Old 08-16-2002, 05:08 PM   #1
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
Default newbie question about Sway bars - please help
Hi,
I have a question about sway bars. What does it mean to say sway bar is 20mm? What does 20mm mesures? I first thought that it would be a diameter of the bar. But when the sway bar is adjustible from 18-20-22mm then how does that works, you can't really change a diameter.
Please can some one explain it to me?
Thank you
Alex
Osgood30 is online now   Reply With Quote
Old 08-16-2002, 05:27 PM   #2
superstring
Member#: 4577
1998 2.5RS
Black Diamond Pearl
Post
Hi Osgood30
If you have a non-adjustable 20mm anti-roll bar, the bar will in all probability measure 20mm in diameter.
An adjustable bar, such as a 18-20-22, simulates different diameters by using different attachment points at the bar ends (three in the example). Each attachment point creates a different effective length and therefore a different rate.
Is that clear?
superstring is offline   Reply With Quote
Old 08-16-2002, 05:34 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
That is usually true. However different manufactures 20mm bar might be stiffer or softer than another so sometimes even though it says 20mm it might be something else, they tell you that its as strong as a standard 20mm
Question about sway bar upgrade Liam Brakes, Steering & Suspension 6 06-16-2007 12:39 AM
question about sway bars madspecvman Texas Impreza Club Forum -- TXIC 30 12-28-2005 03:57 PM
Quick question about sway-bar bushings speedracer47 Brakes, Steering & Suspension 2 08-23-2001 01:40 AM
questions about sway bars Tweek Brakes, Steering & Suspension 1 07-26-2001 08:16 AM
('93-'01) questions re:rear sway bar/please help Nordstone Impreza Forum 10 05-02-2001 02:46 PM
