Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-14-2012, 12:42 PM   #1
rocky_66
Member#: 215037
2005 STI
Default 04 sti instantly dies when started
Hey guys, my buddy recently had to swap out his aftermarket turbo-back exhaust and his perrin front mount/intake for stock to pass emissions/smog/intake laws in california. After passing, he swapped everything back to how it was previously and now it's having problems. When he starts it up, it will instantly die. However, if he unplugs the MAF sensor, it will run. He got a hold of another person's working MAF sensor and tried it as well, same problem. Anyone have a clue what's wrong?
rocky_66 is offline   Reply With Quote
Old 02-14-2012, 12:45 PM   #2
rocky_66
Member#: 215037
2005 STI
BTW, his tune is a COBB accessport.
Old 02-14-2012, 01:23 PM   #3
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Something is unplugged, or he's putting in the maf backwards. Also why not just swap the downpipe, that's the only thing that would prevent him from passing emissions.
car_cursed is offline   Reply With Quote
Old 02-14-2012, 01:32 PM   #4
rocky_66
Member#: 215037
2005 STI
He had to swap stock turboback because of the downpipe and visual cat inspection. They also wouldn't pass his perrin intake because of California intake laws, and stock wouldn't fit because the front mount piping was in the way, so he had to swap it all back. The first thing I said as well was that the MAF was in backwards but he's tried that as well.
Old 02-14-2012, 01:35 PM   #5
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Oh, California, I missed that. But something is likely unplugged or a intercooler pipe connection is leaking badly, are there any cel's?
Old 02-14-2012, 01:55 PM   #6
rocky_66
Member#: 215037
2005 STI
Codes he's seen are "low MAF voltage" and something about the air intake temperature I believe, waiting to get more accurate information.
Old 02-14-2012, 02:09 PM   #7
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
It's a maf problem, have him clean it, check all wires and connections
Old 02-14-2012, 02:16 PM   #8
rocky_66
Member#: 215037
2005 STI
codes are p0102 and p0113
Old 02-14-2012, 02:27 PM   #9
rocky_66
Member#: 215037
2005 STI
He's getting these codes when he unplugs the MAF and starts it up though.
If he clears the codes and has the MAF plugged in and starts it, no codes. It just dies.
He said the O-ring is good and it's not on backwards (the plug in part is facing frontwards)
Old 02-14-2012, 02:51 PM   #10
rocky_66
Member#: 215037
2005 STI
With the MAF plugged in, if he gives it gas, it will stay running.
When he lets off the gas, it dies.
Old 02-14-2012, 03:23 PM   #11
Touge86
Member#: 166498
2013 M3
Mint Green
buy gas.
Touge86 is offline   Reply With Quote
Old 02-14-2012, 03:50 PM   #12
r8r4life
Member#: 101464
Intake issue/leak.
r8r4life is offline   Reply With Quote
Old 02-14-2012, 04:44 PM   #13
rossl
Member#: 193147
04 STi
Originally Posted by r8r4life View Post
Intake issue/leak.
This. My first guess would be an intercooler hose leak somewhere or something like that.
rossl is offline   Reply With Quote
Old 02-14-2012, 06:52 PM   #14
rocky_66
Member#: 215037
2005 STI
Thanks for your input guys, I'll update when he figures it out. :P
Old 02-15-2012, 12:38 AM   #15
MarcosV
Member#: 274936
2000 2.5rs
rbp
Could be an egr or idle regulator. It's most likely the idle regulator and it's a pain in the ass to get to on na blocks.
MarcosV is offline   Reply With Quote
Old 02-15-2012, 12:40 AM   #16
MarcosV
Member#: 274936
2000 2.5rs
rbp
Or your tumble generating valves.
Old 02-15-2012, 12:45 AM   #17
MarcosV
Member#: 274936
2000 2.5rs
rbp
Sorry for triple posting but the main source of the problem is that there's no air in your manifold, when you press the gas your throttle body opens allowing air into the manifold and not dying. Checkif the tgv motors are good if you have tgvs but it's most likely the idle regulator on your IM isn't spinning, take it out n clean it with gas.
Old 02-15-2012, 12:53 AM   #18
wrxkyle
Member#: 199635
02-4 rSTI
I have the same exact problem, car runs smooth maf unplugged, dies or stumbles and then carches itself when comming of gas or starting when warm my maf oring is shot but i cleaned my maf and it did better but stull pretty bad, gonna replace the sensor i think. Let me know what you find out
Gonna change the sensor, but i'll look into the idle thing. I thought the dbw sti's just did all that by themselves with no extra valve.
wrxkyle is offline   Reply With Quote
Old 02-15-2012, 01:56 AM   #19
blk25rsti
Member#: 211942
1999 2.5RS coupe wht
01 2.5RS coupe BRP
Sounds like throttle position sensor. voltage out of range at no throttle?...
blk25rsti is offline   Reply With Quote
Old 02-15-2012, 07:54 AM   #20
TurboJunkie85
Member#: 193412
1985 pumas.
white
Sounds like someone stuffed a rag somewhere in the intercooler piping or, the CBV or, BOV recirculation hose is not hooked up or, capped off.....possibly too the pins for the MAF sensor could of broken off or bent in....
TurboJunkie85 is offline   Reply With Quote
Old 02-15-2012, 12:26 PM   #21
MarcosV
Member#: 274936
2000 2.5rs
rbp
If it was a little hose it run but cause a misfire, if it was something blocking the pipes it wouldn't run when accelerated either and if he tried a working maf and it had the same problem then it's probably not the maf.
Old 02-15-2012, 12:52 PM   #22
rocky_66
Member#: 215037
2005 STI
Thanks everyone for your input, it's very greatly appreciated!
Today he "messed with the MAF, giggles some wires and disconnected and reconnected the battery" and his car will idle now. When he gives it gas and the car attempts to go back to idle, it'll chug and almost die again.
Old 02-15-2012, 01:59 PM   #23
MarcosV
Member#: 274936
2000 2.5rs
rbp
If he gives up I'll buy this from him
Old 02-15-2012, 02:25 PM   #24
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
most those things you named have their own CEL's If a motor was stuck shut or open he would have a different cel number. I think it has a leak somewhere. check for hoses not plugged in somewhere.
medamullet is offline   Reply With Quote
Old 02-15-2012, 02:33 PM   #25
MarcosV
Member#: 274936
2000 2.5rs
rbp
He has some Obd codes I haven't looked them up, if the motor on the tgvs don't have a high enough voltage at a specific time or the idle regulator turbine is broken(where the motor spins but turbine doesn't) then it won't throw the code but will not go. Injectors can also not have enough voltage at idle allowing the car to die but then you would get the "mixture too lean" code.
stock 04 STi idles terribly when ecu reset hatched91 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 04-09-2013 03:42 PM
04 STi turbo swap.. Wont Start urabus its 40 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-06-2010 05:24 PM
04 WRX almost stalls when started Whoa!ShutItDown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-24-2010 03:33 PM
Car died when I started it this morning... zackl801 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-24-2009 05:38 PM
My 05 STi keeps dying when I turn off the car drth_sti Service & Maintenance 5 02-05-2007 04:36 AM
