Welcome to the North American Subaru Impreza Owners Club Friday September 4, 2015
Old 02-13-2012, 09:22 PM   #1
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
Default High pitched farting noise (from the car)?
Yeah it's funny until it happens to you.
Weekend before last I bolted on a Perrin downpipe and flashed to stage 2 with my AP. Now when I really get on the gas I eventually hear this high-pitched farting noise. It's like when you blow up a balloon and then pinch the opening and slowly let the air out, pwweeeeeee. It sounds like when the engine's really pulling there's some small hole somewhere that's allowing air in.
I did take the intercooler off to get better access to the bolts on the downpipe, but everything seemed to bolt back on fine.
I don't notice any change in performance.
I've had an AEM CAI on for a while, don't see how that could be causing the noise.
It sounds like it's coming from the intercooler, but I'm not sure.
Any ideas for the obvious place(s) to look?
Dale2011WRX is offline   Reply With Quote
Old 02-13-2012, 09:41 PM   #2
Napalm3nema
Member#: 263954
2014 EVO Yes, EVO
Wicked White
Did you replace the gasket at the mouth of the downpipe when you put on the new downpipe?
Napalm3nema is offline   Reply With Quote
Old 02-13-2012, 09:43 PM   #3
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
Sounds like a boost leak, check all your fittings for the intercooler and tighten them down
brew02wrx is offline   Reply With Quote
Old 02-13-2012, 09:57 PM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
^ this
Old 02-14-2012, 07:37 AM   #5
Dale2011WRX
Member#: 304299
2011 WRX, white
Thanks for the replies.
Yes, I replaced the downpipe gaskets at both ends.
I'll take the intercooler back off and be extra-careful as I put it back together.
High pitched ringing noise from engine bhkim126 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 45 02-20-2010 11:05 PM
High pitched whistling noise from turbo Turbotegra Normally Aspirated with bolt-on Forced Induction Powertrain 5 01-18-2004 03:47 AM
High pitched rining noise from engine bhkim126 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-09-2004 07:18 AM
High pitched squealing noise Blizwinter Service & Maintenance 2 12-28-2003 09:26 PM
rattling + high pitched grating noise from right rear 98GTlegacy Transmission (AT/MT) & Driveline 0 12-02-2003 04:57 PM
