Old 02-13-2012, 09:06 PM   #1
m1nus
Member#: 296328
04 Wrx wagon
Default fine knock learning issue? 04wrx stage2 LOG inside
https://docs.google.com/spreadsheet/...jFnd3I4WDlYYkE
took this in 3rd to redline and then to 4th for a little ways...
loaded it and there is -1.05 when im in 4th gear
ive only ever logged in 3rd gear, so maybie this always happened?
i just fixed a fuel leak on the passenger side fuel rail at the stupid soft line connectors. installed a perrin turbo inlet and cobb sf intake and air box.
heres the car
-Cobb AccessPORT stage 2 93 octane ( just filled tank about 20 min prior to the run, and its about 25deg out)
-Cobb 3'' High Flow Cat. Downpipe
-Perrin 3'' Cat Back Exhaust
-Grimmspeed ceramic coated uppipe
-Perrin Radiator Shroud
-STI Top Mount Intercooler
-Walbro 255 Fuel Pump
-Perrin Turbo Inlet
-Cobb SF intake
-Cobb SF air box
-Perrin BPV hose
-Samco turbo outlet to "y" pipe
is there any reason to be concerned with the fine knock learning?
m1nus is offline   Reply With Quote
Old 02-13-2012, 09:44 PM   #2
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
It seems you had a single knock occurance at about 5100 RPM. My suggestion woul dbe to run the same pull again and look at it. You may need to go into ATR and just remove 1 degree of timing from that section of your map. You also seem to be overboosting a bit.
Black94Snake is offline   Reply With Quote
Old 02-14-2012, 11:21 AM   #3
Cobb Tuning
Member#: 4803
The Fine Knock Learning value appears to be going down, but a battery reset would revert those values back to 0. This would help you determine if it comes back from a consistent issue or not.
What version map are you using? If you are not already, I would recommend the v3.10 that can be downloaded straight from the Support section of our website. They are all new maps.
Ian
Old 02-14-2012, 12:31 PM   #4
m1nus
Member#: 296328
04 Wrx wagon
Thanks for the responses guys, it is the 3.10 93 octant version. And i had the battery out for a whole day while I took the intake manifokd off to do repairs. This log was after a quick test drive the night I finished the repairs, and the following day on the commute home from work after a fresh full tank of gas. So its realitivly fresh except the trip to work in the morning
Can't I just reset the ecu with the access port instead of pulling the battery also?
Old 02-14-2012, 04:29 PM   #5
Cobb Tuning
Member#: 4803
Yep, that way works also.
Ian
Old 02-17-2012, 05:03 PM   #6
m1nus
Member#: 296328
04 Wrx wagon
two more logs,
the first link is a 3rd gear pull. a day after the one i posted above.. this has me concerned about the knock. before i put on the turbo inlet and cobb intake i didn't have these issues... any ideas?
the second link is a quick 4th gear pull right after.
help me out. am i doing damage?
https://docs.google.com/spreadsheet/...lFXMnJxeEplenc
https://docs.google.com/spreadsheet/...nhiZGxtOUhCV1E
Old 02-18-2012, 08:18 AM   #7
snoopy_sti
Member#: 164942
2015 Porsche Cayman
Looks like in the second log the fine knock learning is decreased and being learned away. Good thing.
snoopy_sti is offline   Reply With Quote
Fine Knock Learn & Feedback Knock. MakuseruSukotto AccessPort 18 04-25-2015 11:04 PM
Fine knock learn issue failchawi AccessPort 1 08-28-2011 07:26 PM
Log with Fine Knock Learn? wrx904 AccessPort 5 08-24-2011 11:10 PM
feedback knock and fine knock learning??? please explain. dudenhoeffer02wrx AccessPort 3 07-28-2011 11:55 PM
Fine Knock Learning in ATR Tripintaz AccessPort 5 10-01-2010 09:31 AM
