop
Groupe N Trans Mount
Torque Solution Positive Shift kit
Torque Solution Prop shaft inserts
Torque Solution rear shifter bushing
Perrin Shifter bushing insert
SPT OEM Short throw shifter
Fortune Auto Dreadnought Coilovers, 9kF/10kRR Custom Swift Spring rates (Ordered Nov 9th)
Whiteline 24mm front and rear adjustable sway bars
Kart Boy solid endlinks
GT Spec rear lower control arms
Cusco Front power brace
Exterior
INGS+1 shaved and smoothed Front Bumper
Badge less Grill
Rear De-badged
Red outline tails
Rally Armor mud flaps
WeatherTech Rain Guards
DressupBolts.com Ti dress up kit
Wheels / Tires / Brakes / Lugs
OEM 18" Forged BBS silver wheels on OEM Dunlops
17x8 Sparco wheel 235/45/17 blizzak lm-60
Hawk HPS pads
Fortune Auto Ti Smart series lugs.
Interior / Gauges
SMY CluterMaker Dual gauge pod
AEM tru boost digital boost gauge
AEM Wideband Uego Digital gauge
NYRM98 triple 52mm A pillar gauge pod
Prosport Evo Oil Pressure gauge
Prosport Evo Oil Temp Gauge
Prosport Evo EGT gauge
FlossyShop.com Redheaded Shorty shift knob
Some shots of the car over the time of ownership
LM60's for winter 2011-12
Project completion date is expected to be the end of the 2nd week in march to begin break in.
noside is offline   Reply With Quote
Old 02-13-2012, 04:28 PM   #2
noside
Member#: 241254
2015 Scat Pack
I take pictures of everything that I get, here is what I have in my possession at this time.
TigWerks motor mounts
Tomei Expreme EL header/uppipe
IAG 3 bolt 38mm EWG kit.
ClutchMasters FX300 Kevlar disk
Old 02-13-2012, 04:28 PM   #3
Pandafactory
Member#: 228349
03 Impreza Wagon
sweet. what bumper is that?
Pandafactory is offline   Reply With Quote
Old 02-13-2012, 04:40 PM   #4
noside
Member#: 241254
2015 Scat Pack
DW65C drop in fuel pump
Perrin Black Fuel rails
Injector Dynamics 1000cc injectors
Process West TMIC
Forge BPV
Engaged Performance PNP TB and TGV
Old 02-13-2012, 04:41 PM   #5
noside
Member#: 241254
2015 Scat Pack
Ixiz concepts vacuum distro block
Manley stock Replacement valve springs and retainers
KS tech Mega MAF
JDM 12mm oil pump
KillerB picup, oil pan, and baffle
ARP 2000 head bolts
Agency power inlet
Gates racing timing belt, ac belt, ps belt, water pump, rollers and complete oem engine gasket kit
Old 02-13-2012, 04:45 PM   #6
noside
Member#: 241254
2015 Scat Pack
nyrm custom 52mm triple gauge pod
SMY dual 52mm dash pod
Prosport evo oil pressure, oil temp, EGT gauges
Installed
GT spec RCA
Cusco front power brace
Fortune Auto TI smart series lugs
Dress up bolts TI fasteners
Custom methanol install
Old 02-13-2012, 04:55 PM   #7
noside
Member#: 241254
2015 Scat Pack
Blouch Dom 5.0 XTR is in, big thanks to RallySportDirect.com for there help with it.
Thank you to SubaruOnlineParts.com as well. Ordered my OEM oil cooler and replacement lower control arm hardware with them. They threw in a nice USRT 2012 calendar and a Subaru air freshener. :tup:
2-17-12
installed cusco front power brace
installed Mishimoto radiator
Replaced new AIS 250psi wmi pump
Ixiz Cocept AOS with CCvent
Old 02-13-2012, 04:56 PM   #8
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
Mr.Chow is offline   Reply With Quote
Old 02-13-2012, 05:28 PM   #9
REXXYY
Member#: 265754
2003 STI
Nice list of parts.
REXXYY is offline   Reply With Quote
Old 02-13-2012, 05:53 PM   #10
Soulless
Member#: 263667
2002 WRX Sedan
Wrb
So much eye candy
Soulless is offline   Reply With Quote
Old 02-13-2012, 07:54 PM   #11
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
good job on your shop choice! iag knows their $hit
shadowmd is offline   Reply With Quote
Old 02-14-2012, 09:45 AM   #12
IAG Performance
Member#: 158123
Thanks man, we are stoked to be a part of this build!!!
Rick
IAG Performance is offline   Reply With Quote
Old 02-14-2012, 10:09 AM   #13
Wirtz
Member#: 286408
WFC #952
Function:error!
Damn clean car and damn good photos
Wirtz is offline   Reply With Quote
Old 02-14-2012, 10:44 AM   #14
Dstretch33
Member#: 157211
2k4 stg. 2 WRX sti
This build looks promising, great photos of the parts.
Dstretch33 is offline   Reply With Quote
Old 02-14-2012, 04:47 PM   #15
noside
Member#: 241254
2015 Scat Pack
I'll be able to sleep good knowing that she will be in very capable hands!
Rick
^ thanks Rick I'm likewise as excited to have my build done with you guys. Can't wait to come down in a couple weeks.
Just have to say Rick is par none as far as customer service goes. This guy will not dissapoint you. I had a few problems with dealing with a shop 3 hours away but Rick is taking care of everything, down to even getting my car to IAG.
Thanks man, I try to keep her clean even though its my DD. I always appreciate the comments on my photos.
Thanks every day it feels a little more promising then the last .
No real updates for today, just got off the phone with my engine builder and my pistons are leaving swaintech today and he should be done building my motor middle of next week. I should have the motor by the last week of feb/ first week of march when I get back from Radial Rumble the night the lights went out at SGMP. Should be a good surprise to return home with.
Side note, big updates expected for tomorrow as long as the men in brown don't let me down
Old 02-14-2012, 05:28 PM   #16
dave_88
Member#: 65864
WRX gone; hate the
Honda forums so much.
Wow, actually jellin a little. Good luck with the build.
dave_88 is offline   Reply With Quote
Old 02-14-2012, 06:32 PM   #17
kevosnowsti
Member#: 202097
2001 Subaru 2.5rs
BRP
Bunch of sexy parts!
Originally Posted by noside View Post
...and White Castle on a snow day FTW!
kevosnowsti is offline   Reply With Quote
Old 02-14-2012, 07:21 PM   #18
noside
Member#: 241254
2015 Scat Pack
Why you Jelli Bro!? I've been stuck driving my back up 88 cavalier because of this!
Whats even better is White Castle breakfast to get the snow day started. If anyone hasn't tried a breakfast slider yet they don't know what they're missing!
Old 02-15-2012, 02:49 PM   #19
noside
Member#: 241254
2015 Scat Pack
UPS came through, updates in post #7
Old 02-15-2012, 06:21 PM   #20
YZ86
Member#: 188705
GD Widebody STI
Lexus Pearl White
Lot of nice parts! good luck with the build.
YZ86 is offline   Reply With Quote
Old 02-15-2012, 06:31 PM   #21
besthaticouldo
Member#: 279660
wow...definitely going to be watching this build...that IAG up-pipe is amazing, was going to go grimmspeed, but maybe you've changed my mind.
besthaticouldo is offline   Reply With Quote
Old 02-16-2012, 12:54 AM   #22
20wrx05
Member#: 177861
1999 Built! RSTI
FP Red, E85, IM FAST!
why the top mount, that will be a limiting factor for power for sure with the Dom-5, but besides that killer build! Love that front bumper! but you sure do have a lot of $$$$ in pats though! haha
20wrx05 is offline   Reply With Quote
Old 02-16-2012, 01:14 AM   #23
sxcobraz249
Member#: 123770
2006 WRX
^^^ What he said... you have all these awesome engine parts a nice new bumper with a huge hole for a front mount and you go with a top mount?? Did you run out of money lol jk man congrats on the build... I too feel like the top mount is gonna set you way back
sxcobraz249 is offline   Reply With Quote
Old 02-16-2012, 01:29 AM   #24
noside
Member#: 241254
2015 Scat Pack
Much appreciated!
The kit is complete the welds are perfect inside and out, and there is no flex section. I bought this setup before I even new I was going to IAG because it looked well put together.
A couple reasons I decided to use a tmic. First I wanted to keep lag to absolute minimum by keeping everything in the stock location but still getting the biggest turbo in there that I can. Next ill be running wmi so that does an extremely great job at bringing down IAT's and keeping detonation from occurring regardless of intake temps. I'll wrap the pw core in reflectagold along with the y pipe, intake, and inlet. Headers, uppipe, ewg dump will / are wrapped in dei titanium exhaust wrap. This stuff is serious I can not feel radiating heat from the components wrapped pretty much at all. Titanium turbo blanket is on order as well, I needed to get the measurement of the exhaust side of the turbo today to figure out which size I would need.
Lastly the most non performance reason that I dont initially want a fmic is because of the bumper. It's very aerodynamic the center lower grill opening completely seals itself against the condenser. A lot of hacking away at the bumper would have to happen to get it to work. And to be honest that bumper took me about 6 months to get and have painted along with about $1600 end price tag and I really dont want to do that.
If it really turns out to be a huge limiting factor well do something about it but atleast now you know my reasoning.
Old 02-16-2012, 01:56 AM   #25
Speedster329
Member#: 214652
2004 STI !
JBP !
wow these are high quality parts ! Good setup....keep us updated on the car bro
Speedster329 is offline   Reply With Quote
N/A 1.8 Re-build kit? OffroadGL 'Old School' Subaru Forum 7 07-09-2004 11:57 AM
re-building my old-skool playstation library RaceCarRiot Off-Topic 9 01-17-2004 01:34 AM
Shop that does turbo re-builds? mofoporn Rocky Mountains Impreza Club Forum -- RMIC 10 01-17-2003 11:54 AM
Definitive Post on ECU re-building Fuel/Ignition Maps is2scooby Engine Management & Tuning 8 11-07-2002 05:54 PM
Re-Building a bulletproof '98 DOHC JoelR Normally Aspirated with bolt-on Forced Induction Powertrain 1 07-24-2001 04:52 PM
