Old 02-13-2012, 08:04 PM   #1
GromsKillA
Member#: 292760
2005 CGM STi
'02 Impreza OBS
Default 05 STi Data Log
GromsKillA is offline   Reply With Quote
Old 02-13-2012, 08:14 PM   #2
maxg1989
Member#: 293057
Looks like your not getting any knock which is very good! that FMIC is working well which if its a standard cobb tune not ment for a Front mount, you could probably get away with more spark advance in some places since you are front mounted.
the only red flag i see is that you are exceeding 100% on what looks to me like Injector duty cycle ( Inj Duty cylce %) 104% in some places, which (anyone correct me if im wrong) isn't good and you could fry and injector causing it to stick open ect ect.
Which means your injectors aren't keeping up with the ecu's demands. and is keeping them open 100% of the time. ( not good)
I would ask cobb about that.
maxg1989 is offline   Reply With Quote
Old 02-13-2012, 09:29 PM   #3
GromsKillA
Member#: 292760
2005 CGM STi
'02 Impreza OBS
Old 02-13-2012, 10:07 PM   #4
maxg1989
Member#: 293057
I dont tune with cobb at all, so i dont know what they target for boost in that specific map, You are only hitting 71% wastegate duty cycle which mean if the computer wanted to make more boost it has 29% more duty cycle it could throw at the wastegate (close the wastegate more) to make the boost. This map, just from reading a tiny little bit right now on cobbs site says its boost target is 17.5 +/- .5psi and it tapers down to 12psi towards redline so you are really really close, you hit 17.08 psi. Also whatgear were these taken in usually 3-4 will have more load making more boost. And if the car wasn't fully warmed up it could not be targeting exactly 17.5psi due to colder coolant temps, which if those logs are in order your first log showed boost was a little weak but your middle log made the most boost and the third was a little less than the second. Your boost seems to be just fine to me, i wouldn't worry to much about a boost leak or anything like that.
Yeah a pro tune would be a good idea to maximize your bolt ons and that front mount. but as far as this tune, it seems to be working just fine to me, except for the Injector issue.
also did you just flash this map? sometime it takes a little while for the computer to get settled in.
This is directly from cobb "If after 1-2 weeks worth of driving you are still unable to reach target boost pressures; you may try using the HWG version of this map."
Old 02-13-2012, 11:02 PM   #5
GromsKillA
Member#: 292760
2005 CGM STi
'02 Impreza OBS
Data logs from 05 STi, Stage 2 OTS danny_d19 AccessPort 19 08-22-2012 11:31 AM
Please Check My Data Log (New logs added) Xsile STI Engine Management & Tuning 6 04-30-2010 04:17 PM
05 STi ECU Log Jrags87 Newbies & FAQs 6 07-15-2009 05:30 PM
Data logging gurus, need your help reading log. vortectoy AccessPort 5 05-22-2006 01:19 AM
05 Sti Data Log, What Does It Mean? RIRENTER Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-20-2006 12:24 AM
