Old 02-13-2012, 05:58 PM   #1
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Default 08+ WRX Omni Power 3 and 4 Bar MAP Sensor (also 05-07 LGT)
OK, everyone knows that Omni Power makes a plug and play MAP sensor for the 04-07 WRX and 04+ STI. Unfortunately, the 08+ WRX and 05-07 LGT use a remote-mounted MAP sensor that gets its boost input from a vacuum line off the manifold, and uses a different electrical connector than the STI sensor (and older WRX's). This mean the STI MAP sensors will not work.
When I was researching this topic, it seemed that the most common solution for the 08+ WRX was to purchase the AEM universal MAP sensor and hard wire it into the car. I was trying to avoid cutting into my OEM wiring, and eventually determined that the Omni Power MAP sensor for the 93-98 Toyota Supra looked very similar to the one on the 08+ WRX. I decided to give it a try, and it fit!
The 93-98 Supra MAP sensor is a perfect match both physically and electrically. It mounts in the OEM sensor location, using all OEM hardware and hoses. The electrical connector is identical and plugs right in. It is a 100% plug-and-play installation, and it would be completely possible to revert back to stock if so desired. No permanent changes are required.
Here is a link to the sensor on the Omni Power site:
http://omnipowerusa.com/product.asp?P_ID=164
And here is a photo of it next to the OEM 08+ WRX sensor:
I was very pleased to find that this sensor worked, and I hope this info will be useful for someone else! There are a few more photos at the end of the post.
Why would you need an aftermarket MAP sensor? If you plan to run higher boost than the OEM sensor can read. This is somewhere in the 22psi range. If your boost levels are higher than that, you would probably want a new sensor, or else the ECU is essentially blind to what pressure is in the manifold. If you are running less boost than this, there is no benefit to upgrading the sensor.
Note: Once you have the sensor installed, you will immediately need to re-flash the ECU with new scaling parameters or the car will not start. This is because the sensor does not read the correct atmospheric pressure, so the vehicle won't turn over. Keep this in mind before you install the senor. The good news is that it literally takes 30 seconds to install or remove, so it's not hard to swap back to stock. The scaling values for the Omni Power sensors can be found here:
http://forums.nasioc.com/forums/show...46&postcount=7
4 BAR
Multiplier = 11.97 psia/V
Offset = +0.506 psia
3 BAR
Multiplier = 9.119 psia/V
Offset = +0.164 psia
More Photos:
xluben is offline   Reply With Quote
Old 02-13-2012, 10:11 PM   #2
cmiller219
Member#: 187179
Chapter/Region: HIIC
14 STi
Cocain
Amazing Find
cmiller219 is offline   Reply With Quote
Old 02-14-2012, 01:28 AM   #3
geddesk2
Member#: 119397
98rs 06sti
RBP & WRB...BLUE!
Nice!
geddesk2 is offline   Reply With Quote
Old 02-14-2012, 03:21 PM   #4
Nuke209
Member#: 108089
2003 WRX
NF Performance
I helped Ben with this and was worth the time.
Not a bad (and affordable) mod for those who needs it.
Nuke209 is offline   Reply With Quote
Old 02-16-2012, 04:53 PM   #5
THE_SMURF
Member#: 260624
2007 Z06/ZX10R
awesome man.... funny thing too is i just sold my mk4 supra, so i thought this was a little funny. thanks
THE_SMURF is offline   Reply With Quote
Old 05-14-2012, 03:41 PM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Originally Posted by Nuke209 View Post
+1
Yep, thanks for the help! This is a great solution for a plug and play MAP on the 08+ WRX!
Old 05-24-2013, 09:30 AM   #7
lordsanointed
Member#: 301522
2011 WRX
Great information.
It helped me so much!
Thanks!
lordsanointed is offline   Reply With Quote
Old 05-24-2013, 09:32 AM   #8
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
1 year later and someone actually finds this useful!
Old 09-15-2013, 03:56 AM   #9
jacks-GTB
Member#: 303949
2007 Liberty GTB
hey guys, great info.....would this include 07 subaru legacy gt?
jacks-GTB is offline   Reply With Quote
Old 09-15-2013, 04:05 AM   #10
jacks-GTB
Member#: 303949
2007 Liberty GTB
sorry I just realized that its written in the topic
Old 10-24-2013, 04:58 PM   #11
JBinda420
Member#: 321692
2008 WRX Sedan
Dark Grey Metallic
Holy cow this is great information! I'll be running full SD and more boost+EWG and i was looking for a plug&play solution! +1
JBinda420 is offline   Reply With Quote
Old 01-09-2014, 12:58 PM   #12
leemwalls
Member#: 325396
2014 WRX Hatch
WR Blue
Just wanted to say awesome post and if anyone is interested in picking one up new never used I've one up for sale today.
http://forums.nasioc.com/forums/show...1#post41248221
leemwalls is offline   Reply With Quote
Old 05-17-2015, 02:59 PM   #13
turkeylord
Member#: 89016
2005 Legacy GT Wagon
ABP
Bump. xluben and others that have run this sensor - have you had good luck with it? I see mixed reviews out there, but it seems the issues are mostly with the 4BAR, and the 3 is plenty for me.
turkeylord is offline   Reply With Quote
Old 05-17-2015, 03:39 PM   #14
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Worked fine for me.
Old 05-17-2015, 03:46 PM   #15
turkeylord
Member#: 89016
ABP
Awesome. Others are recommending GM or AEM, but this is so slick...
Old 02-16-2016, 04:01 PM   #16
ninjasane
Member#: 315224
2011 WRX
super cool, thanks for sharing!
ninjasane is offline   Reply With Quote
FS : Megan Racing DP, Omni Power 4 Bar MAP sensor - stock location kellygnsd SCIC Private Classifieds 13 09-12-2012 04:34 PM
FS : Omnipower 4 Bar Map Sensor, plug and play kaane Engine/Power/Exhaust 0 03-31-2011 04:01 PM
FS : Mega Squirt Verson 3.0 with 4 bar MAP sensor, Relay board, Harness and cable to conn martystoked Engine/Power/Exhaust 18 11-19-2010 02:19 PM
FS: (VA)-TurboXS UTEC w/ map selector switch, 4 BAR MAP sensor Clark_Kent Engine/Power/Exhaust 6 06-09-2008 03:33 PM
FS: (VA)-TurboXS UTEC w/ map selector switch, 4 BAR MAP sensor Clark_Kent MAIC Private Classifieds 9 06-09-2008 03:33 PM
