Old 02-15-2012, 12:50 AM   #1
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
Default UOA: 11 WRX, 3556mi, 5W/30 Castrol Edge Syntec
2011 WRX, 3556 mi on 5W/30 Castrol Edge with Syntec (black bottle). OEM blue Subaru oil filter. This oil seems to be working well for me. Nice TBN, low wear, and low oil contamination. Shearing is to be expected since it is Resource Conserving.
90% highway at 65-75 mph, usually keeping it below 4k. Revs to 5k about 2 times a day.
I think I'll continue with 3750 mi oil change intervals. I could go to 5000 mi I think, but Syntec would probably shear to 8.X cSt by that point. But if wear continues to decrease, I don't see the problem. Thoughts?
Uncle Scotty:
NO 5W/30, just none, zippo, nada.
Thanks Uncle Scotty for your helpful input.
HTML Code:
OIL             5W-30 Castrol     5W-30 Castrol     5W-30 Castrol     Subaru 5W-30 Factory Fill
                Edge Syntec       Edge Syntec       Edge Titanium     (Idemitsu Lubricants)
MILES IN USE    3556              3296              3182              5135
MILES           15174             11618             8317              5135
SAMPLE TAKEN    02/04/12          12/10/11          10/21/11          09/09/2011
MAKE UP OIL     0 qts             0 qts             0 qts             0 qts
ALUMINUM        5                 5                 7                 -
CHROMIUM        1                 1                 1                 0
IRON            6                 10                11                22
COPPER          4                 6                 12                34
LEAD            0                 0                 0                 1
TIN             0                 2                 4                 1
MOLYBDENUM      77                191               260               976
NICKEL          2                 1                 2                 2
MANGANESE       0                 0                 1                 3
SILVER          1                 1                 0                 0
TITANIUM        1                 6                 38                0
POTASSIUM       1                 0                 2                 0
BORON           42                97                61                166
SILICON         5                 8                 18                79
SODIUM          2                 1                 3                 9
CALCIUM         732               975               954               1854
MAGNESIUM       1544              1296              1223              11
PHOSPHORUS      702               753               766               838
ZINC            771               1084              882               1028
BARIUM          0                 0                 0                 2
INSOLUBLES (%)  0.2               0.1               0.2               0.2
WATER (%)       0.0               0.0               0.0               0.0
ANTIFREEZE (%)  0.0               0.0               0.0               0.0
FUEL (%)        <0.5              <0.5              TR                <0.5
FLASHPOINT ºF   390               400               360               390
SUS VIS 210ºF   58.3              56.5              56.4              52.6
cSt @ 100ºC     9.72              9.22              9.17              8.06
TBN             7.1               7.6               6.7               3.5
furiouswrx is offline   Reply With Quote
Old 02-15-2012, 07:59 AM   #2
bluesubie
Member#: 767
04 FXT
You're definitely doing the right thing by keeping your intervals short before thinking about extending them. Yes, the oil will shear to a 20 grade if you extend the interval but the oil is still functioning as it should with a strong TBN and wear is low. Most importantly you're covered under warranty.
Having said that I'm not sure that a Blackstone uoa is the best tool for extending your intervals and is not the be all and end all of determining wear. Just look up old posts by BuickGN at bitog. Good uoa's even with a chunk of a piston sitting in his engine.
I like how you saved Uncle Scotty the trouble by already quoting him.
-Dennis
Old 02-15-2012, 09:10 PM   #3
2011OBPWRX
Member#: 296791
2011 wrx
Uh, you're running a syn oil for <4k miles, already shearing, and you're giving scotty ####? Why not just run a dino oil and likely get similar results for half the price? Maybe then you'll actually have grounds for acting snobby.
2011OBPWRX is offline   Reply With Quote
Old 02-15-2012, 10:04 PM   #4
bluesubie
Member#: 767
04 FXT
The zinc level on the last run is too high.
-Dennis
Old 02-15-2012, 11:15 PM   #5
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
I'm just saving him the trouble of posting the same thing he does in every 5W/30 post. Lighten up. Nothing snobby here. And what's with the double standard - Uncle Scotty can call everybody who disagrees with him a &*#$* kiddie/idiot and I'm not allowed to tease him?
Subaru requires synthetic 5W/30 Resource/Energy Conserving oil for 2011 WRX/STI, so that's why I don't run dino.
Old 02-15-2012, 11:15 PM   #6
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
-Dennis
What does that mean?
Old 02-16-2012, 07:57 AM   #7
bluesubie
Member#: 767
04 FXT
The factory fill Idemitsu has higher levels of zinc than RC oils. Unlike moly, which hangs out in your engine for a while as you can see in your trend, your zinc dropped to a normal level during the run on Titanium. But then it jumped to a level higher than the API allows on your first run of Syntec.
You should check with Blackstone. They're known for wonky zinc numbers.
-Dennis
Old 02-17-2012, 10:59 PM   #8
PROcede
Member#: 293500
11' WiderBody Hatch
Ah ha! You are the guy that the service advisor Kevin was telling me about that did the blackstone test on the different oils. Great job on letting them know about their oil and thanks for testing this brand. I will look into this brand for my 2011 WRX.
PROcede is offline   Reply With Quote
Old 02-18-2012, 02:50 PM   #9
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
Yup that would be me. Reminds me, I should forward the results to Kevin.
A note of warning though, as you can see, Castrol Edge 5W-30 RC shears pretty quickly in our engines, especially compared to 40 wt oils like RT6 or M1 0W-40.
I would not run more than 5000 mi on this oil. Dennis suggested not running much more than 4000 mi. I will probably change/analyze again at 4200 mi and adjust from there.
UOA: 11 WRX, 3296 mi, 5W-30 Castrol Edge Syntec furiouswrx Service & Maintenance 37 12-30-2011 05:44 PM
UOA: 11 WRX, 3182 mi, 5W-30 Castrol Edge Titanium FST furiouswrx Service & Maintenance 8 10-31-2011 01:08 AM
UOA: 02 WRX, 3200 Miles: 0W30 German Castrol Syntec Buffman Service & Maintenance 7 10-29-2011 10:13 AM
UOA: 2003 WRX 150k Castrol Syntec foxboroxt Service & Maintenance 5 03-31-2008 09:13 AM
UOA: 2006 WRX 5MT Castrol Syntec 5w-30 Mind Service & Maintenance 18 03-08-2007 09:29 AM
Message Board Statistics All times are GMT -4. The time now is 09:06 PM.
