Old 02-14-2012, 01:17 PM   #1
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Default is there any way to use accessport with a hybrid
I have a built 05 sti with non avcs heads
is there any way to run accessport instead of hydra or aem??
shilohb is offline   Reply With Quote
Old 02-14-2012, 04:28 PM   #2
Cobb Tuning
Member#: 4803
Oopsie! See below
Ian
Old 02-14-2012, 06:31 PM   #3
Cobb Tuning
Member#: 4803
So I talked with a few of our calibrators here to verify the information posted earlier and I was a bit wrong.
The cam position sensors are different on the heads and the signals are generated differently. Therefore you can't use the 2.0L heads on a 2.5L ECU using the AccessPORT.
But, using 2.5L heads with some bigger cams would allow you to make the top end power you need while still being able to use the AccessPORT and the stock 2.5L ECU.
Ian
Old 03-01-2012, 12:13 PM   #4
tundra
Member#: 9290
02 Built 2.5L wrx
Sorry for the thread jack, but I have a similar question for you Ian.
Right now I have an 02 WRX, AP V2 (for the 02 ecu), built shortblock, 2.0L heads with oversized valves. Can my car be tuned with the AP or will I have to go stand-alone?
Background: I had my car Pro-Tuned but the tuner was having problems with false knock. The car would pull timing like crazy but all indications showed no evidence of any real knocking. Afterward I checked my compression (it was fine), verified there was no metal to metal vibration in the engine bay, and cleaned the maf..... still the same result.
Have you guys ever experienced this? I'm afraid I might have to go stand-alone and custom recalibrate the knock correction due to a noisier than OEM longblock..... I realize that the oem ecu is limited in this way.
Any input that you guys might have would be extremely helpful, thanks!
tundra is offline   Reply With Quote
Old 03-05-2012, 12:10 PM   #5
turboge
Member#: 35076
2004 507whp Wagon
Thumbs up
You can certainly tune the ECU using the AccessPORT for this kind of configuration. I have a hybrid 2.5L just like you and have been able to tune the car quite easily using the AccessPORT/AccessTUNER combo. There are some knock sensitivity tables that are exposed in the latest TUNER release that can help alleviate the false knock these types of builds produce. I have been able to produce a reliable 500whp on this setup so far with zero issues tuning.
turboge is offline   Reply With Quote
Is there any way to post an embedded video using the html code from the website? Neek Off-Topic 7 08-21-2009 04:14 PM
Tech gurus: Is there any way to trick an installer into thinking an OS is different? Jessie James Off-Topic 11 04-23-2008 02:58 PM
Is there any way to tell what the motor is without the sticker? darksc00by Subaru Conversions 27 11-11-2007 11:03 AM
Is there any way to take my car around a track with spending agagillion dollars? Gerkins31 Off-Topic 55 01-08-2007 12:14 PM
('93-'01) Is there any way to find out if the WRX is the most crashed "new" car this year? Snoopy Impreza Forum 25 10-16-2002 01:53 AM
